Question about Whirlpool GR399LXHS Electric Kitchen Range
My display says E2 -F3- what is the problem (electric range)
Ive tried unplugging it and hitting the start/cancel button but nothing happens. the burners seem to work but the oven does not
  • 367 Answers
E2 and F3 three means that your oven is getting too hot. Replace the oven temp. sensor and it will fix it. If you get me the model number i can get you a part number for the sensor.
Posted on Nov 21, 2008
F2 &F3 error codes, oven keeps beeping, I already tried turning off circuit breaker did not solve problem
F2
- E0 Shorted keypad (also called touch
pad) 1. Check keypad connector for firm
connection (keypad connects to control board).
2. Press CANCEL. If error code
returns after 60 seconds, replace keypad (also called touch pad or membrane
switch). Some models incorporate keypad in to control board as one unit. In this
case, replace control board (also called ERC or clock). F2 - E1 Keypad cable unplugged F2 - E5 Cancel key drive line open F2 - E6 Cancel key drive line open F3 - E0 Oven temperature sensor (RTD) opened (upper oven,
if double oven) Replace Oven temperature
sensor (RTD)
Note: Applies to all F3-E...
codes. F3 - E1 Oven temperature sensor (RTD) shorted (upper
oven, if double oven) F3 - E2 Oven temperature is too high (Cook
mode) F3 - E3 Oven temperature is too high (Clean
mode) F3 - E4 Oven temperature sensor (RTD) opened (lower oven,
if double oven) F3 - E5 Oven temperature sensor (RTD) shorted (lower
oven, if double oven) F3 - E6 Warming drawer sensor open F3 - E7 Warming drawer sensor
shorted
Dec 20, 2010 | Whirlpool Accubake RF362LXTT Electric...
Whirlpool electric range timer constantly beeps and displays E2-F3 I don't even use the oven I just want beeping to stop I press STOP which changes display back to clock, but soon it returns to E2-F3...
Hi
Thanks for using FixYa.
Error F3-E2 in your Whirlpool oven means oven too hot and to resolve this issue you'll have to replace the oven temp. sensor (probe). Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 06, 2010 | Whirlpool GS475LEKS Gas Kitchen Range
What does an E2 code mean? I have a Haier Dehumidifier that is about a year old, I emtied the bucket and put the bucket back into place and hit the start button and nothing happen I unplugged the unit and...
I have a Haier Dehumidifier that is about a year old, I emtied the bucket and put the bucket back into place and hit the start button and nothing happen I unplugged the unit and error code E2 keeps comming on
Jun 30, 2010 | Haier HD451E Dehumidifier
E2 -F 1- MESSAGE APPEARS ON MY DISPLAY
F1 = analog to digital failure. unplug the unit for 30 seconds if the clock does not reset replace the control board.
E2 = Check Door / Switch. Replace door switch if defective.
Repairclinic.com has the parts that you will need.
Feb 20, 2009 | Whirlpool GR465LXLS Electric Kitchen Range
Whirlpool Electric Oven RBS305 overheats while baking, locks door
The technical manual for your range doesn't show an error code of E2 F2 but all of the F2 codes pertain to the touchpad of the range.
Can you clear the E2 F3 by pressing the cancel button? If not, shut off the power to the range for a few minutes and see if the error code goes away. If the error code remains You should unplug the range from the wall and remove the back panel for the control area. Disconnect the ribbon between the touchpad and the electronic control, clean the end of it and reconnect it.
If this doesn't repair the problem you will need to replace the touchpad on the range. The parts diagram lists two touchpads, they are part numbers 8273575- bisque, and 8272702- white.
Good luck
Dec 18, 2008 | Kitchen Ranges
Locked oven door
Look for a button or sensor which the door would press when closed.
If you find it hold it down for a minute, this should reset the lock
if it doesn't it may do when you let go
May 12, 2008 | Kenmore 95680 / 95681 / 95682 / 95684...
Error codes e2 and f3
F3 is an open or shorted oven temperature sensor, you will have to replace this and it should be attached near one of the elements but you will have to pull it out through the back.
E2 is, sorry to say, a possible ERC or Electric Range Control, otherwise known as the brain behind it. But on the plus side, sometimes it gives this code intermittently when it can't process the information from a failed sensor, so you might get lucky.
Jan 28, 2008 | Whirlpool GR460 Electric Kitchen Range
Jenn-Air electric range
my jen-Air has a problem with it continuing to beep. Ive tried to get it to stop by pushing all the buttons. When I pust the off/cancel button it just keeps beeping. Tried the stop timer button and same thing. When I turn on either the bake or convection bake button it automatically just shuts off by itself. It is approx 10-13 years old. HELP, or please tell me to get a new one.
Jan 06, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Amana stove stuck in 'lock' mode, door won't open
try hitting cancel is it displaying any error codes like e2 f3 try turning the breaker for five seconds then back on
Dec 28, 2007 | Whirlpool RF378 Electric Kitchen Range
Oven gives me an -F3- message and stops working
F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse
May 21, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
Whirlpool GR399LXHS Electric Kitchen Range Logo
168 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
