Question about Bosch Refrigerators
FRIDGE NOT VERY COLD - ABOUT 15 DEG C, FREEZER OK
I HAVE A BOSCH KGN34X00GB. THE FRIDGE IS ONLY SLIGHTLY COLD WHILE THE FEEEZER IS NORMAL. DOES IT HAVE SEPARATE SENSORS OR RELY ON AIR FLOW BETWEEN FREEZER AND FRIDGE?
THANKS
JOHN
    President:
  • 1,462 Answers
Relies on air flow between fridge and freezer but is regulated.
fault is probably ice build up on top of evaporator in freezer. remove back panel inside freezer and check. also check the air ducts are not iced up
Posted on Nov 20, 2008
Bosch kann58a50gb/o8 fridge not cooling freezer seems ok
See or hear if the fan inside is working. Im not conversant with your model. Some units have 2 fans , 1 in the freezer and 1 in the fridge. Some only have1 , which will be in the freezer only. If the fan fails, the fridge cannot blow cold air into the food compartment. Generally, when an evaporator fan fails, the fridge doesn't get cold and the freezer overfreezes causing an excess ice buildup in the freezer.
Feb 23, 2015 | Bosch Refrigerators
My ge profile pfs22sbsss model french door freezer drawer was left open overnight and now won't get cold. Any ideas?
THE FREEZER HAS FROZEN PAST THE POINT OF DEFROST;TURN FRIDGE OFF AND MANUALLY DEFROST ALL THE ICE IN THE FREEZER SECTION AND ALL AIRWAYS TO FRIDGE SECTION.
May 10, 2014 | Refrigerators
Bosch KGU 34640 freezer not cold enough
I had a similar problem a couple years back with my freezer. Behind the vent cover in the back there were a few lines that ran the cooling or something like that. What happened was my freezer was icing up horribly. I was told to take that panel off and check those lines. Sure enough one of the lines was busted through. That was why my freezer was having problems. I apoligize I don't know anything about the front buttons tho.
Dec 28, 2013 | Bosch Refrigerators
Fridge too warm
It is likely to be either the circulation fan in the freezer or the defrost element. The cold air is blown from the freezer into the fridge if the fan doesn't work then no cold in fridge( actually I think there are 2 fans in these, 1 horizontal 1 vertical) otherwise it could be a defrost problem, if the element doesn't work the rear fills up with ice and the air cant flow. Both are behind the rear panel of the freezer
Jul 08, 2013 | GE Energy Star PDS22SIS Stainless Steel...
Bosch kgu3201 fridge freezer
Request a wiring diagram directly from Bosch.
Dec 14, 2017 | Refrigerators
Hi, I have a Bosch intelligent frost free 44 which I bought second hand a few days ago. Manufacture date appears to be 2006 and was told it works fine but I am not sure. When I first turn fridge on the...
I think it's the freezer fan that stopped working,open the freezer and see if it goes you should hear it running and even see.This fan allows the cold air into the fridge compartment,without it it takes ages for the fridge to get cold.I've got the same problem if you find the motor online let me know on alvalen31@hotmail.com
Nov 03, 2010 | Bosch Refrigerators
Refrigerator warming (50 deg) while Freezer Temp OK or Colder than normal
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 24, 2010 | Maytag MBF2556HEW / MBF2556HEB /...
Why does my ice cube maker quit working and temperature in freezer is the same as fridge.
ice maker will not work if freezer is too warm . it must be 15 deg or lower and if fresh food is that cold then the food is frozen. the freezer needs to be 0 to 5 deg and the fresh food side 38 def is best . / you may be having a defrost problem and the cold coil is packed with ice and prevent ing air flow .. ck for ice in back of freezer .. mm
Oct 22, 2010 | Amana Refrigerators
Faulty Fridge freezer
I suspect you may have a faulty compressor! Do you notice if the compressor starts?
Feb 05, 2009 | Bosch Freezers
Freezer temp
Do you have a problem with the fridge other that. Have u tried adjusting you controls .. freezer and refrig. ? That should be ok unless you having problems with something else ... like say ice maker
Aug 18, 2007 | Frigidaire FRS23R4A Side by Side...
Refrigerators Logo
666 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
