Question about Sony VPL PX31 Multimedia Projector
Sony LCD Projector - burned prisms
I have a Sony Data Projector, model VPL-PX31, (about 8 years old) and the brackground color has steadily faded from black to blue. I learned that this symptom is most likely caused by the prisms slowly getting burned by the internal UV light.
Is that true, and more important, is it repairable at a cost lower than purchasing a new similar product?
I have the same projector, but my problem is with red.
A replacement prism assembly is about $2k.
If you can get your hands on another projector for cheap, that's your only hope. You can swap out the blue lcd panel from your prism with someone else... it's a bit of mucking around, but worth it of you can.
Posted on Feb 27, 2009
Lcd lens for sony vpl-vw 11
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
May 11, 2014 | Sony NAVITAR REPLACEMENT LENS, Projector...
Image is bright but there is a slight issue - on the left hand side a purple line displays vertically. Anybody knows why is this fault appeared and how could it be solved.
There is three LCD in the projector red, green and blue. If green LCD make any fault mean line or dot or dots then screen show these line or dot in purple color:
If line is very straight and sharp edges then green LCD is faulty and need to be replaced.
If line is not straight and faded edges then some thing in LCD block so your projector need service
Feb 22, 2011 | Sony VPL PX40 Multimedia Projector
Sony VPL-HS50, any viewing (TV, DVD) a spread of blue appears on various parts of the screen, generally contained to the sides but from top to botom. Just recently a large yellow blotch appeared in the...
If this projector is an LCD (liquid crystal display), your LCD probably gone.This usually happens after a period of time with an LCD projector.Try cleaning the LCD or take it to your Sony dealer. yours faithfully Zkhan
Jan 30, 2010 | Sony VPL-HS51A / VPL-HS60 Multimedia...
How to fix yellow hue center bottom of picture.what causes this
Most often color distortion is due to the bulb wearing out. Projector bulbs often fade or distort colors before they actually burn out. The other thing you can try is to reset the projector to it's factory settings, which sometimes fixes color issues. It's usually an option in the "settings" area of the menu.
Jan 18, 2010 | Sony VPL PX40 Multimedia Projector
Sony BRAVIA VPL-AW15 LCD Projector power light
i have color bands running through the picture
Jan 17, 2010 | Sony BRAVIA VPL-AW15 LCD Projector
I have two Sony PX11 projectors, one with a bad (discolored prism). How can I pull the prism out to replace it?
it's not the prism. chancs are it's the light filter(s) on the lcd panels. the prism is just coated glass. the light filters determine the color. you need to take the top off, the main board off (unplugging the ribbon cables), and the lens off. the lcd panels anf the filters are attached to the prism. remove the filters, but do not remove the lcd panels!
Aug 14, 2009 | Sony VPL PX11 Multimedia Projector
Blue Haze on screen Sony cineza vpl-hs50 projector
Its your blue polarizer going bad. This happens over time due to the excessive heat generated in the projector. The main problem is that your projector has organic LCD panels that degrade over time and in turn degrades your blue polarizer. The same thing happened to my sanyo Z2. It took 5 years for it to show on my Sanyo because I only use the projector for sports and movies. not daily tv watching. In any case, it isnt worth it to spend the money ti fix it...jut put tat towrds a new projector. The latest crop of LCD projectors almost all use in-organic LCD panels that last much longer. Hope this helps.
Aug 03, 2009 | Sony VPL-HS51A / VPL-HS60 Multimedia...
Sony VPL PX31 Multimedia Projector Logo
697 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
