Question about Whirlpool 24 in. GU1200XT Built-in Dishwasher
Water in the dishwasher after the the cycle is complete
About an inch of dirty water remains in the dishwasher after the cycle is complete
    Sergeant:
  • 276 Answers
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Posted on Nov 19, 2008
Dishwasher does not drain completely
almost 100% positive its going to be the pump and power pack assembly very expensive repair
Mar 30, 2010 | KitchenAid 24 in. KUDU02FR Built-in...
When the wash cycle takes longer than the time stated on the display, and when the dishes are done, there is about three inches of dirty water in the bottom of the drawer . The repair technician replaced...
A couple of things to confirm first
1. is the second drawer working oK - i am assuming you have a double drawer model?
2. Are you not seeing the wash cycle time on the display? why does the technician want to replace the display (LCD)?
3. Apart from replacing the rotor did the technician try to clean the dishwasher base and pump filter sump?
Please post your comments to help diagnose the cause of dirty water remaining in the dishwasher.
Jan 14, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
We have a Jenn-Air dishwasher. The water does not fully drain when washing cycle is complete. Roughly 1/2 to 3/4 inch of water remains. Any suggestions are appreciated.
Check the that the drain hose is not kinked in any way under the counter and leading to the garbage disposal. Also check that the port in the garbage disposal is not partially restricted, or that the kitchen drain is not slower than normal.
I had the slow drain issue recently, and it would take the dishwasher forever to complete a cycle.
Dec 17, 2009 | Kitchen Ranges
Dirty water remains in Dishwasher after all cycles are completed
The problem was solved by removing the knock out on my new Garburator.
The manufacturer of this garburator does not say anything regarding this knock-out in their installation instructions.
Nov 27, 2009 | Frigidaire Dishwashers
Brand new dishwasher will not drain at end of cycle.
Check your manual. Some dishwashers actually do leave water in them after the final drain cycle. It has to do with the type of seals they use. Some will leak the very first time they are used but not after that. The seals in these types must remain wet. If this isn''t the issue, wait about 5 minutes fir the timer to finish. Sometimes there is quite a lag at the last cycle. If all else fails, call the customer service number in the manual.
Feb 02, 2009 | Haier ESD300 / ESD301 Built-in Dishwasher
Food particles are on dishes after washing
Try adding bicarb of soda/baking soda and vinegar in the detergent dispenser. Bicarb fizzes off hardened particles and vinegar strips off grease and aids rinsing.
Jan 26, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
Ran on normal cycle when done 2 inches of water on bottom
Test by restarting the cycle and see if water drains if it does not then there is either a blockege in the pipe ,pump,or in the machine where the water passes out normally through a filter if you have checked and cleaned out filter and drain pipe and there is still no draining then listen to the pump if you can hear a humming niose then there is something in the pump itself and you need to take it out and inspect the impelar houseing remove what ever is there put back and enjoy if there is no noise and pump is clean then it is proberly fualty and nedd replaceing.
Jan 23, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Service Manual
the top spinner is just clipped on. if you look at it you will see the cut in the plastic and it will just pull off. clean out the spinner and in the hole use some pipe and blow down it. on first cycle it should empty the dirty water out.
May 25, 2017 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwashing machine not fully draining (2 inches of water remain). I have an open problem concerning this problem. I have a new pump. dishwashing machine not fully draining (2 inches of water remain) For...
Following a cycle, a small pool of clean water inside the tub is typical. Excessive water means the pump isn't pumping water out properly, the drain hose isn't carrying it to the drain pipe, or the house's drain lines are backed up. If dirty water spews from the air gap, the drain line is kinked or clogged. Note: If you've recently installed a garbage disposer, be sure the knockout plug for the dishwasher was removed when the connection was made (see your disposer instructions).
Apr 19, 2008 | GE 24 in. GLD5860LSS Stainless Still...
Whirlpool 24 in. GU1200XT Built-in Dishwasher Logo
659 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
