Question about Sony Mavica MVC-FD90 Digital Camera
Trying to find out what code c:13:01
When floppy disc is inserted, the format error flashes code c:13:01
The problem has nothing to do with the type or quality of the formatting. It is directly related to the disk drive malignment pandemic of Sony Mavica cameras. It seems simple enough to fix, since I fixed my own. You need to unscrew and remove all the small black screws which go around the seam of the camera body (my model was a MVC FD90) Look for little black arrows indicating the screw locations (you need a precision philips screwdriver which can be purchased at the Home Depot for $5.00 under Husky brand name). After removing all screws, try the camera now and see if it works. If it does, then reinstall only 2 screws in any of the holes that appear perfectly aligned with the camera body (hole lines up perfectly between cover holes and camera body holes). Then try again to make sure it still works. If it still doesn't work, then carefully remove camera cover with caution not to damage wire ribbon connection both halves of camera body. Then simply reinstall top with bottom of camera halves. Next,install those 2 screws previously mentioned. Camera should work fine at that point, and floppy disks will now operate when inserted without error message or other malfunctions associated with drive misalignment.
jwassmer@ptd.net
Posted on Jan 11, 2010
  • 31 Answers
Try reformatting the disk in your computer before using it in the camera. Not a quick format, right click, format, start, thats all. Dont even give it a volume name or anything.
Posted on Jan 12, 2009
3 Suggested Answers
  • 164 Answers
SOURCE: when a floppy disc is inserted it flashes disk
The floppy driver has an internal switch that detects when the floppy disk is protected or not.
It is likely such switch is damaged.
It is necessary to open the camera and the floppy drive to fix it.
If you have experience and skills in fixing electronic devices, or want to try it, then you can try its repair.
The alternative is to pay to have repaired, but is more likely that the quote you will receive is to replace the whole floppy drive, which costs around $40.00 plus the repair labor.
Regards,
Posted on Jul 25, 2009
  • 66 Answers
SOURCE: I use a 3.5
You need to format your discs in the camera. Not in any other camera. and certainly not in a PC. Some cameras do not like some discs. Have you changed the make you use?
Posted on Oct 10, 2009
Noy reading drive A:.floppy disc is new.it says please insert disk in drive a:
Have you tried to format the floppy disc first?
If the disc is new it needs to be formatted.
Does the LED light up when accessing the disk in the drive?
Sep 01, 2010 | Computers & Internet
I use a 3.5" floppy disc and now I keep getting a "format error" when I insert a disc even though it has been formatted. Brad
Oct 10, 2009 | Sony Cameras
Panasonic JU- 257A686
The operating system you are using is pretty old....DOS uses commands that are typed without graphic user interface. It is probable that the drive is dysfuntional because of age/fatigue. You need to use newer technology. You can insert the same disc in a drive that is in a windows environment e.g Winows 95, 98 or XP. This disc will definitely be more expensive than your old dos-run drive, but am sure you will have a lot less stress. better still when you get this copy all your information on the system and use a better newer storage device like a flash drive, CD/DVD.....they are much better in terms of capacity and functionality.
Best
Sep 01, 2009 | Panasonic JU 257 (JU257A827P) Internal...
When a floppy disc is inserted it flashes disk
Regards,
Jul 08, 2009 | Sony Mavica MVC-FD100 Digital Camera
DISC ERROR
This means the the floppy disk drive has dirty the reader/recorder heads, or the heads are misaligned, or the floppy has a mechanical problem during the reading process.
You can start in blowing compressed air inside the floppy disk.
If it does not work, then the floppy drive will need to be serviced or replaced.
Best regards,
May 29, 2009 | Sony Mavica MVC-FD73 Digital Camera
FORMAT ERROR
You may have a bad floppy... Just like floppy drives in PCs sony floppys do go out. If you search around as I did (sorry don't remeber the link) you can find diagrams on how to replace the floppy and they are available for sale! I think we found some for $25 per. Good hunting!
Dec 26, 2007 | Sony Mavica MVC-FD200 Digital Camera
Looking for advise & help....................
Replace the floppy Disk, we can supply this Disk.
Nov 26, 2006 | Sony Mavica MVC-FD75 Digital Camera
Sony Mavica MVC-73
This is an early floppy drive model yes? Drive error could refer to corrupt floppy disc or a failure of the drive. Check the disc angle first - new disk formatted to camera. If it is not that - then buy another camera A repair I guess will not be an option -but checkout Sony first.
Aug 28, 2006 | Sony Mavica MVC-FD73 Digital Camera
Format error on a sony digital mvc-fd100
If the disks you are using are new, there is always a possibilty you got a bad batch or you got some that were not pre-formatted, or were formatted for an apple computer. I assume that there is some way to format a floppy disk with the camera. Try to do that and then see if the floppy is recognized.
Sep 08, 2005 | Sony Mavica MVC-FD100 Digital Camera
Sony Mavica MVC-FD90 Digital Camera Logo
286 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
