Question about Gateway MX6427 Notebook
No power this lap top will not power up for some reson.is this a comon problem?
    Genius:
  • 1,913 Answers
Check your battery is chrged.then also remove battery from backside then again aattched after clean it.
then power up .
Posted on Nov 19, 2008
  • Gateway Master
  • 4,806 Answers
Take the battery out and try to power up on AC power only
let me know how you get on
regards
How can i fix my lap top battery circuit after fixing new cells?
A very dangerous thing to do and possibly the pcboard and temperature sensor inside the battery is now damaged. Probably cheaper to buy a new battery through ebay than purchase new cells to attempt a repair.
Nov 17, 2014 | Computers & Internet
My lap top its not responding to power button and i cant start my lap top
Unplug the battery and the power cord. Hold down the power button for 30 seconds. Plug back in the battery and power cord. Try powering on the laptop. If it powers on you are good to go. If not try contacting Lenovo support.
May 31, 2014 | Lenovo 3000 G530 Notebook
Power cord won't power charging of lap top
take it out and check if there is any dust or dirt on the connector
Dec 02, 2012 | Computers & Internet
Lap top will not turn on. receives power from the cord and power supply, but has no indicating lights on the lower left part of laptop. was able to get the lap top to operate after removing and...
Measure the voltage at the terminals of the battery in the laptop. If there is no supply then the power section in the lap tops main board is faulty and needs a check.
However if there is voltage then the battery must be checked if this has failed to charge and is defective. check if the cord from the adapter is not short as it will result in DC power cut off.
Mar 24, 2011 | HP Computers & Internet
My processor is getting hot. What will be the solution.
Turn it off ... it will not get hot.
Typically, normal temperature is over 100 degrees. There have been reports of fires starting as the result of a overheated PC. I am not making the claim, I have not had this experience.
Heat is the enemy of delicate computer parts. They call them Lap Tops but you should never use one on your lap. Always place your lap top on a hard surface to insure the vents are not blocked and the internal fan can try to do its job. If you are concerned about the heat, you can get a 'cool pad' to use under your lap top. A cool pad has a fan which blows onto your lap top to keep it cool. The cool pad gets its power from a USB in your laptop. This cool pad should not be used for long periods of time on battery power for obvious reasons.
Thanks for your question at FixYa.com
Jan 30, 2011 | Computers & Internet
When I push the power button to power the lap top up the light display that says outlet power changes from green to amber and the laptop will not power up.
try removing the battery and just use plug power only if it boots normally then change the battery and the change the power supply unit as well I would just start with the power supply unit first then see if the battery charges up if not the battery is bad replace it. Now if the computer will not start with the battery removed then you have a power supply issue.
Change and replace it. Hope this helps. Also when computer lap top get hot they will shut down to protect the computer wait and let it cool down then try to restart your computer. If this does work and the lap top restarts normally get a fan cooler that is USB powered and the lap top sits on top of it. Also make sure the fan is running and is not stopped. Clean and dust it out once in awhile. I hope this assists you with your problem. John
Jan 22, 2011 | Toshiba Satellite Pro 6100 Notebook
Monitor goes to sleeep on lap top
Hello, you can try this... Connect your laptop with an desktop monitor throughVGA cable.... then Click on start>> goto control panel>> Double click on Power Option>> Under Power Scheme it should be Poratble /Laptop >> Select Never under System Standbye, Trun off Monitor and Turn off Hard Disk.
Thank you for contacting Fixya support, please rate if that helps!!
Sep 06, 2009 | Relisys RLT1720 17" LCD Monitor
Dropped lap top now wont boot up
press the fn key on laptop hold it down and then press the power key on the laptop. once u see any display on the screen you will get some tests running on the screen. The system will show you the error message which u need to note down. else you can do a Flea Power on your laptop. Remove the adapter and the battery and then press the power button and hold it down for 30 seconds then connect the battery and adapter back and try to turn on the laptop. See if the magic works for you
Jul 16, 2009 | Dell Latitude D600 Notebook
No power to lap top
make sure the other side of the adaptor is also pushed in fully...i hope this can help
Dec 23, 2008 | HP Compaq Business Notebook NX9005...
Gateway MX6427 Notebook Logo
51 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
