Question about Tappan TGF320 Gas Kitchen Range
Older Tappan range oven not lighting.
My Tappan 72-4252-00/05280 dual oven gas automatic pilotless ignition range lower oven does not light. Would like to know if there is a way to ignite manually.
  • 370 Answers
There is no way to light the oven manually. The gas valve will not open until the oven ignitor draws enough current. But replacing the ignitor will fix ya up.
Posted on Nov 19, 2008
When turning the oven on (Tappan Millennia ). And
If you have standing pilots it sure could be the pilot has blown out. if it is pilotless then you may have a bypassing oven safety.
Oct 06, 2014 | Kitchen Ranges
Gas Tappan oven will not power up after power outage
make this test and use the multimeter. God bless you
No power
Make sure there's power getting to your range, oven or cook top. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
Nov 04, 2013 | Tappan Kitchen Ranges
Tappan 32-1272-10/07056-8509-4080 gas range/oven pilot light works,main oven burner won't come on
You will need to look and see if the igniter is glowing a bright red. If it is weak, the oven will not light. Here is the igniter if you need to order it.
Also check and make sure your getting 3.2-3.6 volts AC to the valve.
Dec 01, 2012 | Tappan TGF320 Gas Kitchen Range
I just cleaned my Tappan NF40700643 Automatic Pilotless Ignition gas oven and now the light bulb (bulb is good) the and oven does not get hot .... it does nothing. Help ... I have dinner ready to put in...
if not even the light bulb is working it sounds like the plug is out or the fuse blew,pull the stove out,plug in a hair dryer or something to see if there's any power at the outlet or just go check the fuse or breaker box
Aug 16, 2011 | Tappan TGF363 Gas Kitchen Range
Ive got a tappan gas oven that wont light. The stove top burners light, but the oven or broiler wont. There is a ''glow plug'' that turns orange but the gas never ignites. What is wrong?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
gfgshg
Mar 13, 2010 | Tappan TGF320 Gas Kitchen Range
heatman101
ssgs
Feb 25, 2010 | Tappan TGF320 Gas Kitchen Range
Oven not coming on
I have a tappan gas stove the top comes on but the oven wont come on.
Sep 07, 2009 | Tappan TGF363 Gas Kitchen Range
Oven will not turn on
You need to replace the igniters for the top or the ignition filiment if it is the bottom.  You can get these at any appliance center.
Mar 12, 2009 | Ovens
Tappan gas stove,oven not lighting
yes replace the lower oven ig nighter you can do this from inside the oven pull the racks out then locate two screws in the bottom oven pan take the out pull the bottom plate then pull the flame spredder pan and you will see the glow bar replace that most common for you compliant
Jun 03, 2008 | Ovens
Tappan TGF320 Gas Kitchen Range Logo
1,105 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
