Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
Panasonic Television Problems
Sometimes my Panansonic Television won't turn off when I press the power button. For the past 2 days I have had to unplug it to make it go off. Also, for the most part the volume works fine, but every now and then the volume goes out and it won't come back on for days. Even if I try and turn it up, it does nothing. Can someone help?
  • 81 Answers
Replace the relay
Posted on Dec 15, 2006
How to reset lamp w/o remote panasonic pt-52lcx16
Instructions
    • 1 Pressicon1.png the "Power" button on the TV remote control to turn the Panasonic rear-projector TV on and display a picture on the screen.
    • 2 Press the "Menu" button. The "Main Menu" will appear on the screen. Press the "Option" button.
    • 3 Press the "Enter" button. The "Optional Menu" screen will appear. Press the button to select "Lamp Runtime."
    • 4 Press the "Enter" button and hold it for about three seconds. The "Lamp Runtime" will change to display "Time Reset (Powericon1.png Off)."
    • 5 Press the "Power" button to turn the TV to the off position.
    • 6 Unplug the power cord from the electrical socket. Wait about one minute and plug the TV into the electrical socket
Read more: http://www.ehow.com/how_7201809_reset-lamp-timer-panasonic.html#ixzz33LeXpAsl
Jun 01, 2014 | Toshiba 37WLT66 37 in. LCD Television
TC-32LX700 WON'T TURN ON
My Panasonic does this periodically. I have to unplug it for a moment and then plug it back in. Sometimes it will turn right on, sometimes I have to press the on/off button. I wish I knew the root cause.
Nov 10, 2012 | Panasonic TC-32LX700 Television
Samsung HLN5065W Color/Power problems
Good day!!!!
Kindly check the power supply board..Look at the capacitors within check the visual condition if it is look like bulged,leak or burnt..
If that so,try to replace it with the same type ratings and value..you can order that parts on local or online..
This is the sample images:
Dec 19, 2011 | Samsung HLN5065W 50" Rear Projection...
Our panasonic HD tv displays every time we turn it on that the LAMP LIGHT needs to be replaced.....we replaced it.......it still pops up and last for about 2 minutes every time we turn on tv
Sir reset the lamp hour meter this will resolve the problem. Follow this instruction.
  • 1.Turn on your Panasonic television.
  • 2. Press and hold the - volume button on your television. Continue to hold the volume button and press and hold the "PIP" or "SPLIT" button on your remote control.
  • 3. Hold both button for five seconds and release. A message appears on your television screen indicating the meter has been reset.
  • Sep 16, 2011 | Panasonic PT-60LCX64 Television
    Won't program to our new TCL television - we have the 222 receiver
    I don't show we have a code for the TCL (Australia) brand TV. Below I have provided instructions on how to perform a power scan.
    • Remote: Basic Remote (Television Only)
      1. Turn the Television On.
      2. Press and hold the clear TV button for three seconds until the LED flashes.
      3. Press and release the red TV Power button.
      4. Press and release the Up or Down Arrow on the remote until the television turns off.
      5. After the television turns off, press and release the # button.
      6. Test functionality with the TV.
      7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
    Aug 14, 2011 | DISH Network IR Remote Control
    I have a panasonic projection TV, PT-60C13 that will not turn on. Upon pressing the power on button, the button flashes green many times, then flashes red five time then one orange flash. This red/orange...
    The most common cause of Panasonic Rear Projection LCD TVs not starting is bulb failure. The PT-60LC13 users manual gives some help in translating the LEDs on the front of the TV.
    If the TV worked normally for a period of time (months or years) and won't start, the most likely cause is bulb failure. There is no way to measure the bulb, sometimes the bulb is visibly damaged when it fails. Remove the Lamp Assembly and look at the bulb.
    If there was an On-Screen Lamp Replace warning and TV won't start, bulb has failed.
    The first step with all Panasonic Rear Projection TV "No Picture" problems is bulb replacement. If that does not remedy the problem, get a technician, there are no user serviceable parts. Guessing if the ballast, power supply, controller board or optical engine is faulty is not practical.
    The Panasonic Lamp Gallery shows all Panasonic models and Lamp Numbers. There is also a link to Panasonic DIY bulb and lamp replacement.
    easyab
    May 05, 2011 | Panasonic PT-60LC13 60" Rear Projection...
    Help my 42 inch panansonic plasma tv will not turn on red light just blinks
    Hi:
    Replace or have the power supply serviced, the most common failure with panasonic plasmas is tthe power supply.
    Dec 23, 2010 | Panasonic TH-42PZ700U 42 in. Plasma...
    Panansonic rear projection TV Convergence needed
    Go to this web site and Print out information on How To Enter Service Menu http://www.freelist.org/archives/techassist/09-2005/msg01111.html Read this very carefully when trying to get into service menu its no easy walk in the park, i hope i never have to set convergence on another myself. (1) Switch to cable (2) Set sleep timer 30min ,exit menu , now enter channel 124, Press vol- on tv ,at zero volume a Red Ck should appear , Re enter menu turn sleep timer off ,Now Press power untill you see oVoo using ch+ Adjust to OV1 ,now Press vol+ You should now be in convergences---- Mute locks- cursor to move- vol-&vol+/ch- ch+ to ajust lines---- Press R-Tune to switch color to adjust When done Press (7) to save then Press Then Press and hold power and action for 5 sec . GOOD LUCK.
    Dec 15, 2008 | Panasonic PT-51HX41 51" Rear Projection...
    My Panansonic TV shuts down every few minutes and the LED blinks three times
    I still have that problem. I calle Mfr and also spoke to repair shops recommended by them and they said they estimate a cost of 300-400$ or so approx. I am waiting to buy a new LCD which could be few 100 more but at least dont have to live with the old one and keep spending money...
    regards
    Oct 07, 2008 | Panasonic PT-47WX49 47" Rear Projection...
    Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
    Top Panasonic Televison & Video Experts
     Grubhead
    Grubhead
    Demonic-2011
    Demonic-2011
    Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
