Question about Kenmore Oasis HE 27082 Top Load Washer
Ld code We have had our Oasis for 8 months. Apart from a broken hinge on the lid, it has worked fine. Now, everytime we try to wash a load, we get the Ld code (water is taking too long to drain from the tub). You can hear the water barely trickling out and then it stops. The hose between the drain hose and pump collapses on itself. We've discovered that if we unhook the hose and blow really hard 5-10 times, it will start working again and drain. It's a huge pain. We were going to call for service, but are afraid one of our kids left something in their pocket that caused this and we will be responsible for the bill. Any suggestions?
    President:
  • 878 Answers
Rod, there a two pumps on this model, drain and recirculation. The back panel is fairly easy to remove. Once the back panel is removed the drain pump will be on the left looking at it from the back. You can remove the hoses to the pump and check to see if any thing is caught in the hoses or the impeller itself. Careful the edges on the panel can be sharp. It's ok to tip the washer forward so it will be easier to work on. Then again, you could call for warranty service. If the service man is a half way decent cat, he won't charge you. Catriver..post back
Posted on Dec 15, 2006
How do i fix the Ld code on a whirlpool cabrio top load washer WTW6200SW2?
Troubleshooting Cabrio, Bravos, & Oasis Washer Problems Cabrio, Bravos, Oasis Washing Machine Overview
Washer Components
Diagnostic Mode & Tests ' Tips & Tricks Error Codes LF ' Ld ' uL ' oL ' Sd ' lid ' Po ' HC ' dL ' dU ' F1 ' F2 ' F30 ' F32 ' F40 ' F41 ' F50 ' F51 'F52 ' F53 ' F54 ' F70 ' F71 ' F72 ' F80 ' F81 ' F82 ' F83 ' F84 ' F85Always disconnect the washing machine's power supply before working on the appliance!Washing Machine Models That ApplyWhirlpool Cabrio Washing Machines
WTW6200SW0, WTW6200SW1, WTW6200SW2, WTW6200SW3, WTW6200VW0, WTW6200VW1, WTW6300SB0, WTW6300SB1, WTW6300SB2, WTW6300SG0, WTW6300SG1, WTW6300SG2, WTW6300SW0, WTW6300SW1, WTW6300SW2, WTW6300WW0, WTW6340WW0, WTW6400SW0, WTW6400SW1, WTW6400SW2, WTW6400SW3, WTW6500WW1, WTW6600SB0, WTW6600SB1, WTW6600SB2, WTW6600SB3, WTW6600SG0, WTW6600SG1, WTW6600SG2, WTW6600SG3, WTW6600SW0, WTW6600SW1, WTW6600SW2, WTW6600SW3, WTW6700TU1, WTW6700TU2, WTW6700TW0, WTW6700TW1, WTW6700TW2, WTW6800WB1, WTW6800WL1, WTW6800WW1 WTW7300XW0, WTW7340XW0, WTW7600XW0, WTW7800XW0
Maytag Bravos Washing Machines
MTW6300TQ0, MTW6300TQ1, MTW6400TQ0, MTW6500TQ0, MTW6600TB0, MTW6600TB1, MTW6600TQ0, MTW6600TQ1, MTW6700TQ0, MTW6700TQ1, MVWB300WQ0, MVWB300WQ1, MVWB400VQ0, MVWB450WQ0, MVWB450WQ1, MVWB700VQ0, MVWB750WB0, MVWB750WB1, MVWB750WL0, MVWB750WL1, MVWB750WQ0, MVWB750WQ1, MVWB750WR0, MVWB750WR1, MVWB800VB0, MVWB800VQ0, MVWB800VU0, MVWB850WB0, MVWB850WB1, MVWB850WL0, MVWB850WL1, MVWB850WQ0, MVWB850WQ1, MVWB850WR0, MVWB850WR1
Kenmore Oasis Washing Machines
110.27092603, 110.27092602, 110.27092601, 110.27092600, 110.27087605, 110.27087604, 110.27087603, 110.27087602, 110.27087601, 110.27087600, 110.27086605, 110.27086604, 110.27086603, 110.27086602, 110.27086601, 110.27082605, 110.27082604, 110.27082603, 110.27082602, 110.27082601, 110.27082600, 110.27072604, 110.27072603, 110.27072602, 110.27072601, 110.27072600, 110.27062604, 110.27062603, 110.27062602, 110.27062601, 110.27062600, 110.27052602, 110.27052600, 110.27042603, 110.27042602, 110.27042601, 110.27042600, 110.27032603, 110.27032602, 110.27032601, 110.27032600
NOTE: For All Error Codes
First press PAUSE/CANCEL once to clear the error code.
If code appears again put it through an automatic diagnostic cycle while you enjoy a nice soothing cup of tea. (Watch The Cabrio, Bravos, Oasis Diagnostics Video) This will reveal any stored error codes. Then you will be able to better use the repair guide to fix the major malfunction. Now put the tea down and get to work!
flood stop water supply hoses that may have closed internally?Is the drain hose sticking too far into your home's drain pipe (siphoning)?
Is the pressure transducer hose kinked, disconnected, or punctured?
Back to Top
Press PAUSE/CANCEL to clear display. pressure transducer hose kinked, disconnected, or punctured?
Press PAUSE/CANCEL to clear display.Washer Diagnostic Modes and Tests Washer Diagnostic Modes and Tests Washer Diagnostic Modes and Tests "Po" Pump Out (Lid Opened) Po flashes when the lid of the washing machine has been left open for more than 10 minutes. Close the lid to stop the drain pump.
"HC" Hot & Cold Hoses Switched This code will appear at the end of the wash cycle to indicate that the hot and cold-water inlet hoses are reversed.
"dL" Door/Lid Cannot Lock (Stored Error Codes F80, F82, F84, F85) Indicates the lid cannot lock.
Check for items caught in the lid keeping it from closing completely.
Is soap, fabric softener, or anything else keeping the lock from extending into the lid?
The control detects an open lid switch, or cannot determine if the lid is locked. Test the lid lock connection to the washer's control board and lid lock resistance levels.
Press PAUSE/CANCEL once to clear the code. "Ld" Washer is taking too long to drain water from the washtub
(Stored Error Code F32) Check the following:
Is the drain hose or pump clogged?
Is the drain hose higher than 96" to reach the drainpipe?
Is the Drain Pump Running?
Jun 07, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore 27042 Elite Oasis. When it goes to spin mode you will get a code LD. Open the lid and move the tub up and a few times then restart the spin cycle and then it will work.
Seems that the load on the motor during the spin causes more strain and so it cut off with a error code. Now when you move it will get free and so causes the spindle to free.
Now after wash check the spindle ,the bearings the motor drive, use some lubrication, use some spray to degrease( WD40) if this is seen to be tight.
If not reassmeble this section to clear the fault.
check for tips on how to remove from:
http://www.espares.co.uk/advice/washing-machines/a/7
Aug 08, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis Washer won't drain. "Ld" code during
Hi
Error code LD means long drain. This error appears when the washer takes more than 5 minutes to pump out the water till point where pressure switch resets. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. Hope this helps... Please post back for more information.
Daniel
Nov 26, 2010 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Kenmore Oasis is beeping with an error code of Ld
LD code is long drain,one of two things the drain pump is frozen and need to be replaced or there is somthing in the pump.Pull the washer away from the wall a bit and get a bunch of towels.Lean the washer back against the wall towards the middle in the back you will see the pump take it apart and find the clog.
Apr 10, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Washer goes thru wash cycle then goes to ld code and wont spin. Hit stop /start numerous times it will start to spin then quit each time and then finally go into the spin cycle.
I'm guessing ld stands for lid. A lost of washers have no problem washing with the lid open but refuse to spin. You need to make sure the lid is engaging the lid switch properly, whether the switch is visible around the lid or attached to one of the hinges. If you can't find the switch outside the machine you may need to pop the control panel. If there are no screws or plastic around or on back of it a common way to gain access is to stick a putty knife in the seam carefully to release the clips holding the assemblies together.
Oct 13, 2009 | Kenmore Oasis HE 27087
I have an Oasis HE - top load. The lid no longer
looking at the picture on sears site if the hinge arm not broken you'll need part# 8580114 9.06
Aug 19, 2009 | Kenmore Washing Machines
Oasis washer has Ld CODE runs will not drain.
LD code is long drain one of 2 things the drain pump is frozen and need to be replaced or there is somthing in the pump. Pull the washer a way from the wall a bit and get a bunch of towels. Lean the washer back against the wall towards the middle in the back you will see the pump take it apart and find the clog.
it can be assessed through the bottom.
May 03, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Stops between rinse and spin cycles giving a ld code..
ld sure sounds like lid switch problems. Suprised to see this so soon, but I did see one come apart on a fairly new Whirlpool. Luckily, it should be easy to check. Unplug the machine first.
Apr 29, 2009 | Washing Machines
Kenmore oasis he, ld flashing at 8min.
Sounds like a bad lid switch. Many times you can test these by using a small jumper wire to connect the two wires on the switch it's self.
Jul 18, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Lid Display lit when starting wash cycle
LID code could mean that the door lid switch is not pressed. try to shut the door completely or the lid switch could have been broken. or the plastic that should press the lid switch could have been broken also. it is attached to the door i hope i was able to help.
Jun 21, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
141 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
