Question about Casio fx-300ES Calculator
Tan cos etc with casio fx-83ES
If i put in tan45 i get answer 0.85408.... when tan 45 = 1 . other trig probs give wrong answer
Set it up in correct rig mode, mode button (several times) until you get a window showing deg - rad - grad, choose deg (degree mode)
Posted on Dec 03, 2008
Bought a Casio FX-260 calculator. Im trying to find out how to input a trig formula. E.g 2/cos(70)= 5.84 When I do put this in the calculator in scientific mode it gives me a different answer. Help?
I'm guessing that your calculator is set to radians or gradians (or degrees, if you are looking for a result in radians or gradians).
Try changing this and hopefully it will work.
Otherwise, post again!
Good luck,
Jul 25, 2016 | Casio Office Equipment & Supplies
How do i get my calculator to do the trig problem Tan45=1? It is telling me Tan45=1.61977, and i know that isn't right.
Angles may be measured in three angles:degree, radian and gradians (grads).
tan(45 deg)=1
tan(45 radians)=1.61977
If your problems require angles to be measured in degrees, make sure that the calculator's angle unit is set to degrees.
In RUN screen press [SHIFT][MENU] (SetUp) select the angle line and press function key under the tab Deg (should be F1).
Sep 17, 2013 | Casio FX-9860G Graphic Calculator
Use the identity tan(x/2)=sinx/1+cosx to solve for the value of tan45 degrees
Setting x/2=45, means that x=90 (degrees)
But cos(90)=0 and sin(90)=1. Thus tan(45)=1/(1+0)=1.
Mar 13, 2013 | SoftMath Algebrator - Algebra Homework...
What is d use of hyp function??
The hyp key is used with the cos, sin, and tan keys to compute the hyperbolic cosine, hyperbolic sine, and hyperbolic tangent functions (and their inverses).
The hyperbolic functions are computed the same way as the trignometric functions: simply press the hyp key just before pressing the desired trig key.
May 04, 2010 | Casio FX-300MS Calculator
How to use trig function keys on my casio fx-300ES
You have 3 keys for the main trigonometric functions: [SIN], [COS] and [TAN]
To use them correctly you must set the angle unit to the one your problem calls for.
Press [SIFT][MODE] [3:Deg] for degree, [4:Rad] for radian, [5:Grad] for grad. Dependig on angle unit chosen a small D, R, or G appears on the top of the screen.
If you need the inverse trigonometric functions arcsine, arccosine, arctangent, you access them by first pressing the [SHIFT] key
arcsine [SHIFT][SIN] (sin^-1)
arcosine [SHIFT][COS] (cos^-1)
arctangent [SHIFT][TAN] (tan^-1)
The syntax for the function is
[SIN] # [ ) ] [=]; [SIN] 30 [ ) ] [=] gives 0.5
[COS] # [ ) ] [=] [COS] 19 [ ) ] [=] gives 0.945518576
Note: if the argument of the functions are numbers, the right parenthesis is not necessary. But if the argument is an expression (with various operations) better put the parenthesis to make sure the calculator is performing as one wants it to.
By the way, there are no keys, or key combinations to calculate cotangent, cosecant, and secant, but you can use the definitions:
cotangent (x) = 1/tan(x) Do not confuse it with tan^-1
cosecant(x) = 1/sin(x) Do not confuse it with sin^-1
secant(x) = 1/cos(x) Do not confuse it with cos^-1
Hope it helps.
Oct 30, 2009 | Casio fx-300ES Calculator
Sin, cos, or tan, on casio wrong answer. another cac right answer
It may be due to the angle unit used. You can have angles in degrees, in radians, and in grads. You should set the default angle unit to waht you problem calls for.
To set degree as default SHIFT MODE 3
To set radians as default SHIFT MODE 4
To set grads as default SHIFT MODE 5
The values of angles calculated by the inverse trigonometric functions are in the default unit that is set . This may be the source of the wrong answers that you get.
Hope it helps.
Sep 16, 2009 | Casio FX-115ES Scientific Calculator
Inverse Functions on Casio fx-270W PLUS don't seem to work
because cotangent, cosecant, and secant are all inverse trig functions, just type in 1 / |shift| trig function and the number if you are finding the angles. It might not be a dedicated button, but its an extra push, and it will give you the same result. *note that I put the shift press only because that is how you get the inverse tan to get an angle from a tan ratio.*
May 04, 2009 | Casio FX-270W Calculator
Locating the inverse key for trig. functions
Use [SHIFT] [COS^-1], [SHIFT][SIN^-1] and [SHIFT][TAN^-1] the keys are the same as the direct function, but they are accessed via [SHIFT].
Be carefule with the angle units when handling trigonometric and inverse trigonometric functions
Hope it helps
Dec 07, 2008 | Casio FX-300MS Calculator
Casio fx-300ES Calculator Logo
535 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
