Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Fridge not cold...freezer, no problem
How can it be that the freezer is working fine, fan included but the fridge is not getting the cold air and there doesn't seem to be anything blocking the vent. The freezer is on the bottom.
  • 833 Answers
You probably have ice in the air passages.  You'll have to defrost.  Cause:  too much humidity in the box...open containers, door left open.
Posted on Nov 21, 2008
Kelvinator cyclic 410 Upside Down Fridge Freezer. Fridge not getting cold. Freezer is working fine.
Is the fan in freezer compartment working? Is the damper fully open to allow cold freezer air into fridge section?
Sep 23, 2017 | Refrigerators
Freezer is working fine. Bottom Control for Crispers working fine. Upper section of fridge not getting cold.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
May 26, 2011 | Frigidaire Refrigerators
My frige is not cold, just cool, turn the T stat to coldest & no good. The freezer seems fine & I looked in the back & the fan is running. It doesn't seem to be blowing cold air or...
Two thoughts. If the fan is running... and you can here it in the freezer when it is on. Then the fan is fine and it is the mixer control. IF the fan is not working, then fix the fan.
The mixer control is in the top of the fridge where the air comes out on the wall between the fridge and freezer.
I think maytag calls this a cold control / damper.
Basically it controls the air flow rate between the fridge and freezer. When it is opens it allows air from the freezer into the fridge and cools it off.
Hope this helps.
Jun 17, 2010 | Maytag MSD2756G Side by Side Refrigerator
Whirlpool fridge not blowing cold air but freezer
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
May 28, 2010 | Refrigerators
Freezer works, fridge part does not
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 21, 2009 | Refrigerators
The fridge compartment not getting any cold air.
Well for whatever reason the fridge compartment is now getting cold air again and its all working fine. Have no idea whats gone on with it but is working again hahaha. The only thing that we did was take the back off the freezer, where it houses the fan motor, the motor wasnt quite straight so I straightened it and now its working. Whether that was the problem to begin with I have no idea.
Apr 12, 2009 | Westinghouse Refrigerators
Side by side freezer works fine ice cold.fridge not so good. only at 57 degrees
Listen for the fan motor to run. Open the freezer\ push the door switch with your finger \ listen for the fan that blows the cold air to the fridge. only the freezer side gets cold...fan blows cold to the fridge side. If the defrost timer has broken then ice may be blocking the flow of cold air to the fridge also. Only 2 things to check. Good Luck
Dec 11, 2008 | Kenmore 57029 Side by Side Refrigerator
Admiral side by side
All the cold air from your freezer gets pushed into the fridge with a fan in your freezer section. So your problem is from the fact that this cold air isn't get to your fridge.
- the door that allows this cold air into the fridge, normally in the top left corner of the fridge, is stuck shut and needs replacement.
-the freezer isn't defrosting and restricting the air flow
-the temp controller for the fridge is damaged and thinks that the fridge is cold enough.
Nov 15, 2007 | Admiral 26 cu. ft. Side-By-Side...
Fridge doesn't get cold enough
 If the evaporator fan is not running. The fan itself could be faulty or the door operated light/fan switch could be faulty.
If the evaporator fan is running. The fridge is not defrosting and ice has built up on the evaporator and the air is not circulating properly into the fridge compartment. The fan circulates cold air into the fridge and back through the fridge control which is normally just an adjustable flap which allows more or less cold into the fridge depending on the setting. If the fridge is not defrosting, the defrost timer could be faulty or heater element could be blown.
Nov 03, 2007 | Roper RT12VKX Top Freezer Refrigerator
Freezer works fine but the fridge won't get cold
It sounds like cold air from the freezer isn't making it to the fridge compartment. This can be cause by a several things. The damper that lets air into the fresh food side is stuck in "closed" position, the temp sensor (t-stat) isn't working properly, the evaporator fan (in the freezer comp above the coils) isn't working to blow air up to the fresh food section. In some situations, the defrost cycle for the freezer section isn't working and the coils have frozen into a block of ice and air can't flow over them properly so you get not cold air to the fresh food section but the freezer still stays cold due to the block of ice.
Feb 21, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
80 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
