Question about MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript
The arrow on top of unit does not line up with the direction the
Trolling motor is going. How can I readjust this?
Sometimes when you disconect your battery for what ever reason and later hook the battery back up you will cross the wires and the motor will run backwards.
Posted on Nov 27, 2008
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    My bow mount 43lb thrust foot controlled trolling motor is only working in one speed. It must be in rapid speed be cause the motor only works with selector switch on the rabbit and not on troll.
    needs to go to a repair shop for a new resistor unit in the motor .or one of the wires going thru the shaft has broken .they fail dueto the constant flex from turning
    Dec 16, 2015 | Boating
    Lot of interference with unit transducer mounted on trolling motor when trolling motor is being used. Then clears up when not used.
    Some how you have Radio Interference conflicting with your unit. The RF as it is called, may be coming from the engine. Try to connect to an INDEPENDENT power supply for the Eagle and not the same source your trolling motor. You seem to be getting line interference.
    Feb 02, 2015 | Eagle Fishelite 502c Igps Fish Finder...
    Is there any way to modify in order to get more power/thrust out of a mk 30lb other than stock? or can you take a moto guide 80 lb., bow mount foot control, shaft and motor and combine it with transom...
    Hey Chris,, you are starting a project (or wanting to) that is going to be problematic... It will be easier to go buy a new trolling motor with the money you are going to spend attempting this conversion... the newer trolling motors are so much more efficient...
    Trolling Motors Fishing Motors Electric Boat Motors MotorGuide Trolling...
    https://www.minnkotamotors.com/
    Jul 15, 2017 | Minn Kota Endura 30 Freshwater Transom...
    Motor works fine but red indicator arrow does not move in direction of motor . what could be wrong.
    you could have a broken gear inside the top of the motor. take the cover apart and you will see 3 plastic gears. one on the motor shaft, one on the indicator and one in between. check all gears are ok.
    Jul 01, 2010 | Minn Kota Edge 40 Freshwater Bow Mount...
    On my standard motorguide trolling motor the direction indicator points one way my motor goes the opposite direction. How do I fix this?
    put the motor in the water and ensure that the propeller is at the rear. On the head of the unit (where the direction indicator is) push down and turn the round plastic plate (this plate has the direction indicator on it) clockwise until the direction indicator mark (mine is blue and is about one inch long) is in line with the alignment bar on the non-moveable part on the head. You will hear several "clicks" and this means that the indicator plate is clicking around to the proper directional alignment with the motor in the water.
    Jun 13, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
    My foot controlled trolling motor pedal is slipping when turning
    Your cable may have broken or slipped and maybe bending rather than shifting in the sleeve. You may also want to check and make sure all set screws and cable locks are secure.
    May 16, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
    No owners' manual
    I have a Motor Guide Trolling Motor - Bow Mount - Model-71V- 24 Volt. Problem is arrow on top of motor does not align with the direction motor is going about 100 degrees off. Any solutions? wm.513@hotmail.com
    May 12, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
    I have a motorguide trolling motor and the front
    With the top off take the six screws out and lift the cable and gear out. Next put your foot pedal at mid position. Then make sure the motor is pointed forward and reinstall the slider gear and the six screws. Last put the top on and make sure the arrow indicator is pointing forward and thats it.
    Mar 09, 2010 | MotorGuide Standard Motor Replacement...
    MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript Logo
    556 people viewed this question
    Top MotorGuide Electrical Supplies Experts
    jdthefixer
    Mike
    Mike Marcotte
    Mike Marcotte
    Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
