Question about VeriFone (M19755014US1) Magnetic Card Reader
I don't know how to paper feed - VeriFone (M19755014US1) Magnetic Card Reader
  • 1 more comment
  • Anonymous Nov 24, 2008
    SAME PROBLEM
  • Anonymous Dec 04, 2008
    I have the same problem
  • Texlar May 11, 2010
    The paper feed feature is dependent upon the application. Example: The credit card application known as SoftPay has that feature and it will ONLY work in that application. If other applications are loaded in the terminal and if they are configured with the feature, then the paper feed will operate. If not, simply open the door and pull out the desire amount of paper and close the door.
  • 26 Answers
The standard function to advance the paper is to Press the [3] key from idle prompt.
Posted on Sep 14, 2009
I don't know paper sensor. I search paper sensor.
small black plastic near paper feed unit or sometimes back of fixing unit and in up of cover
Feb 19, 2013 | Office Equipment & Supplies
Tip
My X2250 will not feed the single sheet of paper evenly. When looking at the...
Printer would not feed paper no matter how many sheets were in the bin or how clean the printer. I even cleaned the roller. The issue was I just needed a little more tension on the roller that pulled the paper in.
I removed the rear access door (see manual). Off to the left near the feeder roller you will see a spring. What I did is mover the spring to the END of the plastic arm that it is attached to (if it is missing ..you have a bigger problem). If you have moved your printer around a bit, the spring may have slipped down on to the arm and is no longer sitting at the end. This will extend the spring another 1/16 of an inch ...and that is all all it took for me. My printer will now feed a single sheet of paper with no issues. BTW: I put a drop of glue on it after so it would not slip off.
on Sep 28, 2008 | HP PSC 1610 All-In-One InkJet Printer
Epson c66 not feeding paper
Main reasons for a paper feed problem like the one you describe are:
-. One of the sensor actuators (normally It will be a little plastic lever on the path of the paper) is either broken or blocked. It could happend if you attempt to remove a paper in the opposite direction of the normal paper movement path. Check if you can see something like that near the point where the paper stops.
-. The second option will be dirt on the feed rollers. If you can remove them easily the you can try to clean them using water and soap. In that case what is happening is that the paper reaches the first sensor but the printer doesn't knows the paper is stuck until It detects that the paper arrives later than expected to the last sensor (a timing issue). As the printer keeps printing this is the most probable cause to your problem.
I don't know that model of printer in particular but I hope this serves you as a guide to pinpoint the issue.
Jul 07, 2012 | Epson Stylus C66 InkJet Photo Printer
My Dell AIO 924 printer will not feed paper.
1.Check inside the printer to see if you have the ink properly installed.
2.Make sure you don't you re-use papers that you have already used.
3.All papers have to be perfectly allined.
4.Check the connection wires between the computer and the printer.
5.Scan your computer with a security system to catch and eliminate viruses,tracking cookies etc.
If all else fails I don't know what to say
Jun 24, 2012 | Dell 924 All-in-One InkJet Printer
PRINTER IS JAMMED SHOWING ERROR
I had a similar problem, my printer was chewing the paper and then I was getting a jammed paper message. I looked inside but couldn't see much anything. I then removed (unscrewed) all the panels, and next I know, a culprit materialized, in other words, something fell inside the printer. I then managed to put it all back together, ended up with a few extra screws, but heck it works like a clockwork. God bless screwdrivers with magnetic tips, they made my life so easier.
May 23, 2012 | HP Photosmart C6180 All-In-One InkJet...
Everytime I send something to print the printer starts normally, it grabs the paper to start printing but then the paper never moves again. It sounds as though the document is actually printing but theres...
I don't know what printer you have, but this applies to all printers. The first paragraph is just for inkjets. The the whole is related to laser printers.
85% of paper jams are caused by worn rollers. The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease.
Metal Tab Separation- Pull out your paper tray and examine either end where the paper sits in. If any of the corners are held down by metal tabs, this is your paper feed system. Chances are, you only have one rubber roller or one set of rollers arranged along side of each other. Reach in where the tray goes and feel up. You should feel some rollers. They might be completely round, or they might be shaped like a half moon. Clean whichever part of them you can with the solution, and this should stop your paper jams. It might be necessary to turn them, but don't force them if they don't move freely.
Pickup Roller and Separation Pad-
If your printer uses this paper feed system, you should see a small piece of flat or slightly curved rubber or cork. It would be towards the end of the paper tray, or deep inside the paper loading cavity on top loaders. This 'separation pad' rubs against the paper feed roller, so if you find the pad, you've found the roller. Clean it and your jams should stop.
Three Roller Paper Separation System- Pull your paper tray out, and look for a roller on either end of it. If you find one, clean it. Then look inside the printer where that roller would rest with the paper tray inserted. You'll find another paper roller there. Clean this one also. Finally, look further back or closer to the front of your printer (depending on which way your paper feeds) to find another roller or set of rollers. Clean all of these, and your paper jams will go away
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 15, 2011 | Office Equipment & Supplies
13.02.00 paper jam on tray 2. i have removed the tray and even the catridges but can't find any paper. I don't know where the sensor is as this may be the cause as well. Please need urgent...
Number 1 you failed to mention what kind of printer you have.
Number 2 when you print, does paper even feed into the printer?
When was the last time that you replaced the feed rollers?
Yes it is possible that a sensor is jammed. Before the 13.02 error,
did the printer actually have a paper jam? If yes, was there a piece of paper
missing from the jammed sheet or was it whole?
The photopaper tray goes in, but the printer feed cant grab the paper. it is the correct direction, so i don't know whats going on.
Sometimes the printer does not feed the paper because it is too thick. Try to check the GSM of the photo paper, it should be 180 or 235.
Jun 27, 2011 | Office Equipment & Supplies
Paper will not feed crumbles on right side will not feed through
Remove the sheets of paper from the feeder. Grab a flashlight ang take a look into the feeder for any debris or foreign objects that could cause this problem. If none, unplug and replug your printer into the power source to reset it. When the printer turns on, load some paper (don't overload). Try to print again. If problem continues, please don't hesitate to contact Lexmark technical support for additional assistance.
Apr 26, 2011 | Lexmark Interpret S405 Wireless All-in-One...
URGENT .. really need help sir.. my Printer Canon MX328, don;t want to feeding the paper. i don't know why . and sometime if the printer can feeding, 80% gonna be jammed. please help !
From your description,it seems that other material present inside your printer and blocking the paper path. Sometimes,broken paper feeder indicates the same way. I recommend you to bring your printer to the nearest service center unless you are quit familiar with assembly and reassembly of this printer.
Source:
Printer Clinic
Download Instant Manual
Feb 19, 2011 | Canon Office Equipment & Supplies
VeriFone (M19755014US1) Magnetic Card Reader Logo
118 people viewed this question
Top VeriFone Televison & Video Experts
Marvin
Marvin
AliennoisE
Andrew Taylor
Andrew Taylor
Are you a VeriFone Televison and Video Expert? Answer questions, earn points and help others
