Question about HP 5510 4-in-one Printer
After uninstall and installing HP 5510 can not fax or scan
I had to uninstall and install the printer to get something hung in the printer queue. Now I can not fax from the computer or scan something from the printer into the computer. I had this problem when I first bought the 5510 but the solutions I had from then is not now working. When I called HP there is no support for this older printer. Could there be something ""hung up" that did not uninstall? The printer/fax does not show up as on my computer at this time. Using Windows XP.
  • jnpurdy Jan 02, 2009
    I uninstalled the 5510 for a paper problem as well. I then installed a J4580. It worked fine. I received back the printer and first uninstalled the J4580 and installed the 5510. The printer works but I have not been able to get the HP Director to work or the scanner. The display panel keeps saying to install the HP software. The printer is recognized in the printer and fax panel, and the scanner is recognized in the Microsoft "Cameras and Scanners" panel. I was able to create a JPG scan but not a PDF.
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    Did you leave the usb cable disconnected until prompted by the software?
    Also, did the HP Director software install? If not, you need to reinstall.
    If the printer is not showing in the Printers and Faxes window, you need to uninstall all the software again, disconnect the usb cable, reboot, and reinstall.
    Sergeant:
  • 154 Answers
With my XP system I considered it had become top heavy after years of updates in particular SP3 which gave it a headache in my view. I found that when it got into a mood to rattle its files "gently" may help.
Fragments of files get left behind which Windows loves to keep unless it has to overwrite them so I first run check/scandisk and if you can wait the full surface check, this will help to put its file house in some order.
Also to run Defragment this tidies the files plus may overwrite fragments left behind.
Then its a case of visiting HP to download the last/latest support and driver software which will better suit an XP with updates than an original supplied installation disc which may have have issues with a later version of XP.
There a other avenues but if you have not done the above for some time it will give your XP a boost anyway by putting files in order so speeding up its system and maybe solve some along the way.
Hope it helps.........
Posted on Jun 04, 2017
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 19 Answers
There is a utility called Microsoft Fit it that might be able to help uninstall the older version of the HP Photosmart software from your PC. It is pretty strait forward to run.
Once it is done try installing the software again.
Please let me know how it goes.
Thanks!
4 Suggested Answers
Beni S-P
  • 1006 Answers
SOURCE: scan
Uninstall it!Then while u install it change the directory dont install on programs files simply create new folder then install there...
Posted on Feb 29, 2008
adonscott
  • 106 Answers
SOURCE: Cannot print with wirelessly networked printer
hi,
if printing from 2 other computer works fine, will i think its not an issue of IP address which changes somehow. but anyways, try to check if you still have other printer drivers under "PRINTERS" (see control panel). it should say HP Photosmart c6100 series. If you also have there a printer icon that says HP Photosmart c6100 series Copy1, try using it (right click on that icon and choose Set as Default Printer). If you only have HP Photosmart c6100 series under PRINTERS, try to right click, then choose properties. When Properties box is open, click on PORTS tab. then click on configure ports below. Try to type in the IP address of the printer under "Printer Name or Host name or IP address". make sure that you already printed network configuration page to get the exact ip address of the printer, Dont know how to print? do this.
PRINTING NETWORK CONFIGURATION PAGE
1. press setup, then scroll down and look for Network.
2. press okay on network, it will give you the first option "VIew network settings".
3. press okay on it, and it will give you the first option "Print network configuration page."
4. choose that and press okay. it will print the network config page. from this document, you will be able to see the IP address of the printer.
Please let me know if the issue is still not resolve so that i can go ahead and give you another possible solution.
Thank you so much.
adonscott
Posted on Jul 07, 2008
  • 17 Answers
SOURCE: HP PRINTER 2840 WONT SCAN TO WINDOWS FAX AND SCAN PROGRAM
well........ first of all it depends on the Operating System on you computer, then starting from there the advice that i can give you it is to fully uninstall the software and then install the software back using the version that is on hp.com
after that when you have the full sw installed you have to set up the scan button on the printer from the twain scan window but that will be a piece of cake. just make sure ot get the software properly installled.
Posted on Jul 13, 2010
Connection to modem does not seem to work even though settings seem to be correct.Printer recognises my network and accepts the WEP code for my modem
There is an installation process that you have to follow when installing these. First uninstall it, you should see if there is any other printers installed on the machine too and remove those. Then unplug the printer and restart the computer. Install the printer software on the computer and when it is done, then turn the printer back on.
Aug 31, 2013 | HP Photosmart 5510
Scanner won't stay installed
When you install the printer software is it installed properly? if the printer is installed properly then you will do need to do the same step. First, uninstall the printer software by going to control panel > add/remove programs and then uninstall all the printer software. then go to control panel > printer and faxes if printer is present in the printer and faxes delete the printer. Restart the computer. Before reinstalling the printer software turn off your firewall, anti-virus, spyware if you have any. Then reinstall the printer. Try to scan again. if it works then try to restart your computer and scan again. it should work
Oct 27, 2009 | HP PSC 2355 All-In-One InkJet Printer
Error message
Uninstall the printer driver from Device Manager, then scan for hardware changes and install the printer driver when it detects the printer...All the best
Oct 02, 2009 | HP Deskjet 6940 InkJet Printer
I cant scan a document in my computer
During a normal installation of the HP All-in-One software, the following events occur:
1. The HP All-in-One software CD-ROM runs automatically.
2. The software installs.
3. Files are copied to your computer.
4. You are requested to connect the HP All-in-One to your computer.
5. A green OK and check mark appear on an installation wizard screen.
6. You are requested to restart your computer.
7. The Fax Setup Wizard (Windows) or Fax Setup Utility (Mac) runs.
8. The registration process runs.
If any of these things did not occur, there is most likely to be a problem with the installation. If the essential icons (Scan Picture, Scan Document, and Send a Fax) do not appear, your installation might not be complete.
If your installation is incomplete, you will need to uninstall and then reinstall the software. Do not simply delete the HP All-in-One program files from your hard drive. Make sure to remove them properly using the uninstall utility
provided in the HP All-in-One program group.
Sep 12, 2009 | HP Officejet 5610 All-In-One InkJet...
My hp 5510 all-in-one won't scan photos
Unfortunately the 5510 is no longer supported by HP for OS X 10.5.x and up. On the Apple tech site, they actually redirect you to a page the HP upgrade page (read: buy a new one).
If anyone can think of any 3rd part software that works with this, please post!
Thanks!
May 01, 2009 | HP Officejet 5510 All-In-One Thermal...
Mar 06, 2009 | HP LaserJet 2840 Printer
HP 5510 Scanner/Copier/Fax Stuck
I had the same problems some months ago. I only solved it when I deleted the printer settings from my computer and reinstalled the software, making sure that I installed all the components from the CD. Also make sure that the printer is on fax default setting when you are using it as fax. You can check this by going to My Computer then Control Panel, then choose Printers and Other Hardware then choose Printers and Faxes. You can then set as default hp Officejet 5500 series fax. Hope these suggestions help.
Jan 08, 2009 | HP Officejet 5510 All-In-One Thermal...
Office Jet K60xi Scanner Failure
Try HP's web site suggestions first.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01077492&cc=us&lc=en&dlc=en&product=61736
If your sacnner still fails to function, uninstall everything for the Officejet through add/remove in control panel. (Power off printer before uninstalling).
Go to Hp's web site. http://welcome.hp.com/country/us/en/welcome.html#Support
Step 1. Click, Download drivers and software (and firmware).
Go to step 2. For product, type in Officejet k60xi .
Power on your printer. (Wait for printer to fully power on).
Click, Start Detection>> button.
Allow HP to scan your system & install the latest software.
Follow the on scren instructions. (When finished, restart your PC). Test your scanner by scanning something.
If your scanner still fails to scan, you may be missing basic HP files loaceted in windows system & windows system32 folders.
(These missing files were not installed during your install of windows). Not your fault.
Apr 25, 2008 | HP OfficeJet k60xi InkJet Printer
HP 5510 4-in-one Printer Logo
265 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
