Question about ViewSonic E70fb (Black) 17 in.CRT Conventional Monitor
Monitor keeps turning off
I have a flat screen crt dell monitor and when i turn it on i hear it click on the light turns green for about 3 seconds and then it clicks again and turns yellow and doesnt come on...i checked the cables in other desktops and they are working fine...help
  • nec_eg_comp Mar 11, 2009
    ihave a philips monitor model 107mb when i switch it on i hear a click and
    the front led becomes green then after 2-3 seconds i hear another click
    no picture comes out on the screen and front led still green .
    when i open the back cover and press on f.b.t. or electrolytic capacitor
    i hear a click and picture comes out on the screen for a while until i release my hand then i hear another click and the picture go out.
    please help me fix this problem asap thanks a lot
    *and if possible send me the schematic diagram of this model
  • rickpulsin Apr 26, 2009
    have the same issue....17" dell lcd....monitor keeps turning blank but power green light stays on. tried on another pc and same issue so its the monitor...what can i do?
Ther might be a problem with your grphics card or the sockit on the end of the lead
Posted on Dec 12, 2008
Our CAL232 TV will not turn on. When pressing the power button, you can see a red light and a green light, but the screen doesn't start up as normal. The TV then tries again after about 20 seconds, but...
My LOEWE CAL 232 will not power up. When the power button is pressed, the monitor turns on, with the LOEWE on the monitor, then the TV continues with the previous activity (antenna, DVD, VCR etc.). Now all that happens is
1. the red light comes on
2.after about 1 second the green light turns on for about 12 seconds
3. the the green light turns off for about 1 second
4. then the green light turns on again for about 12 seconds
and this continues until the power button is pressed to turn the TV off. During this time, the monitor does not turn on and the only sound I hear seems to eminate from the power button.
Any thoughts?
Oct 19, 2010 | Loewe CAL232 TV
Monitor comes on for a split second , and then off
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Dell monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 31, 2010 | Dell E152FP 15" Flat Panel LCD Monitor
M1991 screen stays black, little light is yellow
The fault is a back-light problem and the fault could be a faulty inverter board or a faulty CCFL lamp.
For service, parts and DIY info check out LCD Parts WEB site, please click on this link :-
www.lcdparts.net
Mar 15, 2010 | Dell Computers & Internet
Blank screen, flashing green light
Internal power supply is hurting. It is a non linear supply and they switcher transisters are not working
Jul 27, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Dell 17" monitor is not turning on.
1. Check the cable with the blue connector. Make sure it's plugged well to the back of the computer.
2. CHeck the light on the CPU's power button. If it's solid green, press the numlock key on the keyboard. Tell me, if the numlock light on the keyboard turned off or on. You can press it again if you didnt catch anything.
3. If there are no lights on the keyboard or the computer when you turn it on, the computer is the problem.
Just post here what lights are present or what happens when you press the numlock key.
Jun 16, 2009 | Dell P793 17" CRT Monitor
Screen goes black, but power light is on (not blinking)
The problem is not with your screen. Its the problem of Video Card of your system which is unable to send Video Signals to the Screen.
Apr 23, 2009 | Daewoo L700C 17" Flat Panel LCD Monitor
Sampo Flat Screen Black unless unplug and plug back in
i had the same problem now my monitor wont even turn on if i do that the power light just keeps blinking maybe its a sign of a dying monitor
Jan 16, 2009 | Sampo PD-70 15" Flat Panel LCD Monitor
My monitor will not turn on
disconnect the monitor cable from your computer tower
if you get a 4 colored box which says power on self test. it means its not the monitor then you have to get the video card or the systemboard.
Jun 09, 2008 | Dell P793 17" CRT Monitor
Repair manual
Problem solved! The main power thingy (the thing with the big red wire coming out of it) was all black and dusty. There was 'soot' all over the whole insides of the monitor. I concluded that this monitor should be laid to rest, and a new flat-screen monitor erected in its place.
Nov 18, 2007 | ViewSonic G220f (Beige) 21" CRT Monitor
ViewSonic E70fb (Black) 17 in.CRT Conventional Monitor Logo
680 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
