Lexmark inkjet "OPTRACOLOR 45". Have 910 service carrier stall code. I can position the carrier anywhere on the rail and start the printer,the carrier goes all the way left, times out and codes. Any help is very appreciated,Thanks....Kevin Welch kwelch02@hotmail.com
  • anthony3k Dec 17, 2008
    lexmark optra color 45. my print head go left hand side only and show error massage.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 31 Answers
The encoder strip has jumped off its track. Unplug, Clean the encoder strip with alcohol and get it back in the correct position. The strip should stay vertical behind the carriage assy.
Posted on Sep 24, 2011
Error code 1200
The error indicates that your cartridge carrier has stalled. To fix the problem you are experiencing, please refer to this article from the Lexmark website about 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One.
Sep 05, 2011 | Lexmark X4270 All-In-One InkJet Printer
Carrier stall nothing blocking still says carrier stall what else could it be
It could be a hardware problem. Please contact Lexmark Technical Support Center for assistance on this matter.
Jul 10, 2011 | Lexmark Z715 InkJet Printer
Printer cannot print test page. Cartiridges not sliing over to load position, "JE" flashing on printer
The "EJ" error code on the display screen indicates that the cartridge carrier has stalled. That explains why the cartridges are not moving to the center when you open the printer cover. Try to check in the cartridge area for a loose encoder strip (transparent strip). Make sure there are no foreign objects obstructing the cartridge carrier's path. If all is clear, close the printer cover. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, re-insert the cartridges. If error continues, please contact Lexmark Technical Support Center for additional assistance.
Jul 05, 2011 | Lexmark X2670 All-In-One Printer
The "on-off" light is flashing steadly... while
The flashing light could either indicate a cartridge problem or the printer carrier has stalled.
Test the cartridges one by one and do the printer hardware test (refer to the relevant document for your printer) to establish which one is defective. The defective cartridge needs to be changed. To do the hardware test, follow the steps below:
  1. Switch the printer off.
  2. Put one sheet of paper into the paper feeder.
  3. Press and hold the power button and the paper feed button for three seconds until the power light comes on.
  4. Release both buttons. After three seconds, the printer will start to print. You should obtain a page containing a series of horizontal color lines, and a thick black line below these. All the lines should be solid.
  5. When the test is complete, switch off the printer. NOTE: If you do not turn off the printer, it will keep on printing this page.
To check if you have a cartridge carrier stall, follow steps below:
  1. First unplug the printer.
  2. Move the cartridges to the left by hand. In order to do this, you need to grip the top of the carrier belt (a black/grey belt with cog-like teeth) and pull it towards the right-hand side of the printer.
  3. Once the cartridges have been moved across, you can clip them out.
  4. Try to print without the cartridges in the carrier.
  5. If you no longer have a carrier stall, put the cartridges back into the carrier and clip them into place.
Try to print a document to check if printer is working properly now.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sources: - Lights Flashing on the Printer - How to Perform the Hardware Test on the Lexmark X74/X75
Jun 25, 2011 | Lexmark X75 All-In-One InkJet Printer
Carrier stall
the carrier is the carriage tat holds the ink, it rides on a steel bar back aand forth open up unit t o see if it is stuck
Feb 05, 2009 | Lexmark X7170 All-In-One InkJet Printer
Printer carrier stalls for obstruction and there is no obstruction x4875 lexmark
Check printer drive belt for worn out teeth and also ensure that the printer shaft is free of greezeand dirty.
Dec 25, 2008 | Lexmark X4875 InkJet Printer
Lexmark x83 carrier stall
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:95:0:0&framed=&docid=ENUS22722&relevance=0
Use the above link to trouble shoot the problem.
Error: "Carrier Stall" ID:470
To check the cartridge carrier:
1. Unplug the printer.
2. Move the cartridges to the left by hand and then take them out.
3. Try to print without the cartridges in the carrier. Do you still receive a Carrier Stall error message?
4. If not, put the cartridges back into the carrier and snap them in at the back. The message should no longer appear.
If the power light on the printer is not blinking, the error message may be caused by a communication error. Do the following:
1. Remove any other devices attached to the USB/LPT port.
2. Uninstall the Lexmark printer.
3. Connect the printer directly to the PC and ensure that power is being supplied to the printer.
4. Reinstall the printer.
Feb 24, 2008 | Lexmark X83 All-In-One InkJet Printer
System error 000 carrier stall Presss power Key
Does carriage bash against side when power up? if so encoder strip is dirty or incorrectly seated... plastic strip inside printer lines on it 1cm wide, must sit vertical in slot on carriage
Might be somethin stopping print head from moving along rail, check ink carts are installed correctly and fully, check for paper squashed up left and right inside ends of printer. make sure carriage moves left and right
Try power up without cartridges and just black and just colour cart to eleminate cart faults does error change?
Oct 19, 2007 | Lexmark X85 All-In-One InkJet Printer
147 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
