Question about iLO DVDR05 DVD Recorder
DVD player not reading or playing DVDs
I have owned a Toshiba model number 3960 for less than two years. Recently, the DVD player will not read any DVDs. When I insert a DVD, I hear the DVD player attempting to read it, however, after a short time there's a clicking noise and it says "No disc" or "Error." Since the DVD player is fairly new, I was wondering what would be the best course of action. I spent $60 on the DVD player and would perfer the most economical route. Thanks for the help!!
Don't waste your time get a new player. You can pick a new one up for about 60$ or less now. If there is clicking thats most likly the lens is stuck and probably because the electric motor inside is dying. I see this all the time with roms not even worth the time to fix them anymore.
Posted on Jan 06, 2007
Try cleaning the lens.
Posted on Jan 05, 2007
Dvd will not read disc
cleaning the DVD player will help it read the disc, because a DVD player does get dusty. also it might be the disc, some DVD players will not accept some disc.
Aug 14, 2012 | Toshiba SD-3960 DVD Player
DVD won't play
Netflix doesn't know what they're talking about. I looked it up - your DVD player doesn't have an autoplay feature. Can you try the DVD on another DVD player. Computers DVD drives generally read them differently - and decode them differently, than a regular DVD player. Also, if your DVD drive is a writable drive, it will have a stronger laser than your DVD player. I think it's likely the disk is damaged, slightly. If you cleaned your DVD's laser, it might be able to read it well enough to play - or it might not. I started having problems like this with a few of my own DVDs before my DVD player's laser went out. Basically it's a combination of laser quality and disc quality. If it remains just this one disk, I'd suggest leaving it alone. But if you start running into this problem on other disks as well, you'll probably want to have the laser replaced in your DVD player.
Aug 14, 2007 | Amphion Mediaworks S99 DVD Player
Hi, I bought this LG RC897T 2 years ago and have only used the DVD player about 60 times. I've bought original "US" TV Box set dvds and Chinese knock-offs, and wrote my own dvds and they all...
Hello Mark. Most likely your player is regionalized and not compatable ith those DVD's that won't play. To eliminate the regional setting on your player go to this link http://www.wisebread.com/make-your-dvd-player-region-free-in-seconds
It contains the step by step instructions on how to make your player region free. It also has an how to video and a full explanation of why the regionalization was installed in the first place. Joe
Thanks for choosing Fixya!
Jan 05, 2011 | LG RC897T DVD Recorder/VCR Combo
The screen goes black every few seconds while playing a dvd. I've tried cleaning the player already and still have the same problem.
I am having a similar problem with mine... same model. It worked fine last night but this morning, went on the fritz. It started pausing every few seconds and so we took the DVD out. This evening, I tried to play a number of different DVDs but now the player will not even read any of the disks. I've had this DVD player for about 6 years so maybe it is just time for something new!?
Dec 07, 2010 | Toshiba SD-K620 DVD Player
Toshiba SD-480EKB DVD player
HD is not HDMI. An HD disc needs an HD DVD player.
Mar 19, 2009 | Televison & Video
DVD player won't play DVD, says "load"
The unit can recognize that a disc has been loaded but can not read the contents. This can be as simple as a dirty lens or more drastic like failing optics. Try cleaning the lens using a cotton swab and alcohol. If that fails to correct the problem and a music CD will play OK, then the optics are failing. DVDs require more laser power to read than a music CD.
Dan
Feb 04, 2009 | Toshiba SD-3990 DVD Player
WILL MY DVD PLAY AREA 1 AND AREAV4 DVD'S?
Hi camonk2004,
It's interesting that your DVD player was purchased in Russia but plays Region 1 DVDs. Region 1 is North America. Does your Player also play Russian DVDs (region 5)? If so, then it has probably been modified to play DVDs from multiple regions.
Check the back side of the DVD player - the rear panel should have a Region number on it. If the region number is 1, then try playing a Region 5 DVD. If it reads the DVD, then the modification that was done in Russia will probably allow it to read any DVD. IF the Region 5 DVD won't play (or if it is ejected automatically), then your player's region control os still intact, and it will only play DVDs from the same region as the one listed on the rear panel of the player (or DVDs marked "ALL").
I hope this helps - please let me know if I can be of any further assistance.
Kind Regards,
H2H
Dec 15, 2008 | Pioneer DV-U7 DVD Player
Toshiba SD 3960 DVD player
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 20, 2008 | Toshiba SD-3960 DVD Player
Tempremental playing dvds
In response to your jvc-a75r DVD player, sometimes the solution might be less complex than it may appear. Had the same problem with my Samsung s321,the machine refused to read DVD's but would play CD's no problem. Simply opened up the cover(usually)4-6 small screws, and found my dog's hair inside of the player covering the laser eye.Electrostatic ionization attracts dust,etc. into the player remarkably well sometimes. Carefully used a cotton swap to remove debri. PLayerworked fine afterwards ...Good luck!
Feb 27, 2007 | JVC TH-A75R System
My Toshiba SD-3960 sound does not work.
First thing before a landfill is to go into the units menu and see if something in the audio got turned off if not then inspect the connectors on the back for breakage. Good Luck
Apr 02, 2006 | Toshiba SD-3960 DVD Player
iLO DVDR05 DVD Recorder Logo
707 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
