Question about Whirlpool LER4634J Electric Dryer
Hotpoint aquerius dryer ,no heat
Everythin esle working just no heatm someone says possible
thermestat problem if so where our they in the machine thankyou
  • Whirlpool Master
  • 3,463 Answers
Hi.
Heater and thermostats located at rthe re ar of the m/c.
You need to remove the panel at the left bottom side to expose the parts. You should replace both thermostats if you conclude this is the problem.
Posted on Nov 20, 2008
Aquarius 1200 washer/dryer WD62. Why isn't it washing/rinsing clothes properly?
If your washer /dryer is correctly connected to hot and cold water supplies, replacing the fill valve would be a good place to start.
Mar 26, 2016 | Hotpoint Washing Machines
Where is the dryer fuse,located on an aquarius washer/dryer.the machine washes perfectly,the dryer goes through all the motions,but there is no heat.i have had the machine for 5 years,but this is only the...
-There is not fuse. But there are thermal fuse (Possibly 3)
-Disconnect main power and open back panel cover. You'll see it.
-Possibly heater element burn out.
Good Luck
Mai
Oct 09, 2013 | Hotpoint Aquarius WD640 Front Load...
My dryer wont provide heat, i have replaced the thermal switch and the thermestat.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 28, 2011 | Kenmore Dryers
My ctdoo hotpoint dryer has no heat machine works but no heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 26, 2010 | Hotpoint NWXR473GV Dryer
Door will not open door light just flashing on and off
washer not spining mini load button flashing on/of buton flashing
Apr 27, 2010 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wd420 washer dryer dryer is not heating up
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Mar 07, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint Dryer Heat stoped working
Loook inside door an get me the model number. The heat thermistat and the high limit switch will possibly need replaced. Enter the model and part numbers in the search feature on my site below. We offer free help and assiatance also. Thanks, Sea Breeze seabreezehvac@yahoo.com
http://servicepartstec.blogspot.com/
Mar 29, 2009 | Hotpoint Dryers
Hotpoint vtd65 dryer good working but not drying cloth
You will find the heater and stats located behind the removable panel at rear of dryer, you will need a meter to test them for continuity. there are other possibilities for it not to heat, so do not assume it is a faulty heater.
Plz rate my solution.
Thankyou.
Jan 22, 2009 | Hotpoint TDC32 Electric Dryer
Heating elements will not heat
If you dryer is running but not heating then you may have one of the following problems.
Make sure you have 220-240 volts to the machine. If one leg of you breaker has kicked you will only be getting 110 volts this will cause the dryer to run and not heat. Simply kick the breaker off and back on to fix.
If you have enough voltage then you may have a bad thermostat, thermostats or heating element. I recommend you take your heating element off and look for broken lines.check continuity if possible. If the heater is good then go to the thermostats. Check continuity. Replace if you find a bad one. Good luck and I hope this helped. mca0824@aol.com
Apr 29, 2008 | Hotpoint NLL113EYWO Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
35 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
