Want to use S-video cable from my vcr to the tv. set-up tells me
I can only use the standard white cable. want to get the better quality picture using the S-video cable instead of the regular white cable. MODEL LC195SL9 A
thank you,
Mark Miller
You can get a free 25ft s-video cable today at <a rel='nofollow' href="TigZoo.comhttp://www.tigzoo.com/">TigZoo.com</a>. That may not solve your problem, but it's a component you need. If you don't have an s-video input to the tv or output from the other device, then it will be difficult to hold the quality through any down conversion to composite.
Posted on Dec 02, 2008
The player does play the dvd's and everything but the picture wont show up in my television. I already connected the RCA connectors into the television and the player but still no picture. Please Help.
Assuming you used the standard YELLOW-WHITE-RED RCA cable, between the unit and the TV, the colours of each of the plugs should match both the outputs on the rear of the unit and the respective inputs at the rear of the TV. The TV must also be on an AV input 'channel' to receive the connected unit. (for example, AV1 or VIDEO 1)
Try changing the RCA cables - just in case the ones you currently have are defective in some way.
Being a combo unit, there should be a DVD-VCR common output on the rear - using RCA cable, the YELLOW is video, the WHITE is left channel, the RED is right - these MUST match the input on the TV, and the TV AV input must be selected in order to view the pictures and audio from the unit. To enjoy both VCR and DVD, using the RCA connection, the common output on the rear of the combo unit is recommended.
Better quality video is possible using S-Video cable (available from electronics stores such as Radio Shack etc. but this does not provide audio; you would still require RCA RED-WHITE cable for that, and your TV may not have S-Video input). Your TV may have a TV/AV button on the front - select the correct AV 'channel' with that if necessary.
It makes sense to check everything twice before assuming anything is broken.
Jun 28, 2011 | RCA DRC8300N DVD Recorder/VCR
Philips tv set 29PT6231/79R. Good picture and sound feeding through VCR machine. How do I get it to play video tapes? My previous tv played through channel 7.
I'd suggest connecting the VCR to one of the composite inputs on the set (Yellow, Red and White cable). Select that composite input, then tell the VCR to play. This will you give a slightly better quality picture than going through the tuner as you did on your old TV set.
May 02, 2011 | Philips Televison & Video
When I plug in my DVD using the Red, White, Yellow cables the picture is fuzzy. The female sockets on the back of the TV are loose. How can I tighten them
You can usually use some pliers to squeeze the outside of the RCA connector (when it is disconnected from your TV) to give it a tighter fit BUT, few things to keep in mind,
  • All cables are not equal, a higher quality RCA cables may give improved results. I wouldn't bother with gigantic gold plated $50 cables or anything like that, just a bit thicker gauge wire a better connectors than what comes with a DVD player.
  • Using the "red/white/yellow" connections as you stated is what is called Composite Video. The white/red is left/right audio, while the yellow is the video signal. A better picture will be had if you use a higher quality signal such as the Component Video (red/green/blue connectors) out (if your TV is supported, or of coarse HDMI)
I hope this helps
Mar 06, 2011 | Zenith Z35H86R/M TV
How do I connect a Xbox 360 Console without HDMI to a Grundig LED-tv 40" to get the best picture?
If your tv has a composite wiring inputs (5 wire red,white,yellow,blue,green) use them it will provide a better picture picture quality than the standard rca a/v cable (red,white,yellow) After you connect the composite cable from console to tv go into system/console settings/tv picture quality and adjust settings there
Jan 12, 2011 | Video Game Consoles & Games
Sony rdr vx410 dvd player playing some dvds in black and white
  • DVD's are standard definition video sources. Number of lines output is 576 lines, whereas your HD TV set has 720 or 1080 lines. This difference may result in a poorer image. However some DVD players are able to “upscale” picture to obtain a very good picture. Check if your DVD player has the following connectors: YUV, DVI or HDMI. For more information, refer to the instruction manual of your DVD player.
  • Some HDMI or DVI featured DVD players also have an internal processor that can upscale pictures from a DVD to 720 or 1080 lines to provide an excellent picture from a standard definition disc to your HD TV set. Those settings are available from the setup menu of your DVD player. Please refer to the instruction manual of your DVD player.
  • If your DVD player does not have those connectors and only has a SCART connector, or S-VIDEO, or composite, there is not much to do to improve the picture quality. Just make sure that you are not using the cheapest cables and that the picture settings of your TV set are correctly adjusted.
  • Some high end TV sets have a picture improvement engine that can soften a noisy image. Make sure that it is activated from the setup menu of your TV set. Please refer to the instruction manual of your TV set.
  • If people and objects have weird white outlines around them. This may suggest that your TV sharpness is set too high. Make the correct sharpness adjustments from the setup menu of your TV set.
  • Make sure you use good quality cables and that your cables are not too long (less than 5 meters long).
Jun 15, 2009 | Sony RDR-VX420 DVD Recorder/VCR
Sharp Aquos LC-37D44U only shows B&W images from DVD & VHS source
First thing- why not just use the HDMI instead of standard def cables in the first place? Anyway- If the RCA-video (yellow composite cable) is not producing color, 1 of 2 things may be wrong: 1. You accidentally connected the a/v cables [yellow white and red] to [red green and blue] component inputs or vice versa, or.. 2. Your TV or DVD player is somehow set to the wrong video format. Check the DVD settings for video output format and video connector type. Format should be NTSC, and connector should be composite and/or s-video for the cables you're using.
If this is only happening when connecting the DVD player through the VCR, then check to make sure the same cables connecting the DVD player to the the VCR are also connected to the TV from the VCR.
BTW- if this is just to record DVDs to a VCR, I'll tell you it's not worth it. If your DVD player has an HDMI port, your picture quality will be so much better than if you're watching a VCR copy of one. Your new HDTV will look worse than an old standard def TV. Worse; I'm not kidding.
I hope some of this helps.
Jun 01, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Component Cable
Component video quality is better then Composite Video (yellow wire)
Of course component cable hook up will improve picture quality.
Feb 04, 2009 | JVC HR-XV1 DVD Player/VCR
Rca cables in place of component cables
Typically the Yellow is video and Red and White are Sound. So only one is for video two are for sound normally.
Basically they are about the same thing, the only difference there will be cables are made different. Some cables are better than others at transferring signals be they video or sound. So quality might be affected slightly.
Jan 06, 2009 | Sony RDR-VX515 DVD Recorder/VCR
Have cable box ,also have vcr,and dvdplayer how to hook them all up
depends on what your tv is ill give u basic coax out from wall into cable box out from cable into vcr out from vcr into tv for better picture use red white and yellow from vcr to tv. for dvd use red white yellow out from dvd in to tv for better picture if tv has use s-video instead of yellow cable. for even better use red green blue(component)along with white and red for audio. if tv is hd and if dvd has it the very best is hdmi. you will only need one cable from dvd to tv instead of three or five sounds like a lot i know but take one step at a time youll get it
Sep 10, 2008 | Televison & Video
Hitachi VCR and Phillips Magnavox TV
Mentor, sounds like it`s wired incorrectly or your using RCA cables (yellow, red, white ends) out of the vcr into the tv, If your using RCA cables the tv`s "input" (on the remote) has to be switched to "video input 1 or 2" etc to see the vcr tape. If you want to see the vcr`s picture on channel 3/4 you have to tell me if your using a cable or sattelite box and then I can tell you how to wire it with the coax cable, let me know, BMW Rider
Feb 07, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
