Question about Mitsubishi VS-50605 50" Rear Projection Television
Vertical wrap over & Horizontal tear...
I am working on repairing an arcade video game (crisis zone) which has this type of projection screen. Any help/tip you can provide will be helpful as we are not familiar with Mitsubishi televisions.
Would it be possible to speak with a live technician via telephone
Thank You,
Sherry Modrak - Video Technician
Game Doc
800-766-3166
5 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi Projection Television wont turn on
Un plug the set first then remove the back, and depending on the model number you should have two or three fuses on the board on the right side where the power goes check them for continuity with an ohms meter. What is the model number of your set? Also does the led indicator light up?
Posted on Apr 27, 2008
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi WS-55313 no video
Resolder the vertical output IC that should take care of your problem.
Posted on Jun 16, 2008
SOURCE: Mitsubishi WT-46805 46 in. Rear Projection Television- No Picture
I had audio and no video. Now I cant get ant thing and the TV turns off by itself
Posted on Aug 24, 2008
  • 12 Answers
SOURCE: Mitsubishi rearTV has intermittent wavy lines running throughout
Do you have anything to test it in 1080i? Does it do it on all connections or just one? I had a similar problem with my TV that turned out to be a bad input board. Mine would only display 1080i through the Component connections. All others would show pink and green wavy lines. It cost me around 500 to fix it. Unplug the TV. Remove the back cover for the TV. Using a NON-metal object, or gloves, wiggle the input board (that has all the video connections on it) slowly back and forth and see if the problem comes and goes. You will have to have someone watching for you. If something is loose on that board, the problem should show itself. Narrowing down the problem will probably save you money on repair bills.
Posted on May 16, 2010
How can I fix my glitchy Tron arcade machine?
it sounds like your vertical or horivontal sync is going out what i would do is take the old monitor out and i would buy a arcade rgb cga ega yup to vga hd video converter you can usually find them on ebay for 40 dollars or so then all you will need is a flat screen that will except a vga connection you tube can show you how to install these items into your game i have done several and you would be surprised how easy they are installed and if you get a used monitor you can save a lot of money also
Jan 19, 2013 | Video Game Consoles & Games
Namco Ps1 Guns not working (npc-103)
You must be using on a plasma or LCD tv right?
Will not work... Only works on old tradicional TV...
Jul 26, 2010 | Namco Time Crisis: Crisis Zone
PSP time crisis 2
well you can't unless you can fit the disc in the psp somehow
you can try it and tell me how that works for you
Mar 25, 2010 | Namco Time Crisis: Crisis Zone
I cant calibrate the gun
It might be because of the joystick accuracy. Please clean it or change it.
Regards,
HP
Aug 28, 2009 | Namco Time Crisis: Crisis Zone
Line across middle of screen, rest of screen black
The problelm is a defective vertical deflection system. Could be the amplifier, vertical output driver or whole printed board that supports the vertical deflection activity. It is considered to be a serious failure.
The cost of repair will be around $200 to $300.
Aug 05, 2009 | Hitachi 50UX58B 50" Rear Projection...
Setting up the Crisis Zone Game and guns on a PS2
yep plug the guns in to the controller ports or one controler in one port and the gun in the other port go to calibrate to calibrate ur guns and ur off man good luck
Nov 15, 2008 | Namco Time Crisis: Crisis Zone
Jitter and tearing on bright pictures
1. VERT JITTER/HORZ UNSTABLE-CHECK 'GE' CONNECTOR PIN 5 FOR 1VPP Y SIGNAL INTO PIP PCB THEN CHECK 'GE' CONNECTOR PIN 11 FOR 1VPP Y SIGNAL FROM PIP PCB. IF SIGNAL AT PIN 5 IS GOOD AND PIN 11 IS CLIPPED OR REDUCED. CHECK ALL ELECTROLYTICS (I.E.C7001, C7014, C7026, C7036) AND ALL CONNECTING TRACES TO THESE CAPS FOR CONTINUITY 2. HORIZONTAL TEARING, VERTICAL JITTER. SIGNAL RELATED CONDITION. APPLY FOLLOWING CIRCUIT CHANGES ON PCB-SIGNAL: A. REPLACE R2K8 WITH A 1K RESISTOR (BASE OF Q2B2). B. REPLACE R2K3 WITH A 47 OHM RESISTOR (IC201 PIN 50). C. ADD A 100PF CAPACITOR FROM BASE OF Q2B2 TO JUNCTION OF R2L0 AND R2K6 (GROUND).
Jan 21, 2008 | Mitsubishi VS-60611 60" Rear Projection...
55IN TV.
1. VERTICAL ROLLING, VERTICAL BLANKING BAR LOCKING IN THE MIDDLE OF THE PICTURE, ALSO MAY HAVE HORIZONTAL PULLING OR TEARING. CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01
Oct 31, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
