Question about HP Computers & Internet
I am installing a second hard drive that is sata. Which motherboard socket do I plug it into and is it hot swappable?
  • Greg9845 Nov 21, 2008
    Yes, I see them. They each have a different color. Which one is appropriate for adding a second Hard Drive? Or does it matter?
    Genius:
  • 1,913 Answers
U see in corenr of mother bord 4 sata sockets.
pluginto it.
Posted on Nov 19, 2008
I have just received the hard drive casings ECS_U35K. I followed instructions. I cannot get Windows 7 to recognize this drive. Any help would be much appreciated.
Sabrent website indicates that this enclosure is compatible with your operating system
http://www.sabrent.com/category/hard-drive-enclosures/ECS-U35K/
this is just an enclosure and you have to put in your hard drive in it.
Supports Standard Desktop 3.5? SATA/SATA II Desktop Hard Drives.
Supports hard drives up to 2TB.
Ultra Light Aluminum Case provides heat dissipation.
On/Off power switch.
LED light indicates Power and Activity status.
Hot-swappable, plug and play, no drivers needed.
Reverse compatible with USB 1.1.
Sep 14, 2011 | Televison & Video
Sabrent didn't come with drivers for windows vista and 7
It states online that it is "Plug-in-Play" and that it doesn't need drivers.
Hope this helps!
Remember to give me 4 Thumbs Up for Helping out the Community :)
~~Dayminner
Jun 03, 2011 | Sabrent EC-7F83 Hard Drive Enclosure - 3.5...
Bios setup does not show sata HD windos xp find them
I have had problems like this many times with some of my IBM machines. What i find most often the reason the bios will not recognize them is because the hard drive has gone bad.
Troubleshooting 1. Unplug power cable from computer before doing anything inside of the computer. Unplug sata cable from motherboard and hard drive. Unplug power cable from hard drive.
Plug the sata cable back into the motherboard and into the hard drive. Plug the power cable back into the hard drive. Plug the power cable back into the computer.
Boot computer and enter bios(by pressing F8, Enter, Del ect..) Does the hard drive show in there now?
2. If you have another hard drive.
Unplug power cable from computer before doing anything inside of the computer. Unplug sata cable from hard drive. Unplug power cable from hard drive.
Plug the sata cable into the second hard drive. Plug the power cable into the second hard drive. Plug the power cable back into the computer.
Boot up the computer and enter the bios. Does this hard drive show in the bios? If so then i would say that your original hard drive has gone bad.
Apr 20, 2011 | Abit AV8 Motherboard
How do i install a wdeads hard drive? where is the power supply (4pin Molex)?
I'LL TELL YOU UPFRONT i HAVE ONLY INSTALLED SATA ON A NEW SYSTEM SO MY ANSWER MAY NOT BE CORRECT IN ALL SITUATIONS
Question is vague. Are you replacing a drive or building a new system? SATA drives have a dedicated plug on the Mother Board. Of course you already know you can't replace an IDE with a SATA without an adapter (Ebay has them for about $8) or the Bios is incompatible. The power is on the Motherboard and does not have a connector from the power supply like an IDE has.
Feb 20, 2011 | Western Digital WD15EADS 1.5 TB SATA Hard...
Want to install a second sata hard drive, new drive not auto detecting, bios only identifies ide drives
HI popsrowe
Your problem is most likely the SATA data and power cables. for tips on the two cables. the system should detect the SATA hard disk automatically,
( you only need, setting the hard disk support as a second hard disk to the system in the bios setup )
regards
Jan 15, 2011 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
Can i instal sata hard disk in intel desktop d101ggc
Yes, according to the manual the board has four SATA interfaces. SATA is backwards compatible, so the only risk is not to get the maximum speed. Be aware that if you are replacing a drive, the set up procedure might require initial drivers before setting up the OS. You will need also 1 piece of SATA cable, fout bolts for attaching the disk, and maybe a power adapter joint if the disk has just newer standard socket and your power supply does not have such jack. If you are installing the disk as a second drive for storage, the set up will be far more easy.
Nov 11, 2009 | Intel D101GGC Motherboard
How to install a 2nd sata disk drive - do I need a 2nd sata cable?
Yes you need one SATA cable for each SATA device.
Biggest thing is to make sure that your motherboard has enough SATA ports available to accomidate another SATA device
Sep 27, 2009 | Western Digital Caviar SE WD1600AAJS 160...
Difference between HDD and SATA
Buying a new SATA hard drive is confusing if you don't understand the differences between the various drive types. Which hard drive should you buy?
SATA Hard Drives (Serial ATA) are the most popular drives being sold today. Alongside them in the store however you will also find boxes labeled Parallel ATA or SCSI. So what are the differences between these hard drives and which one should you purchase? Your decision is dictated by what your computer can accept. Check with your computer's manufacturer to see which drive style you can use. Most newer computers purchased within the last two years accept SATA connections. If your computer cannot accept one of the newer SATA hard drives you can purchase SATA adaptor cards that plug into an empty expansion slot on your computer's motherboard. You can purchase SCSI adaptors as well, so follow these tips to guide your decision.
SATA vs PATA: Serial ATA vs. Parallel ATA Drives SATA hard drives have many benefits over their older cousin, the Parallel ATA drive. Chief among these differences are:
  • SATA hard drives are faster and perform much better than traditional ATA drives and are better for high bandwidth applications such as video editing and multiplayer gaming.
  • SATA drives use a smaller, cheaper cable to connect to the computer's motherboard. These cables can also be up to three feet in length compared to eighteen inches with Parallel ATA cables.
  • SATA hard drives can be hot swappable, meaning that they can be disconnected and reconnected without powering down the computer. There are limits to this of course. You should never disconnect your boot drive while the computer is operating.
  • SATA cables are easier to plug in without damaging the delicate connecting pins on the drive.
  • SATA hard drives are significantly faster than external USB hard drives.
SCSI Hard Drives SCSI hard drives are the elders of the storage world. SCSI is one of the oldest specifications but it is also the fastest and thus has been widely used in network servers and other high speed, high bandwidth applications. Unfortunately this high speed storage has also meant much higher costs. SCSI drives were once standard in all Macintosh computers but have since been replaced by the cheaper SATA based hard drives.
  • SCSI drives are also hot swappable, similar to the SATA drives.
  • Some varieties of SCSI can be used with SATA
  • SCSI drives are often set up in a mirroring arrangment to allow for instant, continuous backups of the hard drives.
  • SCSI drives are still the most expensive drives on the consumer market.
Your basic rule of thumb should be to purchase a drive that is designed to work with your computer's motherboard. Try to avoid using SCSI adaptors or SATA adaptors unless absolutely necessary as the whole point of using a specific kind of hard drive is to get the most speed and storage for the money.
Thanks alot,
Sanjeev Kumar
Jan 22, 2009 | Tablets & eReaders
Installing new harddrive
So you want to Install a new Hard Drive?
Im assuming your New Hard drive is a SATA connector. Reply if it isn't.
Open up your computer case and look for the current hard drive. place the new hard drive in a free spot and screw it in. then plug in the SATA power cable and then the SATA interface cable and the other end on the motherboard by locating a free socket usually orange (Gigabyte Motherboard).
If you do not have a SATA power connector, you can get a Molex to SATA converter or you should buy a new power supply that has SATA power connectors.
Oct 08, 2008 | Computers & Internet
Installing 4 SATA hard drives on the GA-8KNXP mobo
check motherboard manual it seems you may have the sata drives plugged into wrong number socket they should have numbers on them sata 1 etc
Jul 28, 2008 | Gigabyte GA-8KNXP Motherboard
Computers & Internet Logo
111 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
