Question about HP Laserjet 2605 Printer
Computer can't find printer
I moved my printer from my office to my home office. In my work office I was hooked to the entire (network) system. I used 1 cord to plug into the wall where my lap top was plugged into as well. I could operate my HP 2605 printer from there. When I brought it home I plugged the same cord straight from the printer to my lap top and tried to print and the computer says that it can't find the printer. The cord I am using has a snap on end like what a phone cord would have. Is there suppose to be another cord and what can I do to start printing?
When connected to a network you use "straight cables (cat 5 or 6 )". To go directly to a printer from your computer with no routers, switchs, or networking you use a "cross-over cable". Be sure your computer and printer are still on the same IP-address scheme. If your on auto IP, or DHCP it might have changed. Hope this helps
Posted on Nov 20, 2008
  • 274 Answers
Your using an Ethernet cable and your not on a network. You most likely need a USB cable, or connect the computer and printer together with a router. How are you accessing the internet from home?
I moved back home from my winter home in AZ, hooked up my computer (Dell 8) and my printer (HP Deskjet 1050) again, but now printer won't obey print command. It runs the paper through and sounds like its...
what operating system are you using
win xp and win 7 will have dropped out the printer driver so you will have to download it from the dell web site
Jan 31, 2018 | Office Equipment & Supplies
I have an HP Laserjet P2035N that worked just fine until I moved it from home to my office. When I hooked it up to my laptop, which it has been before, it said the printer was offline. I've tried...
network printer is connected to check network connection. (cable, plug, etc.), if everything is ok not a problem to the network printer port on ferl can happen and if it is installed USB port, possibly connected to a another USB port
May 25, 2011 | HP P2035N LaserJet Monochrome Printer
You can hook up your printer to the laptop. Once you do this, you may need to install device drivers to the printer works properly.
Click here for driver links
You will have to download the drivers for the appropriate operating system you are using.
Alternatively, if you have the CD that came with the printer, this may have the drivers pre loaded on it.
Also, if the printer is already hooked up to a computer in your home network, you can access it from the laptop. You will have to share the printer out.
Click here for steps to share printer
May 09, 2011 | Computers & Internet
HL-2170w won't print with Windows 7
Windows 7 will not work with earlier Windows versions of printers
Feb 28, 2017 | Brother HL-2170W Laser Printer
The printer (hp laserjet p2015) appears offline
Press and hol the green 'go' button until the lights flash, (about 4-5 seconds) and release the button,
Wait for the config pages to print out, and then check your network configuration, i.p address, Subnet mask and gateway.
If no network page prints out, you might have a dead Network Interface in the printer.
May 10, 2010 | HP LaserJet P2015dn Printer
Use a usb in desktop. quick word flashed worm.
Plz check any other antivirus like kaspersky or antivir avira..
Oct 31, 2009 | Microsoft Windows XP Home Edition
My printer canon ir2022n network printer does not print from my new vista business OS computer
Windows sharing based printers are dependent on the computer where the printer is attached. This means that if the computer is turned off, or is in the sleep/hibernate mode, then all the computers that can print through that server will not be able to print. To solve this issue you can use external print servers to share printers in the home/office. External print servers are connected to the router which allows it to be available on the network without being dependent on any other computer system. External print servers are available in both wireless and wired versions, and the choice between those options is based on the needs of the home or office.get more information and help for Network Printer Configuration .Hope this helps you.
Oct 13, 2009 | Office Equipment & Supplies
We can't get the lexmark t642 printer to work at home
The printer is not hooked up to the wireless network. It will work if hooked up with an ethernet (hard wire) cable. Anyway, it is a royal PIA to set up - let him take care of it.
Sep 01, 2017 | Lexmark T642 Laser Printer
Sharing cannon printer MP170
If you want to make your printer a Stand-alone device (no need to be connected to a computer, just directly to the router) you may want to look at getting a Print-Server.
But if you just want to share the printers, you will have to install the printer separately on both computers (since they use 2 diff drivers for the printer), then share it on the vista computer. at this point you should now be able to print on both machines
Nov 24, 2008 | Office Equipment & Supplies
Connecting to Linksys as Router for Canon Image Runner 3300I
You can connect by using a hub. Then wire the hub to the machine and from hub to the stand alone pc. Still you have ot do some pc configuration to make the system running.
May 22, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
HP Laserjet 2605 Printer Logo
88 people viewed this question
Ben Johnson
