Question about Mitsubishi WS-55511 55" Rear Projection Television
Will not power on. Please Help!!
I have a Mitsubishi WS-55511 that worked great last night, but went to turn on today and no power from remote or button. Pressed reset and green light flashed but still no power. Checked all fuses and all ok. Any suggestions. I have seen this problem on before but no solutions yet. Called service but not available till after holidays. Thanks in advance.
  • 2 more comments
  • Mike Sabo Dec 14, 2006
    THANKS
  • Mike Sabo Dec 15, 2006
    I Checked the codes and it came out with code 12
  • Mike Sabo Dec 16, 2006
    Dont know what I did, but works great mow. Thanks
  • Sandbardi Nov 26, 2007
    Will not power on. Tried reset. Green light blinks then nothing.
I took my control panel off the front of my WS-55511 and resoldered the power switch then I replaced the panel and the Thing fired right up. Thanks for the fix options you gave me. I kind of felt it was'nt those Caps that they talk about so much, Because when my TV Quit Idid'nt have any Blinking Green lights. The TV was just Dead. Thanks Rick
Posted on Dec 31, 2007
I too had a similar problem. One day the remote would not work. Only the power button on the control panel worked. I disconnected the control panel and now the remote works fine.
Posted on Aug 09, 2007
    Novelist:
  • 192 Answers
Error code 12 means normal operation. On these models we have found that a switch is sticking on the control panel not allowing the set to turn on. Disconnect the control panel. You will be able to use the remote on it. To find the plugs for the control panel: Remove the speaker grill and front panel, then follow the wire to the connection. Remember to unplug the set before putting your hands inside of it. Tell me how it went. Lead Tech
Posted on Dec 15, 2006
Turned off cable box but did not turn off tv. storm came throuht last night green light next to reset button flashing. tv want turn off or on. tried to reset want reset. unplug tv for a while pluged in...
rforester,
This model Mitsubishi has some capacitor problems with the DM board and the power supply. See my tip at http://www.fixya.com/support/r7065906-mitsubishi_turn_flashing_power_timer which explains the problem and where to get the parts to repair your unit.
Thanks for using FixYa and for the great rating.
hardrocko
Apr 26, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Tip
Mitsubishi WS-55511 Manual Download
Download Mitsubishi WS-55511 HDTV Manual
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Have you misplaced your Mitsubishi WS-55511 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-55511 HDTV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
____________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
on Apr 30, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Timer light is flashing and the set will not turn on
i need your confirmation that we can handle the repair we need to remove back cover and repair by parts.
Apr 14, 2010 | Mitsubishi WS-55511 55" Rear Projection...
We lost power last night. we have a surge protector on the house. the tv flashes green power button but does not turn on
Replace Both of your STK ICs they are big black ICs will have Part number on them Call Mats 1-800-628-1118 example STK392-570
Dec 03, 2009 | Mitsubishi WS-55511 55" Rear Projection...
WS-55511 shuts off with in 1 secound when turned on.
See my reply to your last posting---The set needs The Stk-393-110 and whichever of the two pico fuses is blown replaced--I have instructions AND photos of what the fuses look like.
SD TECH
Sep 15, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi ws-55511 does not turn on
Listen: you need to wait for the set to first shut off! then push on the TV(not the remote) Input and Menu both at the same time for 5 seconds and then release---the power light will then blink---this model has this feature--
Sep 13, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Got a Mitsubishi ws-55511 as a freebie a few weeks ago. Once plugged in it does nothing but flash the power light. Prior owner removed access panel but went no further. I am an audio engineer with lots of...
Thats an easy fix. The capacitors on the DM are known to fail . You can get the WS48511 - WS65511 DM repair kit at the following link which contains the replacement capacitors and the instructions on how to do the repair on CD which also contains the Service Manual
www.tvrepairkits.net
Jun 25, 2009 | Mitsubishi WS-55511 55" Rear Projection...
WS-B55 - Remote doesn't respond, front panel partial response
Genius!! Thanks! I took a dry cotton towl and ran it across the keys on my front panel and whatever was stuck, became unstuck..The internet just saved me $150.
Jun 15, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Tv wont turn on
That same thing just happened to my t.v. The repair person will be here on 10/10/06. I will let you know what they say.
Aug 22, 2006 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
436 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
