Question about Kenmore Oasis HE 27082 Top Load Washer
Oasis washer displays code Ld and wont fully drain
I have owned the washer for 2.5 years. No problem until now.  I use He liquid detergent. Clothes are very wet, it wont drain all the way .  Suds are now on clothes, cycle won't finish.  I try to power off, it won't turn off unless I unplug it.  Goes crazy beeping and won't do anything now.  Paid too much to have it go bad in such a short time.  Do you know what the problem is?
  • 370 Answers
LD means long drain. Check to see if there is something clogging your drain hose. If not remove the drain pump from the bottom of the washer tub and clean it out. Also clean the recirculating pump. That should fix it. if not replace the drain pump.
Posted on Nov 19, 2008
My washer is showing a f32 ,f71 codes what does that mean
Sd Error Suds Detected (Stored Error Code F71) Did you use regular detergent?
Regular or hand-washing detergents are not recommended for this washer. Use only High Efficiency ("HE") detergent.
Did you add too much detergent?
Always measure detergent. Follow detergent manufacturer's directions. If excessive suds are detected, the washer will display this code while running a suds reduction correction routine at the end of the wash cycle. The suds reduction routine removes extra suds and assures proper rinsing of your garments. If the code remains and the wash cycle dial is ?ashing after the recovery routine has stopped, re-select your desired cycle using cold water. Press START. Do not add detergent.
Ld Error Washer is taking too long to drain water from the washtub
(Stored Error Code F32) Check the following:
Is the drain hose or pump clogged?
Is the drain hose higher than 96" to reach the drainpipe?
Is the Drain Pump Running?
Is the pressure transducer hose kinked, disconnected, or punctured?
Press PAUSE/CANCEL to clear display.
Mar 02, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore Oasis alternates between saying SD and F51.
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump...
If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here's the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
1. Unplug the washer while servicing inside the unit.
2. Remove the Cabinet....
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here's a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don't own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT - DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select the following on the operator console - DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). "C00" will show on the console display as the washer begins diagnostics mode.
10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.(*&^%
Jun 23, 2009 | Kenmore Oasis HE 27082 Top Load Washer
LD code problem
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jun 06, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Code LD comes up wont drain
Hi, how are ya?
Hello, LD stands for long drain.
If all the water isn't out of the unit within a certain time, the ld will flash.
Could be 2 things.
1) There's lint stuck in the pump preventing the water to drain properly or
2) You're using too much soap causing lots of suds also preventing the pump from draining properly. If this is the case, what you need to do is run the washer on full load with no detergent and clothes. Let it go thru the cycle and get rid of eccess suds. This is most likely your problem.
Thanks for using Fixya
Jun 04, 2009 | Kenmore Oasis HE 27082 Top Load Washer
White residue om dark clothes
Even if you use liquid detergent, if you put too many clothes in the washer, or too much detergent. It has happened to me before.
May 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Oasis washer has Ld CODE runs will not drain.
LD code is long drain one of 2 things the drain pump is frozen and need to be replaced or there is somthing in the pump. Pull the washer a way from the wall a bit and get a bunch of towels. Lean the washer back against the wall towards the middle in the back you will see the pump take it apart and find the clog.
it can be assessed through the bottom.
May 03, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite washer problem
you can use a shop wet vac on the drain hose to **** the rest of the water out then you can remove the hoses to check to see if anything is suct in hoses or pump-,mike
Apr 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washer wont wash displays LD on display timer
Could be 2 things.
Best of luck :)
Dec 28, 2008 | Kenmore 22062 Top Load Washer
LD error on Kenmore Oasis HE 27082
I had the same problem with F1 and F68. I just bought a $345 new computer for my washer. These machines are defective. Mine was purchased in Nov. of 2006 but not even out of the box until Jan. 2007!!!
Apr 27, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Displays ld
Hi, how are ya?
Could be 2 things.
Oct 16, 2007 | Kenmore 27032
Kenmore Oasis HE 27082 Top Load Washer Logo
149 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
