Question about Maytag Washing Machines
Non working washing machine
I have a Maytag washing machine modle SAV205DAWN. It fills with water to the right level and then you an hear the motor start, but the agitator doent move. Any ideas?
  • Maytag Master
  • 2,651 Answers
Sounds as if your belt is no longer attached, reomve the lower acces panel 2 5/16 screw under front panel you see the inner working and i would guess a broken belt laying on floor of machine
Posted on Nov 20, 2008
Pressure switch?
sounds like you are having a syphoning issue. caused by having the drain hose too far down the home standpipe. very common problem. test..fill the machine, high water level. when it stops filling turn off. advance into spin/drain for just a moment and shut off. listen to hear water still going down the drain.
repair.. raise the drain hose nearer the top of the stand pipe. also do not tape/seal the hose into standpipe. it has to breath. good luck. kihm washing machine drain hose installation Google Search
Jun 13, 2017 | Maytag Washing Machines
Machine filled with water but no nothing.
if you can hear the motor running but no agitation then your motor coupling has broken,,it is between the motor and tranny!
Mar 13, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag FAV6800AWW - Major overflow right after starting machine
Hi, If you turn the water source valve on and water starts filling the machine even tho the machine is off, change the inlet valve.
If you have to start the machine so water will fill but, the water does not shut off at the desired level, there is a problem with the water level switch.
I hope this helps you. Please let me know if I can assist you further.
Jun 13, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag washing machine model PAV3360AWW won't stop water on selected water level.
It sound like you have a bad float switch and it is not reading the water level right.If it is filling and wont stop then a possible new water valve is in order:) The float switch is locatted under the top panel of washer
Dec 30, 2008 | Maytag PAV2300 Top Load Washer
if you hear a motot running the coupling between the motor and transmission has disinagrated.
Dec 26, 2008 | Maytag MAT12CS Top Load Washer
Maytag neptune modle MAH6500AWW
it is saying locked rotor situation, could be a loose connection at the main board, at the door switch or the motor is bad, bet motor kit # for motor and board 12002039 good luck with the repair
Apr 12, 2008 | Maytag Neptune MAH6500A Front Load Washer
Admiral Washing Machine not spinning
y Admiral washing Machine modle # lnc6760b71 will fill with water and agitate. But when it come time for the spin cycle it wont spin. I can hear the motor making noise. and now stop and it does not work, does not smell to burned What should I do??
Jan 06, 2008 | Admiral AW22 Top Load Washer
Maytag SAV205DAWN, loud and leaking!!
the main seal is leaking and water has goy into the bearings,needs to be stripped and rebuilt
Nov 09, 2017 | Washing Machines
Washing Machines Logo
43 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
