Question about Moyer Diebel 24 in. 501HT Built-in Dishwasher
Hi, I have beenasked to install a MD 24 inch undercounter.
It looks like 501 HT, but spec. sheet has been wiped out.
It came from an auction, and has 110 volt plug. This strikes me as strange, because most hi-temp machines I have seen before are 220 volt. This one pops breaker instantly when switched on .
Is it likely that it has had a 110 plug installed by mistake
  • 1,462 Answers
Almost certainly
Posted on Nov 20, 2008
I'm having trouble getting any spark
Check there is 12 volts + terminal of coil , Check the coil HT cable resistance is within specs , remove the center Ht cable from the distributor , hold it a 1/4 inch from the engine block, have a helper engage the starter , a good spark should jump from the cable to the engine block. also check the spark plug Ht cables and renew if not to specs.
Dec 27, 2014 | Cars & Trucks
Install oven clips
OPeration and Spec sheet are on the bottom of this page clic on the "Manual and Guide TAB
Dec 23, 2014 | Verona 24" Gas Single Wall Oven Stainlees...
Kenmore 700 series Dryer shuts down after a few minutes in heated cycle, runs forever with no problem in Air Dry (no heat) mode, I disassembled the entire machine drum, motor, vents and removed every spec...
Brian, look inside your drum for some curved strips of metal that may be 6-8 inches in length. There may be two of them that run parallel to each other about half an inch apart. This is your moisture sensor. If you use dryer sheets like a lot of people do you may have an issue where there is a build up of residue from the dryer sheets on the sensors. Take some rubbing alcohol and some cotton balls or a rag and wipe down the sensor strips. If they come back blue in color there is build up on the strips. Keep wiping down until you no longer get any blue color. That build up can make the dryer think that the clothes are dry and shuts the dryer down. Hope this helps, I have done this on a couple of different dryers and it made a big difference.
Mar 18, 2014 | Kenmore Dryers
I have a 501 ht moyer diebel undercounter dish washer that doesnt drain all the way
Could be a clogged drain line, a failing pump or even the dishwasher not level
Jan 16, 2013 | Dishwashers
Model# 501 ht mb HHH message in both wash and rinse temp display at different intervals,extreamly hot. cant find manual, washer installed 2 yrs ago not 1 problem untill yoday
Possibly the booster thermostat needs replacing. Expansion of the water in booster enters the wash tank when boiling showing HHH on both displays.
Mar 22, 2011 | Moyer Diebel 24 in. 501HT Built-in...
My 501-ht doesn't dispense detergent?
Could be clogged hose or filter screen. Could be pump hose worn out. Check that the hose goes to the bottom of the detergent container. Could be detergent pump not operating. Could be timer switch not working or not adjusted properly.
Nov 30, 2010 | Moyer Diebel 24 in. 501HT Built-in...
I would like to purchase a Moyer Diebel U/C dishwasher for residential use. I have the option of purchasing a used dishwasher - it could be one of three models. Which one is the model he is trying to sell...
The way you mentioned the unit have a 4 ft. cord at the back seem like a 50l LT the best way to determent is open up the bottom plate and see whether there is a booster tank in the right hand side.
Hope this can help you.
Mar 12, 2010 | Moyer Diebel 24 in. 501HT Built-in...
1988 Ranger failed CA smog test (badly)
pull head off and grind the valves in,this should help reduce the levels ,also check the pistons and bores if ok or look it then rebuild and try it again
Jan 07, 2009 | 1988 Ford Ranger
Moyer Diebel 24 in. 501HT Built-in Dishwasher Logo
123 people viewed this question
Top Moyer Diebel Dishwashers Experts
Are you a Moyer Diebel Dishwasher Expert? Answer questions, earn points and help others
