Question about Canon Elph Z3 APS Point and Shoot Camera
Problem with film winding
I insert new film into the camera and it automatically winds up the film and shows that my film is all used up. Is it the type of film i'm using (fuji)?
4 Suggested Answers
SOURCE: low battery warning
What type of batteries did you buy?
For digital cameras, you want to use batteries with high milliamp hour (mah) rating: "2500 mah" if they are rechargeable.
If you bought regular batteries, you want to use good quality. Look for the "e2" or "better for digital equipment" type.
Does the camera have a DC power plug option? Try taking pictures with it plugged in if it does. If it still malfunctions with power right from the wall, then you bought a bad camera.
Posted on May 13, 2008
  • 170 Answers
SOURCE: Nothing shows up on the film!
The Ilford Delta 400 Professional is indeed DX coded. Since the camera does not allow you to check the shutter without film inside, there's no way we can confirm the shutter is working properly. So only option is a service center. Since all other things are working properly, it should be a simple repair.
Posted on Feb 11, 2009
  • 3006 Answers
SOURCE: I can not operate the shutter of my Canon Prima BF-90 Date camera
Whenever I've had the same problem on 35mm SLR cameras it's usually just been due to the camera needing a CLA (Clean, Lubricate, Adjust) service. Over time the shutter button mechanism can get jammed by dirt or simply by sticky dried out lubricant. The fact that your camera works correctly on self timer confirms that the underlying mechanism itself is still OK.
Your Canon Prima BF-90 though is utterly worthless (in pure financial terms) and is a really basic model with fixed focus, no zoom, fixed aperture and just three shutter speeds and a film speed range of just ISO100 to ISO400. It was never designed to be dismantled and serviced so unless you are prepared to use the self timer for every shot the camera is effectively a write off. The camera itself was only designed to last for a maximum of about fifty rolls of film.
This is not all bad news though as you have a number of options available:-
1. Replace the camera: there are millions of other similar models sitting unused in cupboards and drawers and so just ask around or look on your local FreeCycle/Freegle groups and you'll soon have a replacement for free. Almost all charity/thrift shops have a back room full of such models as they're often virtually unsaleable, but if you go that route then expect to pay £5 or $5 as it's to a good cause.
2. As your camera is officially scrap and no professional repairer will touch it you have nothing to lose and valuable experience to gain in attempting a DIY repair. You'll be on your own in this as there are no repair manuals for such a simple model, but if you search the web for camera repair websites then you'll get some general ideas. Your camera is immeasurably simpler than most others so it's a good place to start learning a new skill. As you dismantle, note where everything goes and how it's connected, and clean out any fluff, grit, or dried-out grease. Sparingly re-lubricate as you reassemble using tiny dabs of a high melting point grease.
Personally, I'd suggest pursuing both options as they are both free. Your camera may be very basic but that also means that it's easy to use and reliable. It also means that you concentrate on photography within the camera's limitations and don't get distracted by umpteen settings and gadgets. One of the most useful features of your camera is the large bright viewfinder, and the fact that it looks like an unimpressive model means that thieves aren't interested and people don't behave differently in the way that they do when they see someone with a far more "professional-looking" camera.
Good luck with this; sorry there's no definite guaranteed fix but at least you do have other ways to resolve your problem. If you decide to dispose of your camera please try to ensure that it goes into an electronic waste or plastics recycling bin. I hope that you have still found my reply to be of assistance and in return ask only that you take a moment to rate my answer.
Posted on Mar 17, 2010
  • 3006 Answers
SOURCE: Camera shows flashing H in rear screen and won't
Unfortunately on your model the flashing H means there's an electrical fault which needs repair.
In practice, it's an old obsolete model and few spare parts will be available. Any kind of professional repair will cost far more than the camera is worth. But as almost all 35mm compacts are now virtually worthless it means that you can get fantastic models for free or very cheap. All of mine have come for free via FreeCycle, Freegle, and by just asking people I know as most have unused and unwanted cameras lying around. Even the superb and very under-rated Canon Sureshot Classic 120 which has one of the sharpest lenses ever put onto a 35mm compact can be had for zilch as the batteries cost more than the camera is worth (new batteries: about £10).
Sorry this is not the answer you hoped for, but I hope that it enables you to fix the problem in a different way at almost no cost.
Posted on Mar 04, 2011
0 characters
1 Points
A clip came off my Cannon sure shot 150u on the left side and it wont wind the film, how do i fix?
hi, this is film camera uses 35mm film , the clip is used to keep the film wound tightly on the take spool, no problem , use ultra thin cello tape on the tip of the film and attach it to the take up spool , ensure that the rewinding stops as soon as the counter reaches 0 or 1 , in case the camera does not have switch, remove the battery on time hope this works
Aug 31, 2016 | Canon Digital Cameras
My canon eos 1000 keeps on rewinding the film into the cannister when i put a new film in
The XS normally winds the film completely out of the cassette and then rewinds it back into the cassette as you take pictures
Feb 08, 2013 | Canon EOS Digital Rebel XS / 1000D IS...
I put the film into the camera, turned it on and it wound the film up for processing. What did I do wrong?
If this is an APS camera, there are 4 different stages to the film, if the can was on the third stage when you loaded it, it will move the film to the wind up stage.
If it was a fresh film cartridge you will want to get the camera looked at by a service centre.
Jul 26, 2011 | Digital Cameras
I used my camera for 17-20 shots but then layed it aside and haven't used it again until now. Will the film be harmed? It's been over a year. That's probably a silly question but can I...
Hi Barbara - The film is actually a digital data file in a digital camera so your 17-20 photos should still be fine on the camera. Data files don't go bad with time.
You can just take up shooting from where you left off originally, just make sure the batteries are fresh and off you go.
Good Luck and happy shooting,
May 25, 2011 | Vivitar Digital Cameras
I may have loaded film roll that has already been taken?
Usually when you finish exposing a roll of film, you rewind it until you are sure it is all wound into the cassette. There is a change in the sound as the end of the roll leaves the camera. An exposed roll would have no film sticking out of the cassette. A new unexposed roll will have a bit of film sticking out of the cassette to pull across the ack to the take up roll.
May 26, 2009 | Canon Elph LT APS Point and Shoot Camera
I have a nikon f65 camera and can't figure out how to put the film in it. I am used to using manual cameras with the film advance lever.
Just put the film cassette in as you did in your manual camera, pull the leader over toward the takeup spool, just to the red mark - no further. Then close the back and it'll wind automatically. If it doesn't, turn the power switch on-off-on.
Nov 27, 2008 | Nikon Digital Cameras
I cant seem to load film in my camera . it winds it back up as soon as i close it or try to take pictures
It's still in auto-rewind mode. Depending on the model, do a manual rewind with no film in the camera to reset the internal counter. Then load film and try it. Please leave feedback if this helps.
Jul 26, 2008 | Digital Cameras
Camera is a JVC GR-DF470 Video Camera. Problem is UNIT IN SAFEGUARD MODE EJECT AND REINSERT TAPE ERROR 03. I have done this and problem still remains.
I have the same model of camera and the same problem has occurred after two years of use. I am not sure why it happens but checking on other web sites, it may have to do with tape tension and the brand of tape. Up to now, I was using Sony and JVC tapes which worked fine but a recent purchase of TDK tapes seems to have caused this problem.
My fix was to take the tape out and then manually wind the tape a couple of turns by inserting one flat blade screwdriver in the tape lock tab (bottom middle of tape case) and using another to wind the tape. This appeared to fix the tape tension and after loading it back in, the tape and the camera worked fine.
Hope this helps.
May 05, 2008 | Digital Cameras
Canon Elph Z3 APS Point and Shoot Camera Logo
22 people viewed this question
Top Canon Digital Cameras Experts
Are you a Canon Digital Camera Expert? Answer questions, earn points and help others
