Question about Canon MultiPASS MP730 All-In-One InkJet Printer
MP 730 Show Wrong Cartridge in the display window.
I have not done anything different with the cartridges, so why is the message showing in the display. The printer will not print because of this problem. Please give me a few suggestions to fix this problem.
  • Anonymous Nov 28, 2008
    I have the same problem, just started yesterday.
  • Anonymous Dec 02, 2008
    where do I get the answer to the problem of "wrong cartridge"
Http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=9035
I went to canon and found the solution. It took a couple attempts, but it finally worked and I am up and running again. Under 10 minutes.
Posted on Nov 28, 2008
Mp 730 "Wrong Cartridge" have been using same cartridge w/o any problems
the cartrige has become faulty or the wire strip that connects to the cartrige holder is comming out or a wire in the strip is broke , a new cartrige would then do the same thing
Oct 18, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
My alarm beeping wrong cartridge and not doing anything
stavio sam nove ketride u cano mp 730 i dalje lampa treperi. sta treba da radim.
Feb 12, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
My canon mp 730 has an alarm lit and says wrong cartridge. I tried removing print head and cleaning with alcohol...no luck...put in a different cartridge...no luck. What else can I do
On Canon that error means the printhead is bad, nothing to do with the inks. The translation from Japanese to English made the error confusing. You need to buy a new printhead, the part number is on the side of the printhead and starts with QY6-
Jan 31, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
MP 780 displays error message "Wrong Cartridge" How do I fix and reset this error message,
Wrong cartridge on Canon means the printhead has gone bad, nothing to do with the inks. You just need a new printhead. The part number is on the side of the printhead and starts with QY6-
Jan 28, 2010 | Office Equipment & Supplies
Had toner life end message. Replaced toner and drum with oem,machine reset but now just making blank copies. Tried to print internal report that's blank too
To reset the sensor after installing a new toner cartridge follow these steps.
1. With unit powered On, open the front cover.
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press 1,0 .
5. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
6. Close cover and see if Toner Life End error message has gone.
Please note that this must be done with a new cartridge so the unit will see that there is toner in the cartridge.
Aug 01, 2009 | Brother IntelliFax-2820 Laser Fax
MP 730 Printer alert flashing "wrong cartridge"
I had the same problem. I removed the cartridges and then the printerhead. I cleaned the printerhead with a piece of cloth and then replaced it and then the cartridges. This seems to have fixed the "wrong cartridge" problem for now. I was told by a friend that if the problem persits, replacing the printerhead may be a more permanent solution, but no guarantee.
Mar 05, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
PIXMA MP780 "WRONG CARTRIDGE" MESSAGE?
Here is what I did and it now works just fine.I turned off the printer and unplugged the power cord, and unplugged it from my computer. I then removed all the ink cartriges and removed the print Head I got some rubbing alcohol put it on some toilet paper and wiped down the back and bottom of the print head.Plugged everything back in and It now works better then ever.
Feb 08, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
82 people viewed this question
old marine
old marine
