Question about Moen Home
Moen shower faucet problem
I installed a new Moen faucet (single turn for hot and cold) it comes with two white plastic pieces that fit on the valve but the handle doesn't seem to line up and the stainless steel screw isn't long enough. I tried every way possible but it still wont go on. Help
  • 24 Answers
I need to ask a few questions to solve your problem.
What Model Shower body is it?
How big is the white plastic piece?
If it is about 6 inches around (just smaller than the face plate) and you are installing this shower body in a preexisting tub/shower, this piece can be discarded. It is a guide that is used so the tile contractor knows how much room is needed to service the valve once it is installed.
If this is not the case, just post with a few details and I'll modify my response.
Posted on Nov 24, 2008
We recently installed a Moen single handle faucet in a refinished shower after having a plumber replumb the front of our house. Handle appears to be properly installed. Now there is no hot water or even...
u need to adjust the scald protector all single handle units are shipped in cold position for safety reasons if have paper work for handle it explains how to adjust if not unscrew handle and remove on handle / valve stem will see a red and a blue plastic clips pull back clips and turn slightly and push back do this till desired hot and cold setting are to your liking replace handle and your done
Dec 17, 2010 | Moen & One Handle Tub & Shower Faucet
Please Help! I installed 3 Moen Banbury single handle faucet/shower units. Water will not flow from either the hot or cold handle position from any of the units. I pulled a feeder pipe (pex) off each one...
were there any thread protectors inside the hot and cold inlets? sometimes they put Styrofoam pieces inside to keep debris out of the inlets and outlets. inspect inside of valve body through inlet holes thoroughly
Sep 16, 2010 | Moen & One Handle Tub & Shower Faucet
HOT AND COLD REVERSED MOEN & ONE HANDLE TUB
This is a very simple fix. NOTE: This is for a Posi-temp model only!! First turn off the house water. Relieve the water pressure at a nearby sink. Then remove the handle from the faucet. Remove the black plastic piece, then the two white plastic pieces (these control how hot the water gets by controlling how far the handle turns), then the metal cover over the center piece of the valve. Once these are out of the way, there is a small metal clip that you can see that holds the cartridge in place sitting in a **** on the top of the center piece. Remove this carefully with a small straight edge screwdriver, taking care not to lose it. Then with a small pair of pliers, pulling on the center of the cartridge, pull straight out. Once the cartridge is completely out, turn it counter clock wise, 180 degrees and then reverse the process. The hot/cold will be in proper location now.
Now for an older style, simply take the handle off, turn the center portion of the cartridge 180 degrees counter clock wise and return the handle. Hot/cold will now be in their proper locations.
Good luck.
Aug 26, 2010 | Moen & One Handle Tub & Shower Faucet
No hot water on Moen single handle shower faucet. cold ok and shut off is fine
do you have hot water elsewhere? if not, might be that your water heater is not heating.
if you do have hot water elsewhere, did you let the faucet run for a minute or 2.
did you have hot water before? is this a new house? new valve?
need a little more detail.
on posi temp valves, if there were no water coming out of the hot side of the valve, the valve will not operate.
Aug 12, 2010 | Moen 1 Handle Lever Shower Faucet With...
I just put in a Moen single, chrome handle shower faucet in my hall bath. Got it all together and the hot water is not comming out. Cold water is fine, but, when i turn the handle to the position where the...
If this is a Moen posi temp valve you may need to adjust the temperature limit stop. It is located under the handle. Usualy a plastic peice with grooves in it so it fits in another peice in the valve. If I remember right you pull this peice out and turn it counter clockwise to get more hot water. Do this in small increments and reassemble and test. I hope this helps.
May 25, 2010 | Moen Posi-Temp Single HandleTub And Shower...
When you turn to hot it doesn't come out. Cold does.
Assuming that you have hot water at other faucets the problem could be a varnish buildup in the cartridge. After shutting off the hot and cold water either by turning off the main or at the faucet stops (if equipped), remove the cartridge and soak it in white vinegar to break up the varnish. You can clean it up with an old toothbrush and make sure that it is working. It should rattle when you shake it. new cartridges are not very expensive so you can just buy a replacement at any home center as well. If you are the original owner of the faucet Moen will send you a free replacement cartridge if you call them.
May 24, 2010 | Moen 3175 Legend One Handle Shower Faucet...
& One Handle Tub & Shower Faucet : i have a moen shower faucet and i get not hot wate...
these valves can be adjusted by removing the handle and adjusting the white gear that regulates the hot and cold that come out, try going more to one way if it gets colder then go the other way.
May 16, 2010 | Moen & One Handle Tub & Shower Faucet
My(installed today) moen single handle shower valve (82910CBN) is only producing cold OR hot water. It is not mixing. What should I do to fix this?
if u still have instructions it will explain how to adjust the water -in the handle are a red and blue plastic tabs that are adjustable pull back and turn to adjust --this is the anti-scold--till u are satisfied
Nov 03, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Moen Single Handle Shower Faucet-turn on get cold, little hot
You can try to rotate the first plastic ring to the left of center a few teeth, this will let the handle advance alittle more to the hot side.
Oct 09, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Home Logo
362 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
