Question about Minolta Office Equipment & Supplies
LCD Display: CAUTION DO SHADE
Minolta Fax 2500 LCD Display: CAUTION DO SHADE IN SRV.MODE How do I clear or repair
    Genius:
  • 1,913 Answers
Rest your minolta printer unplug all things from printer.
also press reset button.
or go to menyu then find reset setings.then reset.
press power buttomn fro 10 seconds.
Posted on Nov 19, 2008
How to clear the usage counter?
From Samsung site:
1. Press MENU # 1 9 3 4 in sequence rapidly. The LCD panel should now display TECH.
2. Press MENU, and then press ENTER. The LCD panel will display Tech Mode.
3. Press the left arrow (<) button once. The operator panel will display NEW CARTRIDGE.
4. Press ENTER. The operator panel will display [YES].
5. Press ENTER. The toner warning message should be gone.
6. To exit TECH MODE, press MENU # 1 9 3 4 in rapid succession, as if you were dialing a phone number. The operator panel should no longer display TECH.
Oct 18, 2014 | Samsung 5pk - Scx-4521 Scx-4321 Scx-4521d3...
Fax machine says: Printing Online on its LCD readout but won't print anything. We have replaced the drum and the toner. We can't get the message to clear either
Press "Menu" & "Mode" keys. Display should clear. Then press 0, enter 91. Hit stop after completion. THIS WILL CLEAR ANYTHING IN MEMORY.
Aug 17, 2010 | Brother IntelliFax-4100e Fax
Can't get print job out of memory
If the memory if 100 % full on the LCD display then you have to reset the fax machine in the service mode
You can enter the Service Mode with the following operation.
Menu #
scroll down to
#12 CLEAR
all.....set
or
The operation that is carried out when the memory clear list cannot be printed can be altered by changing the
setting of SSSW SW02 bit 0. In the service mode as well.
Oct 09, 2009 | Canon FAXPHONE L170 Plain Paper Laser
I have Samsung fax & copy machine, SCX 5312F,
Press "Menu / Exit", then "System Data" on the one-touch dial keypad. The display shows the first system data option "Cassette Paper" on the upper line of the LCD display. Scroll through the options by pressing ^ until you reach the option "Message Conf." Then press < or > to select your choice. Options are: ON, OFF or ERR (prints only when a transmission is not successful). When the desired selection is displayed as indicated by the blinking cursor on the lower line of the LCD display, press "Mode / Enter" to save the selection. Press 'Menu / Exit" to exit the menu or "Stop / Clear" to return to standby mode.
Source: Samsung Laser Facsimile User Guide - Digital Laser MFP - SCX-5312F, pages 6.2, 6.4 and 6.5
Jun 12, 2009 | Konica Minolta bizhub C250 All-In-One...
Konica minolta problem
How to reset an F34, F35, or F36 code.
Solution:
To clear the code, perform the following:
1. Turn the machine OFF.
2. Enter the 25 mode, (turn the machine ON, while pressing the 2 and 5 keys).
3. Select 1: Software Switch Setting.
4. Use the arrows on the LCD to select dipswitch 3-1.
5. Touch the OFF key on the LCD to change the data to 0.
6. Press RETURN.
7. Power the machine OFF/ON to exit the 25 mode.
PLEASE. NOTE;
THIS IS ONLY TO RESET THIS CODE ,IF IT CAN;T BE CLEARED THAN YOU NEED TO Replace the temperature sensor assembly
Nov 29, 2008 | Office Equipment & Supplies
No image
well perhaps you forgot to switch it to the playback mode (red switch on the power ) in the record mode you have to choose between lcd and viewfinder . further more it is possible to switch the display off .
the camera needs enough power i reccommend 2500 NIMH
accu's
Apr 18, 2008 | Konica Minolta DiMAGE Z3 Digital Camera
Imagistics 2500 fax stuck in the "printing" mode. Need to reset.
Yes that worked!! I unplugged it, and kept the red stop button push in while plugging back in and it cleared it out! THANK YOU!
Jan 28, 2008 | Brother MFC-8220 Fax
SHARP ER-A440
2. Master reset (All memory clear)
There are two possible methods to perform a master reset.
· MRS-1
Used to clear all memory contents and return machine back to its
initial settings and return keyboard back to default keyboard layout.
Procedure
1) Unplug the AC cord from the wall outlet.
2) Set the MODE switch to the (SRV¢) position.
3) Plug in the AC cord to the wall outlet.
4) While holding down JOURNAL FEED key, turn to (SRV) position
from (SRV¢) position.
· MRS-2
Used to clear all memory and keyboard contents.
This reset returns all programming back to defaults. The keyboard
must be entered by hand.
This reset is used if an application needs different keyboard layout
other than that supplied by a normal MRS-1.
Procedure
4) While holding down JOURNAL FEED key and RECEIPT FEED
key, turn to (SRV) position from (SRV¢) position.
5) Key position assignment:
After the execution of MRS-2, only the RECEIPT FEED and
JOURNAL FEED keys can remain effective on key assignment.
Any key can be assigned on any key position on the main keyboard
i found this on the manual at this site...
http://www.skan.com/Manuals/A440/ERA440-SRV.pdf
Jan 26, 2008 | Casio Parts Cash Register PC Desktop
35 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
