Question about Desa International GWP20T GLOWARM Wall Mounted Panel Heater
I have a DESA gas wall heater.
The pilot light will come on but when the gas is turned on the pilot light goes off so I can not get it lit. It has always worked good until now.
  • countrstrike Dec 03, 2008
    Are these two above the only solutions to this problem?
  • Anonymous Dec 13, 2008
    pilot light on my wall heater lights but the heater will not come on,,,,blower doesnt work,,, nothing happens when you adjust the thermostat
Are you sure you have valve in pilot position . Sounds dumb i know . I had same problem that is what it was .
Posted on Nov 22, 2008
Take the heater off and have it blowed out. we did that to ours and haven't had a problem since.
Posted on Nov 20, 2008
My husband and I recently purchased a house that has a Comfort Glow Vent-free Propane/LP gas compact fireplace 14,000 to 26,000 BTU/Hr with Thermostat. Model CGCFTP We need to light the pilot light and it...
Remove the small copper colores tubing going from the gas valve to the pilot assembly. Take it to a good hardware store that sells heaters and ask them for a new one.It is called a thermocouple.
Nov 18, 2009 | Desa International Heating & Cooling
I have the DESA CBN20T Wall Heater. The pilot
take your gas lines off and blow compressed air though the lines blow out all the dust and stuff too
Nov 06, 2009 | Desa International CBN20T Heater
Pilot light will stay lit as long as i hold down the knob, but when knob released, light goes out....... i have a wall mount model# GWRN30t
Normally when you release the knob it work the same as a two way switch ,which mean gas will stop flowing through the small pilot channel and will flow to large channel where it will continue to burn.
In your case, you have to strip down the regulator switch and look where the gas passage is glogged.
Oct 05, 2009 | Rinnai Desa Vent-Free Infrared Gas Heater:...
WE can get the pilot light lit but it will not stay on
You will need to check the pressure regulator for the gas.
It sounds like the gas pressure is to low to keep the pilot lit.
John
Oct 01, 2009 | Desa International Blower Glow Warm Wall...
Ventless gas wall heater. Pilot lights but wont stay lit.
The thermocouple may be worn out.
The thermocouple may have come loose from the valve.
The ODS pilot may be clogged with dust or lint and may need to be cleaned with air(less than 30psi)
The valve or regulator may be faulty.
Sep 30, 2009 | Desa International GWP20T GLOWARM Wall...
The pilot light will not stay lit after I let the button go to turn on the heater.
you most likely have to replance the thermocouple, its a safly feature that tells the gas valve that there is a flame present, if its not working its telling the gas valve that the pilot is not on and not to turn on the gas. If you look at your pilot light its a small metal rod that sticks into the flame, it should trace back and go directly into the gas valve.
Feb 11, 2009 | Desa International GWP20T GLOWARM Wall...
Heater will not stay lit
sounds like the thermocouple is going out this is the part the flame from the pilot burns on and tells the gas valve to stay open by producing a small amount of electrical current in milli-amps these can be purchased @ a good hardware store and you must position as it is when it comes out , and must be the same length , make sure to connect to gas valve clean and tight , also is there a moisture trap in the line if so you might need to turn off gas and make sure it is free of moisture , this is a good place to start with these items
Jan 16, 2009 | Desa International GWP20T GLOWARM Wall...
Desa International GWP20T GLOWARM  Wall Mounted Panel Heater Logo
108 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
