Question about Master Heaters B155DST
Find a part
I think this part is a spark ignitor
it is ceramic "L" shaped
it has two yellow leads about 15 inches long
part number on it 0634-3
Master B155DST
  • macky81049 Nov 20, 2008
    ok i got a serial # WP060X5UZ 155.000 BTU
    MASTER forced air heater
    i need to locate a part that came from it
    the # stamped on it is 0634-3
    it appears to be ceramic with two yellow leads on it. spark ignitor maybe
  • 734 Answers
Purchase the spark ignitor from the above link--
Posted on Nov 20, 2008
  • 19,396 Answers
Can you explain again the whole problem, many thanks.
Posted on Nov 19, 2008
Xl44 top burners light
There are a few things that can do this... First check the burner top to make sure the holes are not blocked. 2nd, Are the other ignitors sparking? If so then try rotating the slack in the burners left and right - this works sometimes. If not then try placing a screwdriver (you holding the handle only) and touch the burner and lean the screwdriver towards the ignitor... making the spark gap smaller. If you have used the ignition without a burner in place the ignition pack will short out inside it and there will not be a spark until the gap is very small. 3rd, are the ceramic part of the ignitors cracked at the base... take care when washing as they break easy if caught on the cloth. The ignition pack works in pairs so having one work suggests the pair of this one is something in the lead if there is no spark... A huge spillover causing a short or a bad earth... check the burners are firmly in place. There is more but too much detail to post here. Good luck
Jan 02, 2014 | Kitchen Ranges
Igniter doesn't spark on only one burner
There are three parts to the ignition system typically.
The ignitor that is either in the burner or outside the burner.
The spark ignitor switch that is located on the burner control. (( one for each control ))
The spark modual. the modual creates the hi-voltage spark.
If the burner that does not ignight with its control does not spark but does spark with one of the other controls then the spark ignitor control switch is bad.
You can test it with one of the other burner control knobs. (( just try a working burnder and when it clicks look at the bad burners ignitor and look for the spark.))
If the bad burner that wont ignight does not spark then either your modual is bas or the ignitor is shorting out.
If you see any little spark but it does not spark from point A to Point B like the other burners then your ignitor is shorting and should be replaced.
If your ignitor is ceramic and it is cracked, then it should be replaced.
Jan 13, 2010 | Miele KM360GSS 23 in. Portable Gas Cooktop
My pentair minimax heater wont fire. The ceramic
If you can see the ignitor glow it is probally a gas supply problem. If you have continuity and it dosen't glow it is probally a voltage problem. They did have one model out when they first brought these out that needed a 110v ignitor and you will probally have to go to the factory help line for this info you will need serieal numbers from the heater and model numbers also. Then if this is the problem you will have to order parts from the factory as they are rare on the market. But it sounds like gas pressure or feed if you have good cont. and you have run the heater before. You should check your gas orfaces for tiny, tiny spider webs in the gas orfaces and soot on the burners. It's hard to cover it all with little info but I hope this helps. Good luck.
Oct 17, 2009 | Pool & Spa
My gas dryer runs but no heat.
Most gas dryers use a surface-type ignitor, a ceramic element with traces that glow to ignite the gas and yours has failed. BTW, it's helpful to give model numbers so we don't have to guess.
Aug 27, 2009 | Kenmore Dryers
2005 yamaha royal star venture. Still haven't found the problem with no spark on left rear coil. I replaced the coil, but there still isn't any spark. The wires (orange and black/red have continuity to the...
If you have continuity from the coil to the ignitor, the problem lies within the ignitor. The coils function by having a constant battery voltage on the red/black wire (you'll notice that ALL the coils have a red/black wire) - the primary windings in the coil charge up, until the ignitor "grounds" the colored wire (grey and white in the front, orange and yellow in the rear). As the voltage in the primary winding drops, it creates a strong magnetic field - the magnet (laminated iron) in the center of the coil charges the secondary windings, and the very high voltages generated fire the plug. You've already determined that the voltage on the orange wire is higher than the voltage on the yellow wire; that could only be because the orange wire is not being "grounded" on a recurring basis by the ignitor. (You have to remember that the meter you're testing the leads with cannot react to changes in voltage nearly as quickly as they happen; to really "see" what's happening at the coil, you'd need to use an oscilloscope).
Aug 25, 2009 | 2005 Yamaha Royal Star Venture
Stove Ignitor makes tik tik sound and the sparks continuously
may be a loose wire on the spark ignitor ceramic or if you run via main electic it may be your spark generator
May 14, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Replacing the Oven Ignitor.
That's all you have to do, cut them as close as possible to the old ignitor, strip them back about a quarter inch and connect them with ceramic wire nuts. Catriver
Jul 28, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Changing the broiler ignitor
The ignitor will be attached to the burner. Usually 2 quarter inch screws. Of course the ignitor has a harness that runs to the safety valve. You can either cut the wires and connect the new ignitor using ceramic wire nuts or you can follow the harness down. It's easier sometimes just to splice the wires and wire nut it, using the ceramic wire nuts. Catriver
Jul 20, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
Laser 73
hot surface ignitor or spark type of ignitor? does it look like a ceramic tube going into the pot? look on your computer board for the abbreviation brn. put the ignitor leads here.
Nov 01, 2007 | Rinnai Toyostove Direct Vent Heater:...
Master Heaters B155DST Logo
35 people viewed this question
Top Master Heaters Heating & Cooling Experts
T bone 1963
Gil Shultz
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Master Heaters Heating and Cooling Expert? Answer questions, earn points and help others
