Question about Philips 105S51 15" CRT Monitor
Monitor I was trying to change the resolution on my monitor and accidently hit a button saying 'Extend screen'. Now my monitor turns on, shows a picture for about 15 seconds and then goes black. No picture. What happened and what do I do to correct it?
I was trying to change the resolution on my monitor and accidently hit a button saying 'Extend screen.
Posted on Oct 06, 2008
LG HDTV Monitor Permenantly switched on but no display white screen with V.2.0.0 moving around the screen
sounds like you are possibly over resolution (setting resolution higher than the monitor can show. Try setting to low resolution and see if it shows up. Try VGA first and move up if it shows.
Jun 21, 2014 | LG Flatron N1910lzbf 19 Led Lcd Monitor 43...
Tried to enlarge the screen and screen went black and now showing this! I turned it off and hit F8! It came on I pressed safe mode! I tried to get on Internet and it locked up again ! Back to this scr
When a monitor displays "Input not supported", the display resolution is set too high. To resolve this, change the resolution to a supported resolution of the monitor.
In Windows XP
  1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
  2. On the Settings tab, under Screen resolution, drag the slider to the desired resolution and click Apply.
  3. When prompted to apply the settings, click OK. The screen will turn black for a moment.
  4. Once the screen resolution changes, confirm the change by selecting Yes. A timer will count down for 15 seconds to ensure the change is desired.
    Click Yes to confirm the change; click No or do nothing to revert to the previous setting.
In Windows Vista
  1. Press the Start button , select Control Panel, select Appearance and Personalization, select Personalization, and then Display Settings.
  2. Under Resolution, move the slider to the desired resolution and click Apply.
Oct 20, 2012 | Computers & Internet
I accidently hit recall on my monitor settings. I now have a smaller veiwing screen with black edges
You didn't say which OS you're using but it sounds like you've changed the aspect ratio of your video signal. Different screen resolutions have somewhat different aspect ratios. The aspect ratio indicates the ratio of the number of pixels of width to those of height. For example: my video driver offers a resolution of 1280 x 960 or 1280 x 720 which would give screen aspect ratios of 1280/960 = 1.33 :1 and 1280/720 = 1.77 : 1. The latter would produce a narrower image. You can compensate somewhat by increasing your horizontal sweep voltage with your monitor menu. A better solution would be to select a resolution that more closely matches your monitor's screen size.
Aug 10, 2011 | Dell D1028L 17" CRT Monitor
Osd lock in my LCD
Check your switchers resolution settings .....
You might have to change your resolution settings....
This solution is for AOC Monitors......
Setting the Optimal Resolution
The recommended resolution for this monitor is 1680 by 1050. To setup the monitor to this resolution, follow the steps below.
  1. Click START.
  2. Click SETTINGS.
  3. Click CONTROL PANEL.
  4. Double click DISPLAY.
  5. Click SETTINGS.
  6. Set the resolution SLIDE-BAR to 1680 by 1050.
External Controls
Press the power button to turn the monitor on or off. The other control knobs are located at front panel of the monitor (See Figure ). By changing these settings, the picture can be adjusted to your personal preferences.
* The power cord should be connected.
* Press the power button to turn on the monitor. The power indicator will light up.
203-35.jpg Hope this helps ,
Rate me please,
Cheers Misterdj
Aug 12, 2009 | X-10 LM929 19IN LCD 12X10-.294MM SPK BLK
BenQ Monitor ' Out Of Range '
check your resolution settings and change to 800><600 and try again.If it does not work at 1024><768 try loading monitor driver In display properties it should show BenQ FP731 instead of plug and play monitor.
Samir
Oct 29, 2008 | BenQ FP731 17" LCD Monitor
Data Shows up only on External Monitor, not on Laptop Screen
If your system won't display anything w/o the external monitor. there's something wrong with the LCD's backlight. you may have to contact your laptop's manufacturer and check if this laptop is still under warranty. you may have to get the lcd replaced.
thanks.
Aug 26, 2008 | Toshiba Satellite A135-S4527 Notebook
Monitor
When your computer is starting up, hit F8 and you'll see the safe mode, safe mode with networking, etc. screen...You should see a choice that says "enable vga mode". Select that and windows will start and the os will select a screen resolution for you. After that, everything will work fine...I hope.
Good Luck!
Anonymous
Mar 15, 2008 | Acer X193W LCD Monitor
Sony monitor desk top wallpaper
While starting the computer Press F8 and boot in safe mode. Now you should change the resolution. For better reply please let me know the operating system.
Best Regards
rafique
Feb 08, 2008 | Sony VAIO PCV-RS720G (027242658103) PC...
Philips 105S51 15" CRT Monitor Logo
145 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Steve Allison
Steve Allison
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
