Question about Samsung Digimax S500 Digital Camera
Auto Focus Not Working
While taking pictures the other day, the Auto Focusing stopped. I didn't change settings or anything. I tried to reset the camera. I tried turning the camera off and then on again. I changed the batteries. I tried all different settings, i.e. children, portrait, auto, movie. The picture on the LCD sceen is blurry and so are all the pictures I've tried to take. I did not drop the camera, I did not pour water on it. I was just taking pictures of my child and one picture is fine and the photos after that are blurry. I need help before Chistmas. Is there anything that I can do short of throwing my camera against a wall? Please help. Thank you, Mary
  • Anonymous Mar 17, 2014
    My pictures are coming out blurry, it doesn't matter if its a still picture or of something moving. I have tried taking pictures in all the different settings but nothing has helped
Mine did the exact same thing and i hav only had it for 3 months; there is nothing i could do exept for taking it to the professionals
Posted on Mar 16, 2007
Digital camera won't focus
I see your camera has a focus area. If you have a subject with enough contrasting parts in this area, the focusing should work fine.
You must know that not every subject can be focused on as quick or as good as you would like. If there are little contrasting lines in the subject, or when it is getting dark or there are dark and light parts in the focus area, that don't belong together, every camera can have problems to focus correct. Changing the ISO settings won't change anything for the auto focus.
But special when you try to shoot in almost dark places, you camera will have lots of work to focus and in most cases it won't work at all.
You could try to place an object with light and dark lines, on the same distance as the object you want to picture. Then by pressing the shutter half, when focusing on the object with much contrast, you can look if the camera can focus. If it is in focus, keep the shutter pressed half way down, while moving to the object you want to shoot a picture of. Once you have every thing in the frame as you want it, press the shutter complete.
Dec 27, 2013 | Vivitar Vivicam 5388 Digital Camera
I am havin Sony Dsc-190 camera, the problem is pictures are not clear and I cnt increase the iso level, so pls help me out.
So the problem here can be many things.
  1. Either the camera is not focusing well
  2. the lens is not clean
  3. there is condensation inside the camera
is it possible if u post an image taken with the camera itself. also try checking if the camera has a master reset just in case u have set something that caused the auto focus to get disabled. like this you will reset the camera and get the auto focus back working.
the iso level will only control the lighting in your camera, so it will enable you to take pictures in darker areas when the iso goes higher. if your camera does not let you control the iso its probably set on auto.
regards
May 12, 2012 | Sony Cameras
With camera on the AUTO setting, I can't seem to take clear, focused photos. Nearly all of them are out of focus or blurry. Does not matter if it is in the day time or at night. Also, when using the...
Try resetting your camera back to factory defaults. Press the MENU button, select the middle tools tab and scroll down to RESET ALL. Press SET, select OK and press SET. Hope this helps.
Nov 09, 2010 | Canon PowerShot S5 IS Digital Camera
My lens stopped working in Auto Focus mode. I can take a picture in manual but I can't seem to focus clearly. I prefer using auto focus for my everyday pictures, but the lens will not work. I am sure it...
there is couple of possibilities like wise when you zoom lens manualy and can you heard the hard noise then could be AF unit itself faulty. AF unit gear is gone.
could be AF shaft broken thats why not focusing
could be AF Flex broken thats why not focusing
for that please bring to canon service center
Aug 11, 2010 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
My cable release is not working. It triggers the auto focus but will not take a picture.
Try setting the camera to M manual focus and manually focusing on the subject. Some combination of focus size and focus type may not focus unless the sensor sees a subject and is in focus. So if the sensor cannot see and know it is in focus it will not fire. If you subject is not moving then focusing in manual will ensure the subject is in focus and the camera can shoot.
Apr 10, 2010 | Nikon D300 Body Only Digital Camera
Auto focus problem
If you set the camera on "manual", it assumes you focused manually and allows you to press the shutter without having to stop half-way. Check your settings.
Oct 07, 2009 | Canon Rebel XT / EOS 350D Digital Camera
My Nikon D40 doesn't focus not take pics
If it's under warranty, use the warranty. It takes my D40x about a half second to focus at most. I keep my camera in a dust proof case when not in use. I've had it for 2 years, it still works fine.
Jun 24, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Aoutofocus stopped working
Please remove the battery and and then insert it again and test to automatically reset the setting.
melnavz
Oct 13, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Canon Rebel xti - auto focus problem
AI should be focusing. You really can't change many settings when you are shooting in auto mode. Is the lens in AF mode?
I'm sure you have long since returned from vacation!
Hope this helps!
Dec 31, 2007 | Canon EOS 400D / Rebel XTi Digital Camera
Auto focus problem
My first suggestion is to send it back if it is under warranty.
The grease probably got so thick, from the cold, that it caused too much resistance for the auto-focusing mechanism. You probably have damaged the focusing mechanism in the lens. You cannot repair this, yourself. I don't know how cold is too cold but it really shouldn't have done that.... Tamron makes cheap lenses. Try and exchange it for at least a Sigma.
Dec 24, 2007 | Tamron 18-250mm F/3.5-6.3 AF Di-II LD...
Samsung Digimax S500 Digital Camera Logo
175 people viewed this question
Top Samsung Cameras Experts
Computer Links
Jerry Z
Are you a Samsung Camera Expert? Answer questions, earn points and help others
