Sony Cyber-Shot DSC-S90 Digital Camera Logo
nicole cummings Posted on Dec 14, 2006
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony digital cam
The lens of the sony dsc s90 will not open the problem has been posted on the site already but have had no luck with the solution, the camera makes a noise like it wants to open but doesnt. can anyone suggest anything?
  • FlyingRyan Nov 26, 2007
    When I turn my camera on the lens won't open. I have to zoom all the way in to get a full picture. What is the problem?
AMJAD HUSSAIN
Level 3:
  • Sony Master 586 Answers
  • Posted on Mar 11, 2009
AMJAD HUSSAIN
Sony Master
Level 3:
Answers
586
Questions
Helped
206017
Points
1533
  This condition appears when the lens assembly start malffunctioning. Therefore, You have to replace the complete Lens Block Assy. For this plz contact any nearest Sony Service Centre nearby to u.
Thanks for using fixya!
Take care.
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 326 Answers
  • Posted on Mar 17, 2007
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
326
Questions
Helped
150224
Points
632
Replacing the motor unit will cure the problem. Part number: 289137601 If you need more help please advice
I have a sony dsc-s90. It will work fine for 3 - 5 min. and then a black screen will appear with "turn power off and on again". Once done, it happens again.
Usually a lens sensor. Clean with maybe some compressed air. If you trust your skills you could open the unit and clean cabinet where the lens retracts and extends.
When i turn off my camera sony cyber shot DSC-S90 the zoom wont retract and a word appear in the screen turn off and on again..any idea what's going on with it?
Sounds like you have some grit or gum on the lens barrel. This will cause the lens to stick in the partly closed position. Clean the lens barrel and try again. A rag moistened with methylated spirits may be needed. The rag must not be wet as we must not harm the special grease used in the lens.
If this fails it probably means an very expensive repair, or replacement.
I plug the USB cord into my sony DSC-S90 camera, then into the CPU and it doesn't do anything.
You need to use the install disk or go to the manufacturers site under "Support" there you'll find all necessary software and drivers available for download.
2answers
I DROPPED MY SONY CYBER-SHOT DSC-S730 WITH THE LENS OUT AND NOW IT WONT GO IN..
Lens mechanism is broken due to dropped. You need to replace lens assembly. If you know how to apart camera and replace lens assembly then let me know to guide you. Or take camera to local repair shop for fix.
Sony cyber shot dsc-s90
i don't have one,
did you get sand in it? that's what happened to mine and i opened it up and took the sand out. piece of cake!
but ir sounds like you might have a motor problem... that different. good luck!
5helpful
2answers
Sony Cyber-Shot DSC-W30. The lens is in a "stuck" position
You have a bad lens, it prob. also says turn off and on again.
2answers
Lens will not retract and no view on back of screen
possible bad lens assembly.These can only be replaced try alamo camera service .com
2answers
Sony DSC-S90
Hello, something is wrong with the lens assembly. The part number for the lens: 178821511. If you need more info please advice.
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
