Question about Krups Small Appliances Espresso Machine
I don't know how operate a small coffe machine
    President:
  • 2,992 Answers
You can usually find the owner's manual for a product online these days. I would suggest starting at the manufacturer's website. They almost always have a support link to click on. By following the link you'll find their download manuals area. If that doesn't work, the site should list a support phone number you can call and you can ask about getting the replacement manual.
If you'll provide the make and model of your machine, I'll see if I can search out a link for you.
Posted on Nov 22, 2008
Hello, i have a krups xp7220 and i have two problems with her.
A common place for a leak under the machine is the barista seal that goes in the bottom of the boiler around that eject rod. Barista seal part number is MS5002202, Seals on the tamping piston are MS5002040 (there can be 1 or 2 of these piston seals) If fixing the leaks does not fix error 6 then I expect it will end up being the distributor. Part number MS2A01500
Jun 17, 2017 | Krups Coffee Makers & Espresso Machines
How do I fix my coffe machine?
Contact the authorized service center.
Jan 07, 2016 | Krups Orchestro Dialog FNF2 Espresso...
I need the user manual
Dear friend: I bought mine in 1996 in Orlando. The user manual was so simple with some b/w pictures.
1.- Heat the water.
2.- Over one cup place the thin filter that match perfect and is the bigger one of two elements supplied.
3.- Over the thin filter place the coffe deposit the one that have small holes at the bottom.
4.- Fill the deposit it with coffe for one cup and fill over with hot water slowly from one cup trying not to overflow.
5.- Wait untill the water flows down and your cup of coffe is ready.
6.- For another cup repeat this procedure.
Is a bit long but you can enjoy a room coffe for two.
Its what my experience was. Excelent when you don't find where to boil a cup of water. Now mine machine burns suddenly the heater and I am trying to find the replacement part, but probably should be and adaptation of it.
Good luck. The manual is not much than what I told. Not much manufacturer info. A pitty for a well designed help machine.
Claudio.
Apr 03, 2013 | Franzus TJ-10 Coffee Maker
Just picked up a new Franzus TJ-10 Coffee Maker at a garage sale, but it has no instructions with it. Can you please tell me just how to operate it. Appreciatively, Vincent
1.- Heat the water.
Claudio.
Aug 07, 2011 | Franzus TJ-10 Coffee Maker
Very little water comes through...small drips...enough to get the grounds wet but not enough to make coffee.
mix half white vinegar and water together...then pour this solution in just as you would if you were making coffe....minus the coffe grounds of course... then run it through a cycle and then run clear water through again... and you will be good to go...do this once a month or so to keep it working great...
heatman101
Aug 22, 2010 | Krups Small Appliances Espresso Machine
Coffee is leaking onto burner and spilling onto counter, yet the carafe is not leaking. The problem seems to be coming from the drip
Does the coffee seem to be overflowing the coffe maker and the running down? If so the valve where the filter is placed is not working properly. When you place the coffee pot it actuates a small arm which inurn opens a valve at the base of the filter unit. If this is the case remove the unit and correct this unit. In speaking from past experience I know this happen to our coffe maker while the unit was apart being cleaned; it was just a matter of proper reassemble.
I hope this may have helped,
Tom
Sep 07, 2009 | DeLonghi Coffee Makers & Espresso Machines
Out of 10 cups of coffe maybe i get 4 cups
Try to make a cup of water (the) and see if you can make a full cup.
Try to take out the brewing unit (central unit) and wash it in warm water.
/Best regards
/Mirran
Jan 29, 2009 | Saeco Incanto Classic Espresso Machine
Small leak from the bottom right side (when looking at the machine) of my Saeco Incanto Sirius Espresso Machine when being operated. After two or three cups of coffe are made, need to move machine to the...
I have the same problem. To day I opened the Saeco and discovered that the unit attached to the knob at the right side of the machine must be replaced. Water came out in two places. I dont know where to buy this part.
Per
Oct 13, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Venezia
I was a Saeco tech in Italy were i come from and i do know pretty this machine since are one of my favorite.I like solid construction machine and easy to operate.This machine is very stable,durable,and work with basic element.
Back to your problem technically could be something very easy to fix or something require a little time to troubleshhoting the real issue.
This coffe maker need to be open to check the status and troubleshooting the issue.Don`t forget to unplug the power cord first all the time.
This one are the check need to be done.
Check thermostat....some coffe maker have overheat protection thermostat and if the coffe maker was without water for a while that thermostat could be in protection.Sometimes they have a red push in for re arm .Try to push the re arm button.Check the thermo fuse(most of the time inside a silicon tube and on the top of the boiler) and check the heater element
To check the heater element you need a voltmeter (no power is necessary)
Set the meter on ohm and check if you have continuity.If you have continuity the heater is good.Check also 1 element and stick the other probe on ground to make sure no short are present.
Pls don`t forget to rate your experience
Aug 17, 2008 | Saeco VIA Venezia
Krups Small Appliances Espresso Machine Logo
32 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
