Keyboard number pad not working, number lock is on
  • 3 more comments
  • flynnnone Nov 20, 2008
    Dell computer, tried switching out keyboards, XP recognizes new hardware, everything else works on the key board, Num Lock light is on.
    Desk top unit, no Fn key on keyboard
    Yeah, I've already stated that the num lock light is on...tried that several times before switching out the original keyboard.
  • Alan Matzke
    Alan Matzke May 11, 2010
    what model of gateway do you have, what windows are you running,
  • vicky bliss May 15, 2013
    i am using Windows 8 - new compaq computer. My num lock is off even when the light says it is on
Switch on pc
Posted on Mar 12, 2011
  • 4,806 Answers
Hold "Fn" down and hit the "Num Lock" key
regards
Posted on Nov 19, 2008
  • Lee Hodgson
    Lee Hodgson Nov 20, 2008
    look at the top right of the keyboard and just hit "Num Lock"
    regards
  • Lee Hodgson
    the keyboard command should have released the num lock, if it has not, then the keyboard itself may be faulty, to test this theory try the keyboard on another computer
    regards
Key pad is not working in excel and there is no num lock key
there is a number lock for all models. simply do one thing use on screen keyboard to unlock the num pad
Aug 20, 2013 | Logitech Wireless Solar Keyboard K750 -...
Number pad on wireless keyboard not working
turn on your numeric lock............can be enabled in BIOS, should be same as on corded type.... The Print Screen key does not work. Try the following:
  • The Print Screen key copies an image of the screen to the clipboard (not the printer). To use the image, start an application that uses graphics, such as Microsoft Paint, and use the Paste function.
  • If your keyboard has an F Lock key, press it to toggle between Function key modes. On some keyboards, the Print Screen key only works if F Lock is on.
Good success, meder's tv service
Jul 17, 2012 | Computers & Internet
Number pad on microsoft wireless keyboard 5000/1045 not working
Charlotte;
Try using CTRL, SHIFT, and NUMBER LOCK. You may have accidently shut down your number lock.
Jul 17, 2012 | Microsoft Wireless Laser Desktop 4000...
I cleaned my keyboard while turned on and now I cannot get my number pad to work, which buttons did I accidentally push to get to turn off and how can I get them back on.
Based on your description of the problem you're experiencing, it sounds like you most likely pressed the "NUM LOCK" key. If NUM LOCK was activated before you cleaned the keyboard and was accidentally pressed during cleaning, this key press would deactivate NUM LOCK, causing the number pad to stop responding. To reverse this, simply press NUM LOCK again. The NUM LOCK button is located right above the "7" key on the number pad (see picture below).
Alternatively, since the setting determining whether NUM LOCK is activated when your computer is started is stored on your hard drive, you can try restarting the computer to revert back to an active NUM LOCK. Be sure to try this in case the first solution above does not work.
If you found this solution helpful, please leave a positive rating!
Sep 06, 2011 | Maxi Switch Silitek SK 6000 Keyboard
I`m using a wireless keyboard because the one on my laptop works but it has trouble on the part that has numbers witch are the letters .
From you're description it sounds like the "numb lock" check my be on. (numbers lock). On most keyboards you turn it on when you want to use the numbers pad. Or it may also be some other key shortcut on that keyboard which switches it to a numbers pad.
Feb 25, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
My number pad on my keyboard is not working, how can I reactivate it?
At the top, left corner of the number pad, there should be a key that says "Num Lock." This key toggles the functionality of the number pad keys between Numbers and Directions.
Press Num Lock once and the numbers should start working again.
Press it again, and the keys should go back to the Directions (up, down, left, right, Page Up, etc.)
Jan 11, 2011 | Gateway Computers & Internet
Labtec USB Number Pad for Laptops with 2 extra USB Ports
I bought this number pad and had the same problems.
I found this fix. download this from the labtec site. http://www.labtec.com/pub/techsupport/keyboards/usb_numpad_for_notebooks_1.0v.exe This worked and the number lock off changed from grey, number lock off to, yellow number lock on and back again.
This appears to be a later driver update.
Mar 17, 2008 | Labtec USB NUMBER PAD FOR NOTEBOOK 2 BUILT...
Keyboard
have you tried using the numeric pad while the num lock key is turned on? if this doesnt resolve your problem, you're gonna need a replacement keyboard.
Nov 27, 2007 | Acer NSK8458AN Keyboard
My numbers aren't working and my num loc is on
i got it!! hold down the 2 shift keys for a few seconds then bamm!!
Sep 08, 2007 | Targus USB Ultra Mini Keypad Keyboard...
Computers & Internet Logo
1,307 people viewed this question
Alun Cox
David Payne
David Payne
