Question about Uniden CXAI5198 Corded Phone
Can't get phone to ring
Accidentally pushed a button, turned ringer off. Can't figure out how to turn ringer back on
  • penny_tipton Nov 19, 2008
    I don't have an owner's manual, I moved my phone and accidentally hit a button that turned my ringer off. Unfortunately I don't know what button I hit or how to turn the ringer back on.
  • Anonymous Mar 31, 2014
    Phone ringer OFF. How do you turn ringer on?
    Sniper:
  • 84 Answers
No problem, just push the volume up key untill the ringer is at the level you want it.
Posted on Feb 27, 2009
Somehow the ringer got turned off. Can't figure
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
Sep 12, 2011 | Uniden Lands Phones
Ringer does not ring on one phone
Well it depends on the model, Most of them you can adjust the ringer volume by pressing the volume up key while the handset is onhook (not in use)
May 25, 2010 | Uniden 5.8GHz Dual Cordless Phone
My Vtech 5.8 cordless phone says ringer is off. How do I turn ringer back on?
press and hold menu button. Find ringer, push up button to change ring volume.
Nov 17, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
My vtech cordless phone will not ring. message is ringer off. how to turn ringer on.
Does your handset have a PROG button? Press that, then press the VOL+ button until you come to RINGER VOL: OFF. Press SELECT button, then use the ^ (VOL+) key until you get the desired volume level. Press SELECT again, then OFF. You're good to go.
May 30, 2009 | Vtech 5867 Cordless Phone
Ringer off displayed on base. How do I turn it back on? Just called myself from my cell phone and phone actually did ring.
Thanks for giving me the opportunity to help with your problem.
The "ringer off' message on the base display is referring to the ringer on the "base" unit not the phone ringers. Your phone handset(s) will still ring even when the base ringer turned off.
To turn the ringer on the base back on press and hold push the ^ symbol on the base until it beeps two times, To turn the base ringer off, press and hold the v symbol until the unit beeps.
If my information has proven to be of help, please give me good rating. Thanks for using FixYa!
Jan 27, 2009 | Panasonic KX-TG5632 Phone
How to adjust ringer volume
Yours is a little different from mine, but maybe this will help some, I hope. On the "talk" side, there is a button (2nd from right on mine) which says "loud" over the button, and "ringer" under the button. Pushing the button once gives you the soft ring. Pushing the button again will give you the loud ring. If you have gone to the loud ring, you will get the loud ring on the first time. Then you can push it again to get you back to the soft ring. I hope this helps.
Jan 23, 2009 | Panasonic 900 MHz Cordless Phone
Uniden 5.8 ghz phone. Can you turn the ringers off and how ?
On most of the phones you just keep pushing the volume down button untill it turns off. On some models there is a "Do not disturb" feature, usually it is a soft key feature so look on the LCD screen. Also, for the person that can't turn the ringer back on, just push the volume up key untill the ringer is at the level you like.
Dec 10, 2008 | Uniden 5.8GHz Cordless Phone
How do you turn the ringer back on a V-Teech 5.8 phone
yeah!! i kept playing with my phone that did not have a switch...and i finally got the ringer to come on! the volume up and down arrows are what finally got it to work, i just kept holding it down and it finally responded, try more than once if it doesn't work the first time
Jan 28, 2008 | Uniden Cordless Phone
Ringer off, need to re-install ringer. volume control does not put ringer back on
To turn your ringer back on, you do the following. For your handset, you push Menu, scroll to ringer settings, then push select, Press select again for ringer volume, then scroll up to turn on and increase the ringer volume. Then press Save once its at the desired volume. To change your base ringer, while it is not in use, push the ringer up button until you hear the desired setting. That should fix your problems.
Dec 31, 2007 | Panasonic KX-TG2357 Cordless Phone
Phone ringer
You can download the manual for a very similar phone, the KX-TG2302 at http://service.us.panasonic.com/OperMan/findmanual.aspx?cat=TEL and you can figure out all the features of a KX-TG2303. The simple answer is: while you are not using the phone, press the up or down volume button and it should turn the ringer back on. To turn the ringer back off, press and hold the down volume button until you hear two beeps. You can adjust the volume while the phone is ringing. The manual will tell you how to change your ringer tones, etc.
May 10, 2007 | Panasonic KX-TG2303B/WH Digital Cordless...
Uniden CXAI5198 Corded Phone Logo
287 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
