Home
My Products
Sign In
Back to:
All Products
Fedders
(AED24E7F) Thru-Wall/Window Air Conditioner
Troubleshooting
Tags
water
LEAKING WATER
water leak
compressor
leaking
No drainage water, room too humid
posted by
alvaro2110
on Dec 14, 2006
Report abuse
Just purchased a refurbished unit and the compresor goes on an off every 2 minutes. I have tried different settings with no changes in results. Room is way too humid and no water is leaking to the outside. Please Help!
Solve This!
I have the same problem.
X
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
OK
Best Solution
posted on Feb 15, 2007
hibby
Rank:
Apprentice
Rating:
82%, 5 votes
Sounds like the compressor is cycling in and out on a safety switch , could be high or low pressure, due to being short of gas for example
Was this solution helpful? Show your Appreciation by rating it:
Inappropriate
Thanks for Trying
Helpful
FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on No drainage water, room too humid:
I don't want to Accept this solution
Done
Suggest a new solution for this problem
Can you Help with these Air Conditioners problems?
Air Conditioners
A/C turns on and cools
A/C turns on and cools but Heating system does not turn on...
Answer This...
Air Conditioners
Smeg gas hob mod PGF
Smeg gas hob mod PGF 75SC...Two electronic ignitors fail...
Answer This...
Air Conditioners
my hampton fan remote does
my hampton fan remote does not work properly the light...
Answer This...
Fedders (AED24E7F) Thru-Wall/Window Air...
Unit shutting off
I have a unit about 3-4 yrs old and using it this summer...
Answer This...
My air conditioner doesn't blow out any air.
When you turn the air conditioner on you can here the...
Answer This...
Let Our Experts
Solve
Your Problems
Ask!
Loading problems.
shah9
Wiz
Let FixYa Experts
Solve Your Problem
Ask!
Repair Service
Find Air Conditioner Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
No
Yes
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
