Question about Motorola Mobility RAZR V3
Phone goes off while talking
Even when the phone shows "Fully charged" the moment I get a call, within a second or two of me answering the phone shuts itself down.
  • 32 Answers
The solution to these change the battery
Posted on Nov 20, 2008
My H700 Motorola Bluetooth does not go to pairing mode by steadily lit in purple, even after turning off the phone it is currently paired with and after I close and reopen the H700 Motorola Bluetooth ...
First off, you want to have the H700 fully charged up and it's probably good to have the phone fully charged up too. Now turn off the H700 (the ring around the talk button should not be flashing blue every few seconds) then push the talk button for about five seconds, until the ring around it displays a purple color. Immediately let go of the button and flip open the tiny microphone extension. Now it's in pairing mode and you can leave it while you fiddle with the phone to finish the process
May 11, 2010 | Cell Phones
LG VU,battery indicator shows fully charged but I can only talk a couple of minutes before phone shuts off and shows dead battery? Just a dead battery or something else going on here?
I believe the cells of your battery is very weak that is why it can no longer hold charges for long.
All you need to do is to get a new battery on your phone and makesure you charge the new battery to its maximum capacity before you start making use of it.
This will help preserve the life span of the battery and make it last longer.
Take care.
May 02, 2010 | LG Vu CU920 Cellular Phone
Battery
Your battery is gone, you will need to replace a new battery because the old battery is at it age. When you get a new battery, charge it 24 hour to fully charge it before you use, it is very crucial to maintaince the life of battery
Jul 20, 2009 | Apple iPhone Smartphone
My iphone 3g won't charge more than 10%....
it has corrosion in the charging hole or insde where the battery charging slots are
Jul 12, 2009 | Apple iPhone Smartphone
Battery fully charged but phone dies within a minute
A friend that worked for GTE advised me some yrs ago to do this and I have NOT had a problem with another battery since
when you get any new Battery charge it plugged in to the ac AND phone jack for a minimum of 24 hrs without using it.
all batteries have some memory and deminish power over time but if it was NOT fully charged to begin with as a yr goes by so does the battery life. hope this works,
Apr 16, 2009 | Panasonic KX-TG5438 5.8 GHz Cordless Phone
Doro 5065R +3 not working after replaced battery
I have replace my doro batteries with Duracell rechargeables, just make sure you fully charge them before you put them in the handset.  If you find after a time that the charge goes again, charge them again (in the charger you buy when you buy the batteries)! Hope this helps.  PS, do you know how to turn the answering machine on?
May 06, 2008 | Doro 730R Cordless Phone
UNIDEN 5.8 GHZ CORDLESS PHONES
Registering Handsets to the Base
Whichever handset you choose to charge in the base is automatically
registered to the base. Any additional handsets must also be registered to
the base before you can use them.
Be sure both handsets are fully charged.
One at a time, place each handset in the base. The charge/in use LED on
the base begins to flash, indicating the base is registering the handset.
Wait for at least five seconds, then pick up the handset and press
[talk/flash]. If the display shows TALK, the handset is registered. If not,
place the handset in the base to try again.
Press [end] and continue with the next handset.
Note:
Once both handsets are registered, it doesn’t matter which
handset is placed in the base or the charger.
When you charge the handsets, Caller
ID summary screen and the name of
the handset appears.
This can be find from uniden website.
http://www.uniden.com/pdf/DXAI4588-2om.pdf
Oct 17, 2007 | Uniden TRU8885-3HS Digital Cordless Phone
Phone loses connection after few minutes
I looked up the battery specs for your phone. They are 3 X 200mah= 600mah battery packs. They should last 8 hrs talk time with the headsets. This style of battery pack in my experience only last about 1 1/2years and sometimes longer and "sometimes" shorter...much shorter. I bet you never had problems when you first got them. Basicly this "battery design arrangment" goes back many years before newer battery technlogy was developed. But designers still insist on using them even today. They are cheap to make. ****Time to replace them with new ones.**** Make sure you follow the mfgs charging instructions: "After battery installation, place the handsets in their base unit or charger and allow to charge for 16 hours before use. You can keep the battery charged by returning the handsets to their base unit or charger after each use. When the battery is fully depleted, a recharge takes about 12 hours. Average talk time on a fully charged battery is about eight hours depending on environmental conditions, standby time is approximately four days." Good luck
Jul 19, 2007 | AT&T E5640 Phone
Motorola Mobility RAZR V3 Logo
51 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
