Question about Logitech Harmony 880 LCD Remote Control
Harmony 880- how to take be back cover off?
Coffee was spilled on the remote. the buttons are now sticky. i would like to remove the back cover and clean them with isoproal alchohol. i only saw 2 visable screws and removed them but the back still dosent want to pop off. how do i get the remote to come apart?
  • paul_nagy Dec 12, 2008
    the mystery is solved. I didn't realize it had those retaining clips in there. thank you for your help and the detailed directions!!!
Once the screws are out, using your finger nail (I find the thumb is best), with the remote display side up - do the following: At the very narrowest part of the remote, with the display facing up, wedge your nail in and down. This will spread the cover just a bit. Move forwards and backwards, and you should get the retaining clips to "pop' out from the top half. Do one side completly before the other, there are 4 "clips" per side. If you did this carefully, you will not have broken any of the clips, nor scratched the plastic. When re-assembling, be sure the IR / USB cover is properly in place before evenly snapping the top and bottom halves back together. Hint, if you look very carefully in the seam, you can actually tell where the 4 clips are as there is a slight indent and it is a bit darker.
If you do not want to damage the case edge, or break the clips....DO NOT use a screw driver, and do not force anything very far into the seam.
Posted on Dec 12, 2008
Bweh's solution worked great. Just want to add that a thin butter knife helped 'pop' the 4 'clips' out.
Posted on Jan 01, 2010
Were you able to get your remote working? Just spilled 16oz of latte on my Harmony One and it's dead right now. Wondering if there'sbany hope
Posted on Jan 25, 2010
I spilled coffee on my Harmony Remote 650. I've got move of it but I noticed there's liquid drops inside the screen. Can you remove the back of this unit to clean it?
open the remote and clean the keypads with contacts cleaner or ethylic alcohol to 75% , for dirty, humidity, corrosion, oxide, bad contacts.
1a) clean the contacts batteries and retigh the spring for better contacts
2) reset the code
3) try again.
4) if the problem persist go to the repair shop for fix it.
God bless you
Oct 16, 2012 | Televison & Video
Tip
Harmony 880 Manual Download
Download Logitech Harmony 880 Remote Control Manual
Have you misplaced your Logitech Harmony 880 Remote Control Owners Manual?
Would you like a digital, searchable, pdf version of the Logitech Harmony 880 Remote Control Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
__________________________________________
Logitech Harmony Firmware Update
Harmony Mac Software Download
Harmony Win Software Download
Logitech Harmony Safe Mode Fix
Harmony Remote Glow Light Fix
on Apr 30, 2010 | Universal Remote Control Harmony 880...
Tip
I hope that helps.
on Apr 30, 2010 | Logitech Harmony 880 Universal Remote...
Non functioning "zero" button on Logitech Harmony 880 Rf remote
The problem may be either a stuck "0" button, or the contact on the control board is dirty. You can take the remote apart by removing the screws and slowly separating the top and bottom halves of the remote. There should be 2 screws on the back of the remote (1 is hidden under the battery/cover). If you need further assistance let me know.
Oct 31, 2009 | Logitech Harmony 880 LCD Remote Control
When I go to the guide grid om my Directv right arrow doesn't
Found instructions in another post for removing the back plate. Trying to clean contacts and buttons to make it work.
Sep 11, 2009 | Logitech Harmony 880 LCD Remote Control
Tip
I hope that helps.
on Apr 30, 2010 | Logitech Harmony 880 LCD Remote Control
Don't know how to open back ofLogitech 880 Harmony remote control
Hey!
I thought you might want to look at the following link for how to remove the back of your Harmony Remote!!!
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=12583
Hope this helps!!!
-Kennedy
Aug 31, 2009 | Logitech Harmony 880 LCD Remote Control
Need to have lcd screen replaced on my harmony one remote
Harmony One and 900: If you pry off the rubber backing (Glued on with a sticky rubber) you can expose the screw heads in order to separate body shell. There is also a couple screws inside the battery compartment. I believe you need to remove the ID sticker in battery compartment to expose these screws. It doesn't come apart easy but I did manage to open one. Unfortunately the LCD ribbon cable is Machine/Computer soldered to the mother board so it is not replaceable like the 880/890.
Mar 13, 2009 | Logitech Harmony One Advanced Universal...
Harmony 880 Logitech tv remote - won't change channels on direct tv
you may need to reprogram your remote, or, if you have your profile setup on the harmony website, reload from there
May 11, 2008 | Logitech Harmony 880 LCD Remote Control
Logitech Harmony 880 LCD Remote Control Logo
2,073 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
syspro
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
