Question about Pitney Bowes 9920 Plain Paper Fax
Need to set a pitney bowes 9820 to print a fax confirmation
We have an old Pitney Bowes 9820 fax machine. The company has had it so long the manual has disappeared. The machine always printed a fax confirmation after you sent a fax until yesterday. All of a sudden we do not get a confirmation that our fax has gone through. I don't know how to set it to print confirmations (hoping setting it again will solve the problem).
  • 1 more comment
  • isabella_van Nov 20, 2008
    Thanks leroyal. The info seems to be for a different machine. I did manage to figure out my issue with my 9820 though. As it turns out I was correct that I had to go into the set options function but I didn't know the password. I figured out the password and was able to set it to print the TX reports so I'm good. Thanks so much for the great site though! Have an awesome day!
  • Anonymous Mar 26, 2014
    I can't even find where the toner is located in teh machine.
    I can't even find where the toner is located in the machine.l
    Genius:
  • 2,120 Answers
Function
74
set
12
set
set
stop.
Posted on Nov 20, 2008
Pitney bowes 9820 fax machine is popping up error 50 check printer what might be the problem
Error 50 is a service error and you will need to contact your local computer repair or go to their site and talk to customer service to get someone to fix this for you.
Hope this helped
Positive Feedback ALWAYS Appreciated :)
Mar 06, 2011 | Pitney Bowes 9920 Plain Paper Fax
Error code 050 what is this? PITNY BOWES 9820
This is a defective laser code. The lubrication in the laser has hardened and the laser cannot turn as fast as it needs to.
Oce is the repair people for PB faxes now. 1 800 243 5556
Oct 05, 2009 | Pitney Bowes 9920 Plain Paper Fax
My Pitney Bowes 9820 fax machine says check printer service due. When I hit the help key it asks for a password which I entered 9820, but no other key after that seems to work
Service due and check printer may be two different problems
check printer may be a fuser or laser problem
service due may be a counter for a ozone filter that needs to be changed to make the EPA ha[[y. If you wait too long to reset the filter counter, it can go to a check printer and cease printing
To reset the counter, press function 99, yes,access code is ***1.yes
press 146, yes, then press 1 to reset, press yes. press stop to exit
Sep 14, 2009 | Pitney Bowes Office Equipment & Supplies
Pitney Bowes 8000, when I go to Copy it prints BLACK
your thermal print head is bad. This is a very old machine and I do not know where you can get parts. This machine is no longer supported by field repair
Aug 20, 2009 | Pitney Bowes Office Equipment & Supplies
Pitney bowes 9820 error message
press function, print incomplete command report, then go to function 4 and use command numbers on report to delete.
Jun 01, 2009 | Pitney Bowes 9920 Plain Paper Fax
New help getting Pitney Bowes 8050 fax machine to work
The code is the same as the model number 8050, Your battery has failed and will not keep it's settings if it loses power.
May 17, 2009 | Pitney Bowes Office Equipment & Supplies
Pitney Bowes 1530 Fax Machine
On top of the operating panel is a small removeable tab with a bump on top. (not the Blue ones) Pull it out of the machine This is the battery holder.
The battery is a CR 2032. Most electronic stores sell them.
Jan 31, 2009 | Pitney Bowes Office Equipment & Supplies
9720 Pitney Bowes Fax - access code has mysteriously been placed
Function 9, access code is 9720, press yes, press no until you get to set access code? press yes, delete code, press yes, press stop. I don't think this manual in online any more, but you can go to www.oceusa.com, go to drivers and support, and look for 9820 or 9800 series. The programming instructions are the same as this model
Jan 06, 2009 | Pitney Bowes 9920 Plain Paper Fax
Pitney Bowes Fax Function Question
I have a 9920 manual,could be the same.Try the following but if you get different displays don't change anything.Press function,should read FUNCTION SELECT , ENTER FUNCTION # .Enter 8, scroll to AUTO REDUCTION.(use COM STAT or HELP keys to scroll)Change to NO.Press stop to return to normal mode.If this procedure is not exactly the same for your model,then just search through the function settings and find AUTO REDUCTION and set to no.
Mar 05, 2008 | Office Equipment & Supplies
Pitney Bowes 9920 Plain Paper Fax Logo
613 people viewed this question
Top Pitney Bowes Office Equipment & Supplies Experts
Adorjani Laszlo
Marvin
Marvin
john h
Are you a Pitney Bowes Office Equipment and Supply Expert? Answer questions, earn points and help others
