I have a Presario 916us. When it sits idle for a while the monitor goes black and I cannot get it out of "hibernation". I've tried every key and combination and nothing seems to work. Any suggestions?
  • 4,806 Answers
If the operating system is vista, then is has gone to sleep, all you have to do is press the on/off button
you can change the settings, go to the control panel > power options and on the left you will see "change when the computer sleeps"
hope this helps
regards
Posted on Nov 19, 2008
My Dell Inspiron 560 will turn on and I get the setup screen but then it goes into hibernation mode. When I get it out of hibernation the screen is black but there is a faint light on it. I can't get...
Sounds like your monitor or video card is bad. To isolate the problem try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays and works ok, then your original monitor is bad. If the Borrowed monitor does the same thing as your original monitor, then the video card inside the computer is bad.
May 18, 2012 | Dell Computers & Internet
MY LG Monitor W2343T gos blank after a couple of minutes of displaying the desktop. I have replaced the power cable, but still same problem. If I press the red poer button it comes back and then almost...
The monitor is most likely defective and it enters in a hibernation state by itself even when there is signal.
Look in the monitor settings to see if your monitor has any power states.
If you monitor goes black after a few minutes of displaying the desktop while you not being near computer(mouse or keyboard then it's normal to enter in a hibernation mode), if you move the mose it should go back up
If the monitor goes into a hibernation mode while you work/are on the computer then this is not normal, RMA The monitor asap if it has a warranty.
Jan 06, 2018 | LG W2343T-PF Monitor
Hi please help me, my compaq presario 1700 flickers then i dont see anything the screen turns into black, but the sound is ok and its not hibernating, and overheating, but sometimes it comes back to normal...
This is most likely an hardware related issue in which case you need to get it checked. To narrow the issue, you can try hooking up your laptop to an external monitor if possible and see if it does the same. If not, then there's probably an issue with the displays internal connectors. You can also try powering your laptop with only the power cable attached and without the battery, then reset all power management settings. If the problem goes away then it's probably a power management issue.
Apr 18, 2011 | HP Compaq Presario 1700T Notebook
I wiped off my computer keyboard and did npt notice anything happened when I did. When I went back to use the computer, the yellow "sleep" light was on as it usually is after sitting a while. I...
You might have put the computer into hibernate; have you tried pressing the power button? It should wake the computer up if it is asleep or hibernating. It is also possible that your monitor cable is unplugged.
Mar 07, 2011 | Sony VAIO PC Desktop
I have an LG Flatiron W2361V monitor purchased in December. After sitting for about 3-4 minutes, the screen goes black (I guess into hibernation?) but comes right back on if the keyboard is touched. I...
Check if the screen saver is set to come on at 90 minutes, and the VGA cable, is tightly connected at both ends, if so, it might be a virus, check your virus detecting software,
Nov 03, 2010 | LG Computers & Internet
When on computer for some time monitor goes black
Adust the "Power Settings" in the Control Panel to never let the Computer or Monitor power off or Hibernate.
Jan 25, 2010 | HP Pavilion a810n (PP164AA) PC Desktop
I reformated my computer and had it on hibernate and went to sleep.I woke up and now the screen on my desktop pc just flashes about every 3-4 seconds.the screen stays black the flashes with white streaks...
Hi there
i read your report. OK go to your power options and turn off your hibernate and restart your computer.allot of times after you have reformatted your hard driver. the hibernation doesn't work correctly. Try this tip and let me know how it goes. Thank you for writing to fix ya.
Best Regards Richard
Dec 03, 2009 | HP Pavilion F1703 17" LCD Monitor
Monitor flickers then goes to black/blank screen.
have you tested it for gone conponments
Aug 14, 2009 | Computers & Internet
Cannot get by dell screen to come back on once it hibernates
sounds like a power scheme setting is shutting off your monitor after a time-out period. sometimes monitor will not return without re-boot. change your power options settings in control panel.
May 16, 2009 | Dell Inspiron 6400 Notebook
Mymonitor is black and the on button from the monitor is green and is flashing
i havent seen this question asked, and believe me i have searched. i have compaq presario, windows xp media edition 2005, 64 amd processor, model # SR2017CL, with HP 1703 17" monitor. Prob-put computer in hibernate mode other evening, without turning it off. when i woke up, screen had diagonal lines going across it. i rebooted, well manually restarted, since comp would not respond.
Message comes up white with black writing, essentially, prob with active desktop, restore or turn off. i tried to turn off and screen went back to diag. lines. looks like the horizontal hold of a tv screen is asque. tried adjusting monitor to no avail.
tried a few more times, was fine for a few mins then went to same thing. now when i turn monitor on it blinks red, blue, and so on.
just whole screen that color. so i am at the point where i dont
know if its the comp or the monitor. (i am quite a newby)
ty for any help you can give
ellie
Jan 30, 2008 | HP Pavilion F1703 17" LCD Monitor
Computers & Internet Logo
Alun Cox
David Payne
David Payne
