Question about Philips 26PW6341 26" TV
Picture does not fill left and right side
Picture is not filling complete picture area. Concentrating in the center not filling left and right side.
  • 100 Answers
Try chenging the aspect ratio in your settings if you can
Posted on Feb 16, 2009
Picture does not fill the screen
Check the main output voltage (B+) from its SMPS regulator side. If this voltage is lesser than normal, picture won't fill the entire screen. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts.
Mar 31, 2014 | RCA TruFlat 27F520T 27" TV
Poor picture does not fill viewing area {small in the center
Check its main power supply board's output voltages. It sounds that the output voltages comes out of it is too low that it should be.
May 25, 2013 | Sony KDL55EX500 55 in. HD-Ready TV
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
How do i change my pictures to fit my laptop screen
Please give more details on what you are trying to do.
If you want to take a picture and make it the total size of your screen as the background of your screen, then just right click on the picture and select Set as Desktop Background. If the size is not what you want then go into the display properties and select the Desktop tab and change the Position to be Stretch. Stretch will fill the whole screen with the picture. Tile will fill the whole screen with multiple little pictures. Center will put the picture in the middle of the screen.
To get to the display properties click Start/Control Panel and look for Display or Appearance and Personalization.
You can also get the display properties by Right Click on an open area of the desktop and select Properties.
Apr 28, 2012 | Computers & Internet
There is a black 2 1/2inch bar on leftside of screen how do i adjust is?
if your lucky it's just your H-center is off tilt. to check this Press the menu button on your monitor. scroll through the options till you see Horizontal-center option. select this setting and move the screen to the left. The entire screen should start shifting to the left and fill in the screen. now if you do this and you get a black bar on the right. Center the screen where you have the same amount of black on both sides of the screen. scroll through your menu till you see the H-size. increasing this will fill in the black area. Hope this helps.
Sep 13, 2009 | X2Gen MG19MY 19" LCD Monitor
Banjo Kazzoie
The main area of the game. This is where you’ll access all the levels by completing the jigsaws on the walls when you have enough Jiggies from previous levels. When you press a Grunty switch in the stages, the Jiggy will appear in this lair.
As you enter the lair, get the first Jiggy on the left, then go up the right hand tunnel and fill in the picture at the top to gain access to the first world.
Jul 15, 2008 | Ubi Soft Entertainment Rayman 2: The Great...
Page printing
If the dimensions of the picture your trying to print are not in a 2:3 ratio (same ratio as 4 x 6), it cannot fill the entire 4 x 6 area without distorting the image, i.e., you would have to "stretch" the dimension which has white margins right now to fill the paper. To print an undistorted borderless image, you will have to "crop" the picture so that the remaining dimensions are in a 2:3 ratio.
May 27, 2008 | Canon PIXMA iP5000 InkJet Photo Printer
The screen picture bulges inwardly on the right and the left
you have defective horizontal linearity! replace the capacitor at the hot side mostly 160uf 180V or 160uf 160V.
Oct 02, 2007 | Recoton Advent Advent Q2035A 20" TV
Dark screen at top of TV picture
If this is a projection set then a center channel speaker sitting on top would have no effect.
Feb 03, 2007 | Toshiba 46H84 46" Rear Projection...
Washing machine doesn't respond to the low, medium or high water settings and keeps filling. Spin and drain cycle works. Won't stop filling and doesn't go into the wash cycle.
My GE WSM2780DAWW stack set dryer and washer was encountering the same problem (water kept filling up not stopping). I saw this page, but the SOLUTION described didn't really draw a picture for me.
Here's how I fixed the leaking washer. Sitting in front of the washer I removed two small screws on the bottom left and right of the front panel. Then sliding the front panel DOWN, it comes off. This allows a view into the machine. Around the LEFT side of the wash basin you will find a white tube. This tube is about the diameter of a pencil. My tube was not attached, and when the wash basin filled up past the point where it should stop, water came out. Reaching around the side of the wash basin with my left hand I could feel where the white tube was supposed to connect properly. Then I attached the white tube. This fixed the problem.
I left the front panel off for a day to make sure it didn't continue to leak and also for the area to dry out.
Jun 17, 2006 | GE WSM2780DWW Unitized Spacemaker Washer...
Philips 26PW6341 26" TV Logo
55 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
