Question about Gearbox Toys 2.5' John Deere Stamp Stell Tokheim Gas Pump
I need help with a tokheim dispenser 262A can somevary help me
Ice dispenser and water dispenser does not stop after use.
Hello Junhee, thank you for your post!
From what you have described your ice and water dispenser on your Frigidaire refrigerator continue to dispense after being used. This could be a possible issue with your dispenser or the switch inside of the dispenser. I would recommend looking over the dispenser to assure there is no visible damage done to your dispenser. You may need to have a technician out to perform a proper diagnosis and repair. This will help you avoid any unnecessary part purchases. I hope this information is helpful. -Matt
Dec 19, 2015 | Frigidaire Refrigerators
R52WH73 convergence HELP!!!
If the convergence adjustment is not moving the beam chances are theconvergence IC(s) are defective. If you know how to solder andunderstand TV safety you may be able to fix it. With power disconnectedremove the back. You should see two large heat sinks with large ICs (3by 6 inches) with about 30 leads going through the circuit board.Numbers on the ICs should usually be something like STKxxx-xxx or somevariation with x being a number. These ICs control the position of thethree beams. If they go bad you can't adjust one or more beams. Replacethem both as you don't want to get in there again in 3 months. Cost isnot that much. http://www.tritronicsinc.com or http://www.partstore.comshould have them at a reasonable price. Before replaceing the ICs lookat the circuit board closly for cracked solder joints. Resoldering anybad joints might just solve your problems and avoid replacing the ICs.Good luck and remember safety.
Aug 01, 2008 | RCA R52WH73 Projection Television
Top draw is stuck on rinse / can't move push button to go on anything else
make this tests and fix it. God bless you
Dispenser Lever
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Detergent Dispenser Cover
If the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Wax Motor Actuator
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
Detergent Container
If the dishwasher dispenser doesn't work the detergent container may need to be replaced.
Dispenser Lid
If the dispenser is broken and doesn't open or close properly the dispenser lid may have to be replaced.
Detergent Dispenser
If the dishwasher dispenser doesn't work the problem is often related to the release mechanism. If the problem is with the dispenser itself, it may be easier to replace the entire dispenser.
Dispenser Door Spring
If the dispenser is broken and doesn't open during the wash cycle the dispenser door spring may have to be replaced.
Dispenser Latch
If the dispenser is broken and doesn't open or close properly the dispenser door latch may have to be replaced.
Dispenser Door Pin
If the dispenser is broken and doesn't open or close properly the dispenser door pin may have to be replaced.
Dispenser Actuator
If the dispenser is broken and doesn't open or close properly the dispenser actuator may have to be replaced.
Dispenser
If the dispenser is broken and doesn't open or close properly the entire dispenser assembly may have to be replaced.
Wax Motor
There is an electrically powered device called a wax motor which opens the detergent dispenser. If the dispenser is broken and will not open to release the detergent, the wax motor might need to be replaced.
Bi-Metal
If the dishwasher dispenser doesn't work the bi-metal actuator might be burned out or defective. The bi-metal is a simple metal loop which acts as a latch for the dispenser door. As electricity is applied to the metal loop, the loop deforms and bends away from the latch, releasing it. If the bi-metal is burned out it won't deform or release the detergent door.
Dispenser Slide
If the dispenser is broken and doesn't open or close properly the dispenser slide may need to be replaced.
Dispenser Repair Kit
If the dispenser is broken this dispenser kit may need to be replaced.
Main Control Board
The main control board provides power to nearly every component of the dishwasher including the detergent dispenser. If the dispenser will not actuate the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Jul 24, 2013 | Fisher and Paykel DD605FD Stainless Steel...
How much salt do I put in ,,, and why won't it
follow this steps and fix it. God bless you
Dispenser Lever
Wax Motor Actuator
Detergent Container
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
Jul 08, 2013 | Dishwashers
How can I find fairly used tokheim fuel dispensing pumps. In UK.
A fuel pump is either directly connected to the fuel tank or in some cases inside the fuel tank. You would need to consult your owners manual.
NEC Dash Programmer ECU Flasher
Dec 07, 2012 | Cars & Trucks
I have LG washer less then 1 yesr old and bleach is not dispensing from dispenser
You may have one of 3 issues. The dispenser valve is not working for the bleach dispenser, the control board is not feeding power to the dispenser valve or the dispenser drawer is not draining the bleach properly. You will need an authorized LG technician to help you with that.
Good luck
May 30, 2011 | LG WM2701HV Washer
GE WSXH208AWW doesn't dispense detergent, softner or bleach. Dispenser is totally dry after wash cycle.Appears no water gets to tray.
I'm having almost the same problem - the bleach & softener both will NOT dispense, but (LUCKILY) the detergent does dispense on mine, for now.
In order to get the solutions (bleach, softener, detergent) to go into the washer, the water needs to pour through the dispenser somehow. Dry means NOT working (mothmanmeg).
I need help, too!! We tried taking the drawer out & cleaning, no luck.
Apr 17, 2010 | GE WSXH208A Front Load Washer
Ice dispenser/Water dispenser not working
I will need to get your model number to help you better. Thanks Sea Breeze
Jul 26, 2009 | GE Refrigerators
Gearbox Toys 2.5' John Deere Stamp Stell Tokheim Gas Pump Logo
21 people viewed this question
Top Gearbox Toys Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Gearbox Toys Toy Expert? Answer questions, earn points and help others
