Question about AutoCommand Remote Car Starter Add-On
Starter Stays Engaged
When I use the remote start the starter stays engaged unless I press the start button on the transmitter a second time then it disengages, how do I fix it?
  • 34 Answers
Check the wire that is hooked to the starter wire on the car. it should only show pwer in the start posision
Posted on Jan 09, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
99 yamaha waverunner 1200 xlt starter stays engaged and powered on even after stop is pressed and kill switch is pulled.
The start stays engaged the entire time? I would guess it's a bad ignition switch -- it would be sending power to the starter (through the solenoid) regardless of if you switched it off.
Maybe it could be a bad starter, too. I'd start with the switch.
Mar 10, 2016 | Yamaha Jet Ski Pwc Watercraft Cover...
Starter stays engaged. why?
The return spring on the bendix has broken or the helix is so dirty, that the bendix is stuck.
Jan 27, 2016 | 2003 Ford F-150
starter button on handlebar could be bad or stuck.
Apr 07, 2014 | 1995 Honda GL 1500 SE Gold Wing
Install bulldog rs1100 remote starter
Maybe a relay stuck on closed?
Nov 25, 2013 | Cars & Trucks
Starter stay engaged after it starts
If your starter stays engaged after the vehicle starts with the remote starter then, the vehicle's starter wire is receiving 12 volts, most likely from the remote starter's ignition or accessory wires. Check the connections to the vehicle's wiring: the battery wire is constant 12 volts, regardless of key position. The accessory wire(s) is 12 volts with the key at accessory and on/run (position 1 & 2), the ignition wire(s) is 12 volts with the key at on/run and start (position 2&3), and the starter wire(s) is 12 volts with the key in the start position (position 3) ONLY. Make sure that the remote starter wires are connected to vehicle's wires as directed by the Bulldog instructions.
Nov 17, 2010 | Remote Starter with Keyless Entry
03 Oldsmobile Silhouette 3.4L Starter stays engaged at times.
Sounds like time for a new starter. While it could be electrical, in that the starter circuit is remaining engaged, more than likely it is mechanical. As the starter wears, you get play in the starter gear. Replacing the starter should take care of it. If you have recently had the starter off or replaced it, it could be misaligned, causing a similar problem.
Mar 27, 2010 | 2003 Oldsmobile Silhouette
F 150 starts and starter stays engaged unplug alternator starts ok but no charge
2 problems, first you have bad starter or starter relay for starter staying engaged, keep alt plugged in has nothing to do with starter staying engauged, to test starter relay, jump at relay bat + post with red/bk wire on solonoid, if cranks over without staying engaged, then not relay or starter but rather in your ign switch, ford had bad problems with ign switch some years ago doing that
Feb 05, 2010 | 2006 Chrysler PT Cruiser
Starter stays engaged after motor starts.
solenoid on starter is sticking and needs to be replaced or repaired
Oct 13, 2009 | 2002 Chevrolet Impala
you need to tell us the make model and year of the vehicle and the kind of remote starter u have installed on the vehicle
Oct 09, 2009 | AutoCommand Remote Car Starter Add-On
AutoCommand Remote Car Starter Add-On Logo
469 people viewed this question
Top Design Tech Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Design Tech Vehicle Part and Accessory Expert? Answer questions, earn points and help others
