Question about BenQ Joybook 8100 Notebook
Trying to open up joybook 8100
Hey guys, As the subject says. All the screws that can be seen have been removed but I still cannot access the motherboard. There appears to be something still holding it together but I cannot find any other screws! I need to get in to the device because I need to check if the hard drive cable has become detatched somehow as when trying to boot up, it says device not found. Cheers!
  • clive45 Nov 19, 2007
    I have removed all screws and there seems to be something holding it together in the middle, as if there was another screw. I have surched very well but cannot see one.
If you look very carefully at the top of the keyboard in the recess there are 3 tabs that can be pushed back towards the screen with a knife blade and you can lift the top of the keyboard out and remove it. You will then find 3 silver screws that hold the top to the bottom. Three cables need to be removed from their sockets and the cables that connect to the network card (a black and a grey wire) the connectors just pull off. Use a small screwdriver to prise them up gently. Voila the laptop is now in two pieces.
Posted on Nov 19, 2007
    President:
  • 2,961 Answers
If you can't access the device behind a bay on the underside, the chances of it working after you dissmantle is slim, it's a specialist job where notebooks are concerned, the board is easily damaged when twisting and pulling.
Posted on Dec 22, 2006
SOURCE:
Trying to replace headlight on passenger side. Unable to remove lamp to replace the bulb. top left screw not accessable
if no access then remove whats in the way ,if its a solid chassis then headlight comes out another way ,sorry if not very helpful but iam a europeon mechanic and never seen this model car
Dec 12, 2010 | 1994 Eagle Vision
96 saturn wont start
Hey There,I would check the battery terminal connections real good.If they check out I have seen some inside fuse box issues where a terminal gets hot & burns at the front 68way connector.The wiring con be accessed by removing the left side console trim panel next to drivers right foot area.You can wiggle the wiring the next time it doesn't start & see if it takes off.If so you should back that connector out (7mm) screw in center & inspect male terminals with flashlight.If you see a terminal that looks like the plastice is malted around it you fould it.It will be in the first row.Used fuse box if so.Hope this helps
May 04, 2009 | 1996 Saturn SL
Blackberry pearl. Im trying to access my text messages
hey u need to go to where the text messages are and push on it then u go to compose sms text then put the name in and then write youe messages.try that i have the same phone
Mar 23, 2009 | RIM BlackBerry Pearl 8100
Blackberry got damp in rainstorm and buttons won't work
Moisture has caused a little short in between the contact under th keyboard.
I would recommend to open your phone and gently wipe any moisture under the keyboard..
1) Remove Battery
2) Remove 2 #6 torque screw from rear top of phone
3) Using a prying tool remove base of phone ( where the log of the phone company is
4) Remove 2 more #6 torque screws
5) Remove side chrome cover ( Snaps on)
6) Lever in between front and rear case and pry open gently
7) Wipe gently and re-mount in reverse order..
It should work
Sep 03, 2008 | RIM BlackBerry Pearl 8100
Unscrew laptop
You will get a better response if you pay for the expertise we have to offer!
Apr 07, 2008 | BenQ Joybook 8100 Notebook
How do I open it up?
Remove top cover then 4 screws from bottom.
Then start by prying along middle of rear edge. There is a catch in the middle so the top needs to be pried away from the bottom as the bottom is pushed in slightly.
The front has 2 double catches about an inch from the corners. First open the sides and rear, then push sideways (not up) to open them.
Feb 27, 2008 | Visioneer OneTouch 8100 Flatbed Scanner
Broken power jack joybook 8100
type in your model on ebay ok with power jack after they will come right up tons 7 bucks its a fun job too very tricky
Jan 23, 2008 | BenQ Joybook 8100 Notebook
BenQ Joybook 8100 Notebook Logo
1,040 people viewed this question
Top BenQ Computers & Internet Experts
Steve Allison
Steve Allison
Tommmix
Level 1 Expert
Joaquim Martins
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
