Question about Microwave Ovens
Clock won't keep proper time - Microwave Ovens
  • William Miller
    William Miller May 11, 2010
    The
    first thing I would suggest is a hard reset. Unplug the unit for a
    minute or so. Then plug it back in, set the clock and try again.
    If that doesn't work, leave it unplugged for maybe an hour.
    Then let us know if the hard reset does not fix it and Please reply back with your brand and model number so we can help you.
  • William Miller
    The
    If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
  • 456 Answers
If your clock is not keeping the correct time and you have done everythinh right, the problem lays within the IC or M icroprocessor on the Printed Circuit Board which the lcd clock display is attatched too.
Posted on Nov 27, 2008
KEEPS TELLING ME I NEED TO SET THE TIME AND THEN I SET THE TIME AND THEN WHEN I TRY TO USE IT IT JUST KEEPS GOING BACK TO SET THE TIME AGAIN
Hi Kristen
You MIGHT have to press "clock", set the time and then press "clock" again to complete the operation. What make and model of microwave is it?
-Steve
May 28, 2015 | Microwave Ovens
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
I have maytag advance cooking system(electric) and the oven will not work.The timer to set the oven and the time is not lighting up but the stove is working.any sugestion
try resetting the clock. If it is digital, push the clock button and then the number buttons untill you have the proper time displayed...then push the clock button again. If your clock and timer are manual, try pushing in the clock lever and turning it 1/4 turn. If this works it would indicate that your timer has a start and finish time and that the oven is not working because the clock has rotated around to the finish time.
Sep 09, 2011 | Microwave Ovens
Won't turn on after disconnecting the power code from the wall socket,
Press stop / cancel
Then press Clock
Enter time
Press clock.
It should now be working normally. If not respond here again and I will help you.
Thanks for choosing FixYa,
Kelly
May 12, 2011 | Whirlpool MH6150XM Microwave Oven
The colon between the numbers on the clock, example 8:00 won't stop blinking even after I set the clock and hit the clock button again.
Sometimes the correct procedure for setting the clock is to press the CLOCK or TIME OF DAY button, then enter the time on the keyboard, then press the START button instead.
Otherwise, as long as you can enter a cooking time and your oven operates normally, then don't worry about it. On some models it is normal for the colon on the clock display to blink all the time.
Good luck.
May 11, 2011 | Microwave Ovens
Dont know how to set clock
hello there:
to set the time on you're micro wave you will need to push the clock button and use you're number pad to enter the time and once you have got the time set properly you will need to press the clock button again.... hope this helps you out sincerely D.Jones
Jun 06, 2010 | Goldstar MV-1501 Microwave Oven
Set clock
Does it have a clock button. If so simply push clock, input the time then clock again.
Nov 28, 2009 | Microwave Ovens
Westinghouse microwave WST3502..... Problem:
Press "Clock", type in the time on the keypad and then press "Start". The clock runs a little slow (at least on mine) and I have to reset it about once a month. It gets about 10 - 15 minutes behind after awhile.
Sep 06, 2008 | Westinghouse WST3501 Microwave Oven
Microwave Ovens Logo
97 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
