Question about Kenmore 75962 Gas Dryer
I need to no how to light the pilot, the drier still run
I just don'nt know how to get to the wick of the pilot
How to relite the pilot on kenmore gas dryer
Posted on Dec 11, 2008
Kenmore 500 dryer
If you mean that it is not heating and stays cool, most likely the pilot sensing thermocouple needs replacing (if you have a gas drier with a pilot light) or the electronic ignition contacts need replacing (if you have a gas drier with electronic ignition). Not sure about an electric drier, but probably the heating element needs replacing, or the thermocouple sensor (most likely). None of these are very expensive.
Jul 23, 2014 | Kenmore Dryers
I need to know how to replace the wick and what size wick is required, I guessed a 95mm. The dial that controls the wick wont stay turned holding the wick up so i cant light the heater. would this be due...
It possibly could, if the wick is not installed properly. Also, the height mechanism (the control knob and the gears) may have lost it's tension and will need to replaced.
However, without knowing what brand/manufacturer and model number kerosene heater you have, there's not much more I can tell you.
May 12, 2011 | Heating & Cooling
Have kenmore dryer the pilot is out
it probably has a glow plug not a pilot, tun on the drier and watch for 15 seconds to see if a glow is visible, Not knowing the year or type of drier makes this hard to reply to, but if you do see no glow,, check the main fuse (thermo) at the rear of the unit and replace
Aug 02, 2010 | Kenmore Dryers
Gas dryer not heating up
it probably has a igniter, not a pilot light that lil hole is a check sight hole, close the door and set the drier to start , within a few seconds you should see a glow plug light up, if not,, check the main fuse in the back of the machine,, this is normally caused by a lack of flow for the drier vent and over heating
Aug 02, 2010 | Kenmore 63942 Dryer
Pilot goes out when valve is turned on
If it has a wick,then the wick is dry,or is not up enough,if it is not a wick type,then the thermocouple is bad.
Jan 14, 2010 | Reddy RCP80V Utility Heater
Where is the pilot light on Raypak versa pool heater, i need to light it manually?
In side the front on the lower right is a long 3/8" wide tube about 5 inches long...you'll need a special lighter with an extended wick.
May 18, 2009 | Raypak Free Hydraulic Lift Gate Delivery -...
Hw120m washer/drier
Check if the dryer is heating, if it is not heating check the following There's no heat
Oct 16, 2008 | Hoover H130E Front Load Washer
Gas drier
If the ignitor glows, and then goes out without lighting the gas, replace the gas valve coils. I'll need more information about your dryer to tell you how to do this. (model number.)
Mar 12, 2008 | Dryers
Frigidare laundry center model FLSG72GC
it doesn't have a pilot light has a glow bar and a safety solenoid probably the glow bar needs replacing its on the side of the burner tube there is an slanted acess panel under the drier door
Jan 27, 2008 | Dryers
Kenmore 75962 Gas Dryer Logo
87 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
