Question about Numark ttUSB Turntable
I cannot hear my recordings from itunes on computer
My numark ttusb records A1 but i cannot play my music from itunes my playback device says USB Audio Codec how can i change it so i can play my recordings
  • trevorcolmer Nov 20, 2008
    i am running Windows xp the troubleshooting page in the manual says it wont work if my playback device shows USB Audio Codec how can i change it
    Master:
  • 638 Answers
For Windows: On the bottom left of your screen, select the "Start" menu. Select "Settings" then "Control Panel". In the window that opens, select the "Sounds and Audio Devices" icon. (If you don’t see a choice called "Sounds and Audio Devices," choose the "Switch to Classic View" option in the panel on the left of the window, and the left. Select the "Audio" Tab at the top of the "Sounds and Audio Devices" control panel window. Under "Sound Playback," choose your internal sound card as the default device. This varies by computer but should not be set to "USB Audio Codec" or Under "Sound Recording," select "USB Audio Codec" for your default device. Check the box titled "Use only default devices". Click "Apply"...then "OK". Hope this helps.
Posted on Nov 20, 2008
  • 4,806 Answers
Try this:
http://www.xpcodecpack.com/download
http://www.codec-download.com/modules.php?name=Downloads&d_op=getit&lid=77
these are codec packs for video and audio and you may hear sound after installing thses.
hope this works
regards
    Sergeant:
  • 229 Answers
The solution is probably pretty simple the codec is the format try downloading only mp3 formatted songs and they should work. Go to www.limewire.com for free downloads. use only the mps and have fun. Thanks
  • 728 Answers
As it is recorded, the format may not be able to be read by itunes. You have to change the format of the recordings so that they can be played using your itunes software.
    Brigadier General:
  • 6,966 Answers
If you are using Windows XP, pls try:
  • Goto Start, Control Panel;
  • click on Sounds and Audio Devices;
  • inside the Sounds and Audio Devices Property box, click on Audio tab;
  • on the Sound playback Default Device, select another device other than what is currently displayed or one that is not a USB;
  • click Apply, OK.
Should you be using Vista, similarly but variations on nomenclature/labels.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Nov 23, 2008
    Hi again,
    Any developments or updates so far?
    Sergeant:
  • 276 Answers
When you connect the devuce to the computer is it detected by the computer.if it says usb problem.replace the usb wire or load the drivers again of your device in your pc.
I cant get sound from my turntable. How do you hook it up?
As long as you can hear the record playing in the groove of a record, by ear, then the problem is that the connection to your computer is wrong. Since this is a USB turntable it will have to plug into a USB port. So you need to check that you have connected to the right type of USB port. That the port is working. See Control Panel on a Windows Machine. That the signal level from the port is set high enough and that it isn't switched off. You might also need to check the drivers for the device are installed and up-to-date.
Mar 28, 2015 | Numark ttUSB Turntable
Can't hear audio while playing or recording from my Numark to Audacity yet I can hear the audio when the transfer to Audacity is complete.
You will have got the audio muted in your windows recording mode. If you right click on your speaker icon it will say recording devices. Click that and you will be able to see all the devices and if they are activated.
Jun 08, 2017 | Numark ttUSB Turntable
Numark PT-01 USB Portable Turntable EZ Vinyl/Tape Converter
Pull an old iTunes itl. Lib file from one of your older backups and use that to replace the newer iTunes itl. file
Nov 16, 2017 | Numark ttUSB Turntable
EZ Audio Converter,no sound in iTunes
Presuming you're on a Mac:
System Preferences -> Sound -> Input
Select "USB Audio CODEC"
Repeat all your recording you've done thus far. Worked here.
Dec 14, 2009 | Numark PT01 Turntable
No sound from iTunes audio files
it sounds like EZ A C did not get the audio or EZ put it in a format tha Itunes Cant play. download VLC media player and install it. open the file with VLC and se if it will play it. It will play just about anything it has most of the codex's need to play anything too. if it doesent play it then something is wrong with the input to EZ A C you might have the input muted.
Jun 23, 2009 | Audio Players & Recorders
Numark turntable records record AND sounds in the room
the mic is in the computer somewhere, there will be a way to mute the microphone either in the vinyl software or in the system settings of the computer!
Jan 10, 2009 | Numark ttUSB Turntable
Not hearing songs I transfered to my i tunes from my Numark TTUSB
Open Preferences, Sound, your input should be  USB Audio Codec (turntable).. make sure your output is NOT USB Audio Codec, rather, headphones (for external speakers plugged in there)... thats how i have mine set up...
Jan 07, 2009 | Numark ttUSB Turntable
Playback Problem
They should be recording in mp3.  Then converted into ITunes using AAC.  Itunes will play MP3 format from the turntable.  The best thing to do is to record in that format, then test the files before converting them.  That way you can find out if the problem is with Itunes conversion or the turntable.
Oct 06, 2008 | Numark ttUSB Turntable
Converting to itunes
Have you recently upgraded any software (iTunes, Windows, etc)
- OPTiC
DJ Pro Audio
www.djproaudio.com
www.repairnyc.com
Aug 05, 2008 | Numark ttUSB Turntable
I cannot access the turntable thru my USB hub.
I received an updated driver from Numark but that still did not solve my problem. It turned out to be some sort of incompatability with my USB 2 card. When I plugged the turntable into my old USB 1 slot, my computer recognized it immediately. The new Audacity and MixMeister programs that were sent as a fix from Numark are just burning programs and not drivers for the device. I can now convert my old vinyl with ease.
Mar 10, 2008 | Numark ttUSB Turntable
Numark ttUSB Turntable Logo
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Morne Olivier
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
